My Samsung LCD TV constantly reverts back to test mode and resets all of the settings. I've tried the "press volume on the TV and then press menu for 5 seconds until the mode switches to standard or dynamic" countless times. I've done the 128 mute power on, went to reset and went through the programming cycle - making sure test mode was off - half a dozen times; nothing helps. The TV is a little over a year old and out of warranty, although it's had this problem since I bought it but I never took the time to address it with Samsung, so I'm probably hosed. Any other solutions or advice out there?
  • 2 more comments
  • marty Jun 17, 2009
    The exact model is LNT4671FX/XAA
    Cheaper than I thought it would be, actally; I was worried I would be spending a fortune.
    Two more questions for you:
    1.) Is this a common problem? and,
    2.) Is it difficult to replace the unit? I ask because my TV is mounted to my wall, so it's gonna take some work getting it down.
    Thank you for your help! It's very much appreciated.
  • marty Jun 18, 2009
    Thanks again for all of your help! I'll order the part and that'll hopefully take care of it.
    Thanks for your prompt replies and solution! Great service!
  • 10,594 Answers
It seems problem with EEPROM chip in system control section of TV as EEPROM holds saved service / adjustment data.
Let me know exact model of TV to find out main board of TV some where available because system control section is located on main board and these are non repairable on component level. Board swapping is only option in LCD TVs.
Thanks.
Posted on Jun 17, 2009
How to remove auto visualisation n digital noise filter on and digital noise filter off features from screen of samsung lcd 21 inch....this feature is always there on the screen..........
My TV had the same problem and I have managede to get rid of it. The solution is very simple. This displays mean that your TV is in the " Store Demo" mode and any changes you make will last only for 30 minutes and when the TV is turned off the settings will change back to the normal. Whether you TV is in the "Store Demo" mode can be confirmed by pressing the "Info" button on the remote and you will see that "store demo" appears on the screen. To change this mode to the "home mode" you will have to press the "Volume button" on the TV and when the volume sign appears on the screen then you will have to press the "Menu" button on the TV (not on the remote)and hold it down for about 7to 10 seconds. This changes your TV mode from "store demo" mode to the home mode. Confrim whether the store demo mode has been put off by pressing the "Info" button on the remote to see whether the store demo sign appears on the screen. The store demo is set by sales persons in the shops so that any demonstratation/changes that they make while showing to customers will be temporary as the settings revert back to the original.
Aug 03, 2011 | Samsung SyncMaster 215TW 21" LCD Monitor
Digital Noise filter off , digital noise filter on and auto visualization is always displayed in my Lcd samsung series 4 even though i turned it off in Picture options , digital noise filter is changed to...
Aug 13, 2010 | Samsung LE40R74BDX 40 in. LCD Television
When i turn the tv on the volume is stuck all the way up and if i mute it it stays muted until you turn it off and back on
Muting is not designed to lower volume it shuts it off completely That;s why it resets when turned on and off.
Unless by muted you mean you can lower the volume to a listenable level but it reverts to full when you restart it.
Try using settings and set the volume and the type of sound(mode) you want then when you exit the menu it sshould save those settings.
Please rate my help++++Thanks for using FIXYA
May 16, 2010 | Planar XP15SSA-01 15 in. LCD Television
My Samsung LCD TV slowly flahses colours, each about 2-4 seconds
hi,
your lcd is in test mode. you may try off the power. press and hold menu + source + power on.
this should go back to normal mode.
Apr 01, 2010 | Samsung LA40M81/BDX 40 in. LCD TV
Picture Mode reverts always to Dynamic after several minutes
The set was a store demo, and the options were set so they could not be adjusted. On instruction from Samsung I pressed MENU and VOLUME buttons on the side of the set and hold for 7 seconds The display reverts to Standard from Dynamic. The Remote Options button showed Store Demo, but now shows Standard. All memory functions seem to function now. Thanks for your help.
Watty2c
Jan 17, 2009 | Samsung LN32A330 32 in. LCD TV
Picture setting regularly changes to dynamic from standard
You need to change the option throgh the service mode.
You can not access that mode without permission from Samsung.
better to contact Samsung call center.
Nov 18, 2008 | Samsung LN-T4661F 46 in. LCD HDTV
Modified Picture Settings Reset Each Time TV Is Turned Off/On
Your TV may have been put into shop mode or demo mode. How to get out of "Shop Mode"
1. Press [Source] to get to the Air or Cable input on the TV or TV remote
2. Press [Volume +] once on the TV itself (not the remote)
Next step must be completed while the volume bar is still on screen
3. Press and hold [Menu] on the TV itself (not the remote) for about 7 seconds
If the screen flashes "Dynamic Mode", the process worked
4. Finally check whether the Picture Mode is "Shop Mode" or not after passing "INFO" on Remote Control. If picture mode is still in “Shop Mode” try the alternative way below
Alternative Method
Press [Source] on TV remote to get to the AIR or CABLE input
Press [Menu]
Press [Down Arrow] to highlight SETUP and press [Enter]
Press [Enter] again on PLUG AND PLAY
Wait 10 seconds
Press [Enter] to select ENGLISH (or choose an alternative language
Press [Right Arrow] to highlight HOME and press [Enter]
Press [Menu] repeatedly until you see the message ENJOY YOUR WATCHING
Confirm you are out of shop mode by pressing [Info] on the TV remote
Nov 09, 2008 | Samsung HL-T5687S Television
Samsung 37
It sounds like your TV is set at Shop Mode. To veify that turn on your TV and press the info button on your remote, some info will be displayed, If Shop Mode appear please follow the next steps...
In order to change that mode turn on your tv, press the volume key (either one) on your front or side panel (Depends of the model you have) the volume bar will appear, once this happend press the menu key on the front or side panel and hold it for like 7 seconds, "Dynamic" symbol will appear at your screen this means that you are not longer at Shop mode. You can double check by pressing info button at your remote
Regards
Jan 14, 2008 | Samsung LN-T4665F 46 in. LCD Television
Can't use "plug&play" from TV menu
I can switch between shop mode & normal by holding down the menu key on the side of the screen, just press it till it changes.
Jan 07, 2008 | Samsung LE32R41BD 32 in. HD-Ready LCD...
26PF5521D wont show menu after reseting factory defaults
Switch the TV to analogue mode (if possible)
Press and hold the "MENU" button on the side of the TV. The settings menu should appear. Continue to hold the menu button until this menu disappears. (If you let go before the menu disappears, start again)
The TV should now go blank for up to 2 minutes, and then revert to factory settings and intitial installation screen.
Procede as per original installation.
Oct 26, 2007 | Philips 26PF5521D 26 in. HD-Ready LCD...
Televison & Video Logo
59 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
