Question about Acer Aspire One Netbook 8.9" Notebook
My internet service requires that I load a cd, i do not see a cd drive?
    Novelist:
  • 117 Answers
You do not have one on an acer netbook. You may have to download the software to a thumbdrive for your ISP and boot from that thumbdrive. there are other solutions but this is the easiest.
Ruben
Posted on Aug 16, 2009
Difficulty to open pdf files
1. Make sure that the system meets the requirements for the Acrobat product that you use.
Acrobat can't run correctly if the system doesn't meet the following requirements:
  • Intel Pentium processor
  • Microsoft Windows XP Professional or Home Edition with Service Pack 1 or 2, or Tablet PC Edition, or Windows 2000 with Service Pack 2
  • 128 MB of RAM (256 MB recommended)
  • 460 MB (Professional) or 360 MB (Standard) of available hard-disk space; optional installation files cache (recommended) requires an additional 300 MB of available hard-disk space.
  • 1024 x 768 (Professional) or 800 x 600 (Standard) screen resolution
  • CD-ROM drive, if installing from a CD
  • Internet Explorer 5.5 or later
Jun 16, 2011 | Adobe Acrobat 7.0 Professional
How to install SystemMechanicPro
First thing first I'd check if my machine meets the requirements. [To run SM Pro your computer must meet the following requirements: run Windows 7, Vista, or XP/CD or DVD drive (for CD-based installations)/ 120 MB free hard drive space/at least 256 MB RAM/Internet Explorer 6 (Service Pack 2) or later/Internet connection (required for license activation)]
If all are OK than you can move on and download and install the software.
Here are the instructions and the developer provided:
http://www.iolo.com/customercare/kbarticle.aspx?id=KBA-02212&utm_source=rss&utm_campaign=ten&utm_content=326&max=29
I hope it will work for you!
[please RATE if my answer was helpful for you!!! THANK YOU!]
Mar 07, 2011 | Iolo Technologies System Mechanic: Windows
How do i install internet ti sylvania mini note book
There are three basic solutions for installing software on a netbook without an optical drive:
1. Share the Disc Over a Network
Required: A network, and a PC with an optical drive
This solution essentially shares the optical drive in one PC over a network to your Netbook. For most this is the easiest method because most users these days have a network readily available, and assuming there's a network there's likely a PC with an optical drive connected to it.
First you need to load the CD/DVD into the optical drive in the PC. Now go to My Computer and right click on the drive with the loaded media, click properties, navigate to the Sharing tab (note if you haven't done this before it may give you a warning that you shouldn't do this unless you know what you're doing, click the message to continue). Check the Share this folder on the network box, give it a name of your choice and hit OK.
From this point forward any computer on your network will be able to access the shared drive. If this is a problem be sure to follow the steps above and uncheck Share this folder on the network, to take it off.
Now, make sure your Netbook is connected to the network (this works wirelessly or through ethernet wired connection). Access My Network Places, and click Add A Network Place, use the wizard to add the optical drive you selected to share.
Now that it is shared you should be able to access it from My Network Places at any time (when your Netbook is connected to the network), and it should automatically refresh if you switch the CD, if it doesn't do a right-click, and hit refresh and the files should update. If you are trying to install software and are used to auto-run, double click the Setup.exe file or similar to begin installation.
2. Use an External Optical Drive (can be a bootable disc)
Required: External optical drive
External optical drives are the easiest way to use CD/DVD media and install software to your Netbook. It is however the most expensive option.
External drives are very simple; just plug it into an available USB port. Your Netbook will automatically detect the drive and simply add it to My Computer just like a built in drive. Some drives will even run power through the USB, while this makes them more mobile it eats up your Netbook's battery faster, if that is a problem other external drives do require a power outlet for use but should not drain your battery.
3. Create an Image (not bootable)
Required: Image making software (like Alcohol 120% or VirtualDrive), image emulation software (Alcohol 120% includes one, Dameon Tools is another, or Power Iso), access to a computer with an optical drive, and a method to transfer a large file from that computer to your Tablet PC.
You will need to use your particular software User-Guide for most of this process. What you do essentially is use software to create an exact copy of the CD in the form of a file (normally a .iso) that has to be read by an optical drive emulator which then can access the CD as if it were being read by a real optical drive. The biggest disadvantage to this method is that CDs can run around 700mbs, DVDs around 4gbs... transferring files of that size, even over fast networks, can be tedious. A benefit however is you can carry important CDs (as files) with you as you go, so for example if you need to install Microsoft Word content to use some feature while your in a meeting, you can do so without having the physical CD with you... This however of course requires heavy disk space since the CD file tends to be around 700mbs.
Hope this helps.
Dec 28, 2010 | Sylvania G-Netbook
Installed MS Office 2007 on XP Home Edition version 2002. Message install was successful, however, try to run application and get error "application has failed to start because the app configuration is...
Update your OS to XP service Pack 3 from microsoft.
If your operating system do not have any service Pack(SP) ie minimum SP2 yet, your M/S office 2007 will not function.
Do your Operating system meets the below requirement?
Microsoft Office Basic 2007 requirement:-
CPU: 500 megahertz (MHz) processor or higher
RAM: 256 megabyte (MB) RAM or higher1
HDD: 1.5 gigabyte (GB); a portion of this disk space will be freed after installation if the original download package is removed from the hard drive.
Drive: CD-ROM or DVD drive
Display: *1024x768 or higher resolution monitor
OS: Microsoft Windows XP with *Service Pack (SP) 2, Windows Server 2003 with SP1, or later operating system
*Internet Explorer 6.0 or later, 32 bit browser only. Internet functionality requires Internet access (fees may apply).
Aug 30, 2010 | Microsoft Computers & Internet
My emachine EL1333G, with windows 7 home premium, had a cd explode in the cd drive. The incident caused extreme error, as one could imagine, but the cd drive still works. The machine wouldn't load the...
You should be able to use xp too download win 7 from e machines as long as you have a mdl and serial # of the machine.
The cd exploding is usually beacause of a stress crack in the cd,
Aug 30, 2010 | Computers & Internet
Bought still life 2, have windows xp...game won't load . It just clicks but won't come up on the screen at all.
Hello mis_74,
First things first What type of Disc Drive are you using ?
CD Rom
CD/DVD Drive
Requirements are that you use a CD/DVD Rom Drive.
Next make sure the disc itself is not smudged with finger prints ect. Also check for scratches on the disc. Making sure it is clean ensures that the laser is correctly reading the disc.
Double check and see if other disc's DVD's and CD's will play in the same drive to ensure the drive itself is not bad.
Post back if you are still having problems after verifying that these things are not causing the issue.
Thank you for choosing Fixya!
Aug 25, 2009 | Microids Still Life for Windows
How to install windowxp in dell laptop model latitude cpi
Meh, reload Windows or another OS from the USB key you can set up at a friend's or a store.  See Vuze for videos.
Apr 27, 2009 | Dell (H5195) Laptop Cooler, CPU Fan,...
HOW TO INSTALL SOFTWARE THROUGH THE NET
i think you need that little cd dude.... go complain to the seller and try to get that cd because i dont think you can get it off the internet
Dec 25, 2008 | Philips GoGear SA3245/37 Digital Media...
My desktop is connected to the internet but my toshiba laptop connected to my network does not connect to the internet. How do I turn on the wireless switch? Is there other proceedures that I need to...
First enable the Wireless service of your Internet Service Router/modem what ever it is.
Then enable the Wireless plug and play service in your Laptop, it will automatically load the required file, if not then use the Windows Installation CD/Mobo CD of the Laptop.
Let me know if you need further assistance and also specify in detail so we can investigate and fix the problem.
Have a Nice Day & Best of Luck
Puneet
Oct 05, 2008 | Computers & Internet
Acer Aspire One Netbook 8.9" Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
