Question about Toshiba Satellite A45-S150 Notebook
Application error 437 - cannot read file 17274 bluesky.wmz This is first time I have tried to use the Toshiba recovery disk for my Satellite A45-S250. The installation repeatedly fails with the above error message.
    Sergeant:
  • 338 Answers
Check the cd you are using for scratches, looks like a readom the cd error to me.
to solve:
copy cd using freeware program: imageburn,make an image of disk, burn it onto cd-r(your save-copy, legal)
try installing from copied version could work
else:
copy whole installation cd into sepearate folder and run installation from harddisk.
Posted on Jun 18, 2009
Error 437
It usually means "cannot read file" or something along those lines. You can try cleaning the disk, or making a copy with another machine.
If not you will have to find another recovery disk or a retail version of the Windows you are trying to install, which I suspect is XP.
Jun 19, 2012 | Toshiba SATELLITE A10 A15 A20 A25 A35 A40...
I get the error message when i try to create media recovery for my laptop toshiba l505. the error messsage is "no HDD recovery area", "the toshiba recovery media creator cannot be...
I am glad to HELP YOU!
When you start to create the RECOVERY MEDIA your machine is creating a virtual file [a temporary one...] that includes all parameters and drivers and system files of your operating system; once the temporary file is done the recovery files are written on the indicated media [a hard drive or a DVD/CD].
Because of the huge size of the file [the temporary one] you need enough room for the virtual file to be created.
So you got your error message just because you DON'T HAVE ENOUGH ROOM on your hard drive.
My suggestion is: find an external drive [a USB attached hard drive] and make the RECOVERY MEDIA there. Meanwhile try to clean up a little bit your hard drive by using that application in Windows called DISK CLEANER [START > ALL PROGRAMS > ACCESSORIES > DISK TOOLS > DISK CLEANER].
My best regards!
... and don't forget to RATE, please...
Apr 19, 2011 | Toshiba Satellite L305-S5907 Laptop
I have a satalite 300 had a bad virus,decided to preform toshiba recovery wizard.(clicked next.)Warnig sign comes up(when the recovery is executed,all data will be deleted and rewritten,(CLICKED YES)new...
try using ActiveBoot suite v5.0.5, when turnig on your computer. This program will scan your computer and show u all the errors,missing files, wrong dll,...and repair them. It worked very well for me as I had a TROJAN virus on my Toshiba satellite 300 and couldn't even boot anymore.
After that try use the RegistryBooster tool witch solves every windows problems.
I hope this will help. Good luck :)
Feb 19, 2011 | Toshiba Satellite Pro L300 Notebook
My Toshiba Satellite A205-S5803 will no longer read or write cds
Try getting your recovery DVD's out --- put Disk 1 into the drive; choose "Install Applications and drivers" --- click Next and follow the directions.
Oct 08, 2009 | Toshiba Satellite A60 Notebook
Application error when running recovery disk
hi
Did you create any partitions on the HDD?
Obviously the HDD or some partitions on the HDD are corrupt.
In my opinion, you should firstly try to format the whole HDD and delete also whole partitions.
Then insert the recovery CD and try to install the Toshiba image
villival
Dec 15, 2008 | Toshiba Satellite A135-S2276 Notebook
Used Recovery Disk and I have an application error
It seems like your hard drive has some bad sectors.
You need to run some disk manager software to check/fix tour disk.
The best choice would be to download the "ultimate cd" from here
Boot from the cd, go to "hard disk tools" and select a disk manager (better to select the one from the same manufacturer of the disk).
Run a scan, and fix the drive (if it is possible). Then rerun your system restore cd again.
If the hard drive can't be fixed, you'll have to replace it before running the system retore.
Dec 15, 2008 | Toshiba Satellite A135 Notebook
Getting grey screen with wrong machine
Create a bootable DOS disk and place it in the drive. Then restart the system. that should get you to a DOS prompt. At the DOS prompt you can tell it to change to the D: drive. You can tell if you have done this right because you will see a D: as part of the prompt. Insert recovery disk 1. If it does not start reading the disk type DIR at the D drive prompt. That will list all the files on the D: Drive. There should be one called autostart or install. Type in the name of the file including the extension. Hit enter.
A second approach is to hit F12 during start up and drop down to the second item and hit enter. That started the Toshiba recovery disk for me once when it would not read it automatically at start up.
Dec 14, 2008 | Toshiba Satellite A105 Notebook
Not installing Toshiba Restore Tool 7.5.1.Answers
if you have a good copy of windows,you should try the repair os option. your files should for the most part be safe with this.
Oct 28, 2008 | Toshiba Satellite A135-S4527 Notebook
Sound drivers for Xp sp2
For specific models with different chipset drivers, you can get the sound driver & pretty much everything else on support.toshiba.com. If you can't connect to the Internet, "Tecra, Portege", & sometimes "Qosmio" models came with a built-in HDD recovery, meaning you need to create your recovery disk by running the "Recovery Disk Creator". An application to create your recovery disk. A shortcut is created on the desktop by default, if you cannot find it there, try looking at "C:\Program Files\Toshiba\Toshiba Recovery Disk Creator" & run the "exe" file, it should give you a menu to create one. After creating the disk, you can use that disc to install the drivers for all Toshiba pre-installed devices/softwares on that machine. For Satellite models, the disc should come with the laptop when you boughtt it. When you have the disc, just insert it inside of windows, it will give you options to install the driver & software for a specific toshiba device.
Hope this helps.
Jul 15, 2008 | Toshiba Satellite A100-S8111TD Notebook
Error 437
Hi, I did a Google on your error 437 and it would seem that this problem pops up only if: 1. using SYMANTEC (Ghost); or 2. using Original Toshiba Restore Disc. where possibly: a. the restoration procedure needs to write a log file somewhere (A:?) which does not exist and therefore waits; b. the restore disc is probably corrupted; and/or c. the Ghost image is corrupted. A few things you can try: * On another computer, check the integrity of your recovery disc; * Get hold of another Windows installer and do a complete, clean, fresh install (you will have to use your original Win numbers @ the bottom of your laptop). You will only need the recovery disc for your hardware drivers; or * Call Toshiba Support and get assistance. I was made to understand that they provide replacement Recovery Disc (>50USD). Hope this be of some help/idea. Post back how things are or should you need additional information. Good luck and kind regards.
Aug 27, 2007 | Toshiba Qosmio F25-AV205 Notebook
Toshiba Satellite A45-S150 Notebook Logo
415 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
