Question about Microsoft Xbox 360 Elite Console
Turns on, freezes
Turns on then makes a loud staticky noise that cuts out, and a checkerboard like pattern appears on the screen. No flashing or red lights
    Problem Solver:
  • 4 Answers
Try using the audio video cables andand try taking them out and putting them in again and if that doesn't work try tapping the cords while they are inside of the tv
Posted on Jun 19, 2009
Picture freeze and pinstrip on the screen
When a Microsoft Xbox 360 console experiences a "general hardware" failure or "core digital" failure, three flashing red lights appear (known as the "Red Ring of Death") around the power button, in lieu of the four green lights indicating normal operation. Warning signs may include freeze-ups, in which the screen has strange, spontaneous graphical problems in the middle of gameplay, such as checkerboard or pinstripe patterns on the screen, the sound is frozen and changed to a strange, static-like sound, and the console only responds to pressing the power button to turn it off. These events may happen once or several times until the general hardware failure occurs, when the user attempts to turn the console on, and the three red lights are seen and the console will not function.
this sounds like it will error e74 which will need a reflow
but dont overheat with a towel as this will cause more problems
Mar 07, 2011 | Microsoft Xbox 360 Console
How can I fix "Red ring of death" on my XBox 360
Three flashing red lights around the Xbox 360 power button (nicknamed the "Red Ring of Death" or "Red Lights of Death" or "Red Ring of Doom"), instead of the one to four green lights indicating normal operation, represent an internal problem that requires service. Warning signs may include freeze-ups, graphical problems in the middle of gameplay, such as checkerboard or pinstripe patterns on the screen, and sound errors, and the console only responds to pressing the power button to turn it off. These events may happen once or several times until the hardware failure occurs, or not at all. If the console freezes occasionally, the error will not necessarily follow. The technical problems seem to affect some generations of consoles more than others. e.g. Xbox 360 60GB This error code is usually caused by failure of one or more hardware components, although it can indicate that the console is not receiving enough power from the power supply, which can either be due to a faulty power supply or if the power supply cable is not fully inserted into the console. The 3 flashing lights can also be caused by power surges; if the console is connected to an outlet that receives a power surge, it may have a failure and the 3 lights will appear as long as the console is plugged into the outlet. Turning off the console, unplugging all power cables and plugging them back in, and restarting the console will fix the issue in this case. hope this helps
Nov 30, 2010 | Microsoft Xbox 360 Console
An incomplete red ring circle appeared
All games freeze when trying to play. Comes up with a Red and Black Checkerboard on the screen. Loud "Beeping" noise once this happens. The console is still on but game freezes. what do I do?
Well best solution is take off HDD and play a game if it does not freeze then replace your HDD buy a new one, if there is still a problem, contact MS. (1-800-4MY-XBOX)
Dec 09, 2009 | Microsoft Xbox 360 Console
My xbox360 has a red circle instead of a green circle theirfore will not work what can this be
Three flashing red lights around the Xbox 360 power button (nicknamed the "Red Ring of Death"), represent an internal problem that requires service. Warning signs may include freeze-ups, graphical problems in the middle of gameplay, such as checkerboard or pinstripe patterns on the screen, and sound errors, and the console only responds to pressing the power button to turn it off.
Distinct from the General Hardware Failure is a similar-looking error warning where four red lights appear, in which case the console does not detect an AV cable is plugged in. The four lights can sometimes also be seen when power surges or very brief power outages occur while the console is running, in which the console needs to be unplugged and plugged back in again to reset the error. Two red lights appear when the system is overheated.
Oct 06, 2009 | Microsoft Xbox 360 Console
Red Ring + Freezing Issue
Most likely cause is the perhaps cold solder points on the chips. This happens after the 360 goes from hot to cold over and over again. Miniature fractures can occur in the solder of the chips therefore causing bad connections. There are a number of ways to go about fixing this like the controversial hot towel trick and the 10 penny fix. Some say its bad, but this is quite effective and similar to the production process anyways. Usually those fixes are used in regards with RROD or 3 rings, but I have solved the issue you are talking about with both and so far so good. Here is a nice video explaining the 10 penny fix: http://www.youtube.com/watch?v=asTDsKLVexA&feature=PlayList&p=FDB6C3569A311E6B&playnext=1&playnext_from=PL&index=9 Hope this helps and gets you back up and on your feet soon. Good Luck.
Jun 12, 2009 | Microsoft Xbox 360 Console
No picture when turned on
The tile pattern on the screen is caused by a defective FMT board part # 930B924002.
Sep 15, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Game locks up
if when it freezes it has a kind of checkerboard pattern, then it is what happens before the three red lights of death, try the eraser trick posted by Carl26
Sep 03, 2007 | Microsoft Xbox 360 Console
Game freezes after 5-10 mins play time
Aug 29, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Elite Console Logo
172 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Stu Morris K
shaun taylor
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
