Question about Canon - SUPER G3 FAX BOARD-T1 (0450B002AA)
I want to change the name on header from one name to another. HELP!
  • Canon Master
  • 365 Answers
Go to the fax menu and change the unit name and phone number.
Posted on Jun 20, 2009
How to change the fax # on my HP J4680 all in one printer
if you are asking how to change fax header,here's how:
on the printer push wrench button or setup ,push right arrow to go to fax settings,hit ok,fax header,hit ok,enter your name then your fax number ,hit ok
May 27, 2011 | Office Equipment & Supplies
How do I change the name and fax number on the top of my outgoing faxes
The software that came with the printer will have a "setup" or "settings" icon. You can change it there.
If you can't find it or never installed it you can delete the printer software and re-install it and you can start from scratch with the new information you want.
Jan 27, 2011 | HP OfficeJet 6110 All-In-One InkJet...
How to create book type header in docx file means double header, one for tile which must be apply for whole doc. while other tiltle may change after few nuber of pages
this will set the head on every page till you remove it.
On the View menu, click Header and Footer to open the header or footer (header and footer: A header, which can consist of text or graphics, appears at the top of every page in a section. A footer appears at the bottom of every page. Headers and footers often contain page numbers, chapter titles, dates, and author names.) area on a page.
  1. To create a header, enter text or graphics in the header area.
  2. To create a footer, click Switch Between Header and Footer on the Header and Footer toolbar (toolbar: A bar with buttons and options that you use to carry out commands. To display a toolbar, press ALT and then SHIFT+F10.) to move to the footer area, and then enter text or graphics.
  3. If necessary, format text by using buttons on the Formatting toolbar.
  4. When you finish, click Close on the Header and Footer toolbar.
Jul 21, 2010 | Microsoft Office Professional 2007 Full...
How do I change the company header on this fax machine?
with function key go to entry mode and own number set .change name and number
May 20, 2010 | Sharp FO 5700 Plain Paper Laser Fax
How can I remove the sending fax number on my transmissions on HP
Check the HP Officejet Pro L7300/L7500/ L7600/L7700 All-in-One series
User Guide
(page 83):
"Configure the fax header:
The fax header prints your name and fax number on the top of every fax you send. HP
recommends that you set up the fax header by using the software that you installed with the device. You can also set up the fax header from the control panel, as described here.
NOTE: In some countries/regions, the fax header information is a legal
requirement.
To set or change the fax header
1. Press Setup.
2. Press Basic Fax Setup, and then press Fax Header.
3. Enter your personal or company name using the numeric keypad, and then press OK.
4. Enter your fax number by using the numeric keypad, and then press OK.
To set or change the fax header via the embedded Web server
▲ Select the Settings tab, select Fax from the left pane, select the Basic sub-tab,
and then enter the Fax Header Name and Fax Number. Click the Apply button."
Sep 18, 2009 | HP OfficeJet K80 All-In-One InkJet Printer
Fax header Ricoh 1013F
GEEZ, the 1013f, I beleive you have to access the user tools buttom, it is on the left side of the control panel. From there slect fax features, then select general/settins adjust, then program fax information, then slect fax header, from there you will use th alpha keys on the left side that double as the one touch keys. When you are done select ok!
http://copierquestions.websitetoolbox.com/
Aug 13, 2009 | Ricoh Aficio 1013F Copier
Want to change the Header
Press Data registation,on usersettings press set,press the arrows untill you get unit name,press set,insert you company name there.
To change the fax number-under usersettings select unit number and change it to your number.
Jan 12, 2009 | Canon LaserClass LC 8500 Plain Paper Fax
I need insrtuctions on how to get certain information in the upper left hand corner of every page in a certain document. Also, instructions on how to change some parts of information...
f1, helpscreens
search for 'headers and footers' and 'autotext'
the text in the upper left corner is called a header
autotext in a header allows you 'chapter XX' to update automatically as you type more chapters
specific instructions cant be given because the question did not inform what program is being used
Oct 01, 2008 | Microsoft Computers & Internet
Incorrect Fax Number showing on sent Faxes
the solution given is correct. happy faxing OMNIPRESENT
Oct 01, 2007 | HP LaserJet 3050 All-In-One Printer
Header
change the prefrence setting
Sep 13, 2007 | HP Photosmart 2610 All-In-One InkJet...
170 people viewed this question
old marine
old marine
