Toshiba laptop l305d won't reboot to factory default
I know i am supposed to hold the 0 key and turn on the computer, but when i do that it just makes a loud beeping sound so i let go, and it just starts up the computer regularly instead of letting me reboot to factory default...are there any other ways i can do this?
and why wont my computer let me?
    Problem Solver:
  • 7 Answers
I never heard of holding the 0 key, but have you tried hitting F10 or F12? Normally when you first boot the computer you will see down in the bottom of the screen or on the top corner to press a certain key for system recovery and a certain key for entering setup, etc. It will probably be one of the function keys like F10 or F12, but I believe I have used F2 on a few. Easiest way is to check what your computer says when you first boot it.
Posted on Jun 17, 2009
How do I reboot my Toshiba Satellite C55 without a
If your recovery partition has not been deleted you might be able to do it. See if you can access recovery mode
  1. Make sure the computer is turned off ("Shut-down" from the Windows Start menu)
  2. Remove any peripherals such an external mouse, keyboard, monitor, USB flash drive etc.
  3. Make sure the AC Adapter is plugged in and working.
  4. On machines with the F key numbers on the top edge of the keys and in White:
    • Press and hold the 0 (zero) key and power up the laptop.
    • Release the 0 (zero) key when the recovery warning screen appears.
    On machines with the F key numbers on the bottom edge of the keys and in Gray:
    • Power up the laptop.
    • When the initial TOSHIBA screen displays, press the F12 key to enter the boot menu.
    • Use the arrow keys to select the HDD Recovery option and press the enter key to begin.
  5. The TOSHIBA recovery wizard warning screen appears stating that when the recovery is executed all data will be deleted and the original factory software image will be rewritten. If the recovery process offers a choice of Operating Systems, select the appropriate one for you.
  6. After you are sure you have everything you want from the laptop saved, click Yes.
  7. When the Toshiba Recovery Wizard opens, the default and recommended option is "Recovery of Factory Default Software".
  8. After selecting your desired recovery method, select Next.
  9. On the next screen you may have recovery method options. The default and recommended method is to Recover to Out of Box state.
  10. Select next to continue.
Oct 18, 2014 | Computers & Internet
How to reset Toshiba A215 to factory defaults
You may follow the below steps to restore your Toshiba A215 laptop to its factory defaults:
Turn the Toshiba Satellite A215 computer off.
  • Press and hold the "0" key. Turn the computer on.
  • Release the "0" key when the Toshiba Recovery Wizard screen appears.
  • Click to select "Recovery of Factory Default Software" and then click "Next."
  • Click to select "Recover to out-of-box-state" and then click "Next."
  • Click "Next" on the confirmation screen to begin the recovery process.
  • Press any key on the keyboard to restart the computer when prompted. The computer boots up to the Windows setup screen.
  • Hope this helps..
  • May 20, 2014 | Dell Inspiron Mini 10 Notebook
    What is the Toshiba Laptop L305D-S5881 Hidden partition?
    If your laptop has a recovery partition (hidden partition) then you can -
    Restore Toshiba to Out of the Box Condition
    If your model Toshiba laptop has a Restore partition on thehard drive then follow these steps to restore your Toshiba to the Out of theBox condition.
    1. Press and hold the 0 (zero) key and at the same time, tap the power buttononce to switch on
    your notebook.
    2. When the machine Starts beeping; release the 0 key.
    3. When prompted by the warning screen; select Yes to continue with the systemrecovery.
    4. Select Recovery of Factory Default Software; click Next.
    5. Select Recover to out-of-box state. 6. Click Next again.
    7. Click Next to Start recovery.
    8. Restart the Toshiba laptop when there restoration process finishes running.Follow the prompts that appear on the screen to set up the laptop's date, timeand language settings.
    Jun 29, 2012 | Toshiba Satellite L305D-S5881 Notebook
    Need to do a system restore
    You can try by going to help by the start buttton and searching on restore/recovery and doing so. Or you can go to start, control panel and looking to see if there is a restore\recovery icon. Lastly you would have to reinstall your operating system by putting in the cd and rebooting after pressing F2 and selecting boot from CD. This WILL cause all user data to be lost so if you need it, it must be backed up first.
    Sep 07, 2011 | Toshiba Satellite L305D-S5923...
    I want to reset it
    @lslchrisorei
    Toshiba laptops have a built-in recovery mode on the system wherein you don't need to use a disc to restore it to factory default (if that's what you mean by "I want to reset it". The hotkey for the recovery is the 0 key (don't use the key on the numpad). To activate it, you need to turn the computer off, then you need to hold the 0 key then turn the computer back ON. If you hear a continuous beep, you can let go of the key and It will then say "Windows is loading files" and will proceed with System Recovery. If this doesn't work, that means that this computer doesn't have the hidden partition for you to restore the unit to factory defaults (either it's faulty or it's not there) and you need to order the recovery discs from Toshiba at 1-800-457-7777 (for US) and for Canada, it's 1-800-663-0378.
    If you're still under warranty, they'll give it to you for free.
    Cheers
    Sep 05, 2011 | Toshiba Satellite L305D-S5874 Laptop
    How to go back to factory settings
    All data will be erased on your hard drive if you proceed. Make sure that the power wont be interrupted during this process. Do not switch off or restart your computer either.
    -Shut the computer down completely
    -hold the 0 (zero) key down and at the same time press the power on button release the power when the machine turns on
    -when the computer starts beeping release the 0 key
    -when the prompt comes up choose YES to continue with system recovery
    -Select recover of factory default software and click NEXT
    -Click Next again to start recovery
    Hope this helps!
    Apr 14, 2011 | Toshiba Satellite Pro L300 Notebook
    I am trying to reset my toshibe m45 s165 to its factory settings, but when i try the whole press "0" and power at the same time, the laptop keeps turning off since im holding the power button,...
    Do not hold the power button down while pressing the "0" key - it'll shut the computer off again. You just need to push it once to turn the power on and then hold the "0" key immediately after you push the power button on - just like turning on the laptop, but this time you're holding the "0" key down.
    Feb 05, 2011 | Toshiba Satellite M45-S165 Notebook
    How do i set back to factory default for toshiba l300
    yes actually this conficker april fool virus have struck thousands of systems
    pls try to restore it from the Os partition like this
    Toshiba: BEFORE TURNING ON THE LAPTOP, press and hold the 0 (zero) button on the keyboard, then turn on the computer while holding the 0 (zero) button down. When the Toshiba logo screen appears, you can release the 0 key.
    if u successfully restore ur Os like this otherwise let me know
    Apr 08, 2009 | Toshiba Satellite Pro L300 Notebook
    I have to use my windows xp disk to boot my laptop tried everything to fix it
    pls try to repair ur system thru ur backup OS disk which u r using to boot so u see ur desktop or u see only recovery console like thing u can always restore ur system to factory default but first try to repair it thru backup disk see if it works other wise let me know abt it
    fast way to restore to factory settings
    pls rate me FIXYA for this if u like
    Mar 13, 2009 | Toshiba Satellite A10-S169 Notebook
    Computers & Internet Logo
    448 people viewed this question
    David Payne
    David Payne
