Home | Hitachi | 50UX57B 50 in. Rear Projection Television | Convergence
Hitachi 50UX57B 50 in. Rear Projection Television
Problem for Hitachi 50UX57B 50 in. Rear Projection Television
Convergence
By greenerook on Jun 17, 2009
convergence
Solution #1
posted on Jun 20, 2009
Somewhat Helpful)
Ecollier2012
Rank: Guru  Hitachi Expert
Rating: 93%, 526 votes
Your TV most likely a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Was this helpful?
Yes
No
Solution #2
posted on Jun 18, 2009
Somewhat Helpful)
Skyassoc
Rank: Guru  Hitachi Televisions & Videos  Expert
Rating: 90%, 255 votes
If it is out of convergence, replace the concergence IC's. The are probly
STK392-110's, STK392-120's, or STK392-150's. Which ever they are, replace them both. Also look for burnt resisters near the heat sinks and Sub Yoke connectors.
Hope this helps,
Skyassoc
Was this helpful?
Yes
No
Popular Solutions for Hitachi 50UX57B 50 in. Rear
Questions and Unsolved Problems for Hitachi 50UX57B 50 in. Rear
Do you recommend Hitachi 50UX57B 50 in. Rear Projection Television?
Answer
Answer
we have a hitachi 50ux14b and when i went to turn it on the tv turns on but i get no sound or... (More)
Answer
mine is an ultra vision 50ux18b it worked fine until i moved
Answer
From the top I have a horizontal white line that runs accross the top of the screen and distorts the... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Hitachi 50UX57B 50 in. Rear...:
Top Projection Television Experts
Rank: Guru Guru
Solutions: 1494
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Projection Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
