Question about Poulan Ght225 25cc Gas Hedge Trimmer
Ght225 Weedeater hedge trimmer
I have replaced the spark plug and cleaned the air filter but it will not start. I could not see a spark when I crank the engine. Maybe the ignition module????
  • 59 Answers
Try sanding the fly wheel and the coil to get the rust off
Posted on Jun 19, 2009
  • blessed45 May 25, 2012
    cleand flywheel
    New Friend:
    Problem Solver:
  • 11 Answers
Not uncommon for ignition module to fail, but before ordering one, check flywheel for its magnetic field. Use some steel material to test for field strength. Coil too is an option but typically they are pretty reliable.
Posted on May 19, 2013
I recently had my Choke lever replaced on my Poulan Hedge trimmer, (model GHT 225.) Now the fuel doesn't pump into the fuel line. Any thoughts?
Much thanks,
Patti Butler,
Boonesboro, MD
Posted on May 26, 2010
Which fuel line has the filter , top or bottom ??
the line that goes directly to the carb has the filter inside the tank,the other goes to your primer
Jul 24, 2015 | Weedeater Weed Eater Ght225 22-inch 25cc...
My 10 year old weedeater hedge trimmer ran fine last year when I put it away for the season. When I tried to start it this year it wouldn't even fire. I put fresh fuel mix in and a new spark plug and...
I would check for spark and check the fuel lines, especially if fuel is left in it. Also if fuel left in you will have to empty the lines and carburetor or pull it enough to clear. Another thing to consider is that if fuel was left in it that the carburetor may need a rebuild, replacing the diaphrams.
I hope this is helpful for you.
Aug 19, 2011 | Weedeater 19 in 25cc Gas Hedge Trimmer
Hard to start and will only run on choke or partial choke
The problem is probably due to a fuel flow problem or clogged air filter, but could be caused by the insulation of the spark plug breaking down when it gets hot. Try changing the plug and if this doesn't work have a look at these tips:
http://www.fixya.com/support/r9230929-weed_eater_strimmer_will_not_start
Hope this helps!
May 27, 2011 | Poulan WeedEater Hedge Trimmer 25cc Engine
WHAT IS THE OIL AND GAS MIXTURE RATIO FOR THE POULAN PRO WEED EATER. I HAVE A NEW MACHINE AND IT WILL NOT START AFTER ONLY ONE DAYS USE. WHEN IT DID START IT KEPT CUTTING OFF EVERY TIME YOU PRESS THE...
Gas / oil should be in ratio 50 / 1 and use two stroke oil for strimmers or chainsaws.
Firstly check the high-tension lead to the spark plug isn't loose. Remove the spark plug and place the body of the plug against the engine so that it is grounded. Check there is a spark when the engine is cranked. If no spark, there may be a short circuit or crack in the white insulation part of the plug so temporarily try another plug to see if you get a spark. Don't actually use this in the engine unless it's the same time type as it may result in engine damage if it's too long. If this still doesn't work, there may be a problem with the cut off switch, which cuts the engine when the safety handle is released, if this is the case it may be necessary to strip the cowl off the top of the engine to trace the wire and switch.
The fuel lines may have become airlocked.This can happen if the tank is run dry. If the weedeater has a primer bulb, alternatively press it several times and then try to pull start the engine with choke on. Repeat this several times. The primer bulb should feel spongy and fill with fuel.
If you're up to it, you can dismantle the carburettor and clean any dirt from valves.The carburettors on chainsaws, hedge cutters, strimmers etc are very fiddly with delicate diaphragms, valves and springs so you have to be careful to avoid damage or loosing parts.
Ensure air filter is clean. Foam elements can be washed with hot water and detergent and squeezed dry in a cloth. Paper elements can be cleaned with compressed air blown from the inside of the filter but ideally should be replaced.
Check fuel lines aren't kinked or blocked restricting fuel flow.
Ensure fuel filter isn't dirty. This is probably located at the end of the fuel line in the tank.
Check the throttle cable is actuating the throttle plate in the carburettor.
Check whether there is a vent on the tank or on fuel cap. There is usually a valve on this to allow air into tank to replace fuel as it leaves for the carburettor. Ensure this isn't blocked.
May 02, 2011 | Poulan WeedEater Hedge Trimmer 25cc Engine
Craftsman hedge trimmer won't start.
Have you changed the H T lead and then check the cut of swicth for faulty wireing
Jul 19, 2010 | Craftsman 22" Gas Hedge Trimmer
Trimmer starts and runs for 15 seconds and stops. won't start for a few minutes and does the same ,
Check the air filter, replace the fuel if it is last year's, clean the spark plug or replace. Also lube the blade. Good luck...Lee
Jul 14, 2010 | Craftsman 22" Gas Hedge Trimmer
I have a Poulan WeedEater. It had trouble
CHECK THE SCREEN ON OUTPUT OF THE MUFFLER. ITS CALLED A SPARK ARRESTOR, THESE GET OIL FOULED AND MAKE EM A BEAR TO RUN . CLEAN IT UP AND SHE WILL RUN LIKE A CHAMP, THE CARB MIGHT NEED REBUILDING ,FUEL FILTER AND A SPARK PLUG IS THE FIRST THING TO REPLACE .. IF'N I WAS ANY HELP VOTE FOR ME ...THANKS.. JAY
May 24, 2010 | Poulan WeedEater Hedge Trimmer 25cc Engine
Carburater fuel mixture settings on weedeater gth22 hedge trimmer
your best bet is to buy one small bottle of poulan oil, which will be added to one gallon of gas.
Sep 12, 2009 | Poulan Ght225 25cc Gas Hedge Trimmer
Does anyone know where I can dwonload a users manuel for a Weedeater hedge trimmer model ght225
Hi!
Yepp, i can help you! There are 5 diferent ones of that GT225
I dont know witch one you have so i'l give all five here:
HEDGETRIMMERWEEDEATER --> GHT225 ( 952711803 )
Manual: View
Parts Manual: View
HEDGETRIMMERWEEDEATER --> GHT225 LE ( 952711803 )
Manual: View
Parts Manual: View
Manual: View
Parts Manual: View
Manual: NO MANUAL AVALIBLE
PArt Manual: View
Manual: View
Parts Manual: View
Or you can go to this site and type GT225 in the search window:
http://www.poulanpro.com/poulanpro/manualSearchPrepare.do
Good luck
Nic
Apr 21, 2009 | Poulan WeedEater Hedge Trimmer 25cc Engine
Poulan Ght225 25cc Gas Hedge Trimmer Logo
1,362 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
roeb
Are you a Poulan Garden Expert? Answer questions, earn points and help others
