Question about Hitachi CP-S210 Multimedia Projector
Hitachi cp-x430? How do i reset the thing to factory defaults? I have a green hue on it that I cant seem to adjust. Thanks
Re: hitachi cp-x430?
Its easy...check for a 'lighter', and light your projector....while your projector is on fire just project ok...good!
Posted on Oct 03, 2008
    Problem Solver:
  • 5 Answers
My projector is not Hitachi but I had a similar problem. My manual suggested checking under "signal" to make sure that "auto" was "on". The thing is, there were two places where "signal" came up on the menu. I had to go under "set-up" to "signal" and then I was able to correct it by setting "auto" to "on". I hope this helps.
Posted on Jan 06, 2008
0 characters
3 Points
Hitachi CP-X1250 MULTIMEDIA PROJECTOR - MENU> MAIN> BRIGHT and CONTRAST are not active. BRIGHT and CONTRAST How to enable? I can not make adjustment.
Go to menu and then select main. then select reset and execute it.After that try to adjust the brightness and contrast.
Remember on thing, in some projectors the brightens and contrast will be active when there is video signal. also try that.
Jan 26, 2011 | Hitachi CP-X1250 Multimedia Projector
Why is the screen a green hue when the projector is on?
because the projector bulb needs replaced i have one of these myself but its £230 pounds to replace
Jan 19, 2011 | Hitachi CP-S317 Multimedia Projector
Hitachi cp-x251 lcd projector cannot adjust the tint.
reset the settings to factory default. make sure that if you are using the computer that you are on vga, not composite. if it doesn't get any better, check the lamp for bulges, black spots, or fogging; replace if necessary. if all that is ok, you may have fried polarizer filters on one or more of the lcd panels due to excessive dust and heat. if that is the case, you'll need to replace the entire optical engine.
Dec 09, 2009 | Hitachi Multimedia Projectors
My hitachi cp-s235 projector has a blueish hue on the left side. how do i fix it, it is a brand new bulb
i think it is mothing to do with the bulb it is the stup of the 3 color frame inside ,or iternal dirt ....need profesional store ....
Aug 30, 2009 | Hitachi CP-S235 Multimedia Projector
Seeing a blue "haze" on presentations, and when on blank screen
On the "Option" menu, try selecting "Service" and the "Factory Reset". This may help. If not, you will have to use the menus to manually adjust the level of blue in the projectin. Go here for the manual for your Hitachi and you will find instructions:
Feb 26, 2009 | Hitachi CP-X445 Multimedia Projector
Hitachi CP-x430 "Check air flow"
I have run in to this time and time again. This is why I like to keep things clean. take the bulb out and blow the unit out with air and make sure you wipe off what you can with Q-tips The blub allows air to flow thew the filament so what ever dust that might touch the fillament while its burning will burn at a higher temp. this will send and indication to the unit to send a message that says replace bulb soon and If there is not enough air flow it will say CHeck air flow take the fliter out and clean it with water dont replace it. IF you do just buy a carbon pad and cover the hole(not recomended foir those who are not handy) but keep things clean and it will save you $ in the long run. How many bulbs do you want to buy?
Dec 20, 2008 | Hitachi CP-X430 Multimedia Projector
Hitachi CP-SX5600W colour gun problem
Yes it is if it is same modell on the projectors
Dec 04, 2008 | Hitachi CP-SX5600W Multimedia Projector
Hitachi CP-S210 Multimedia Projector Logo
383 people viewed this question
Top Hitachi Multimedia Projectors Experts
Electro Med Services...
Are you a Hitachi Multimedia Projector Expert? Answer questions, earn points and help others
