Question about Philips 47PFL7403D 47 in. LCD TV
Not repond The remote control
The TV does not respond to the remote control. I press the green button and it does not advance the auto programming. This is a new tv. This is the first time I power up thanks jaime Aude
    Scholar:
  • 70 Answers
Hi, Unfortunatly, Philips had a design flaw from the manufacturer. You will need to have it serviced by a technician,but the replacement part is called an I.R. Board. It should only cost about 2 or 3 dollars,but the labor is the main cost of the repair,which you have a warranty for.
Posted on Jun 18, 2009
Program code for Directtv Universal remote.
You can see an easy step-by-step guide to programming your remote right on your TV screen:
sm_cl_blu__number1_icon.pngPress MENU on your remote control sm_cl_blu__number2_icon.pngSelect Settings & Help sm_cl_blu__number3_icon.pngSelect Settings sm_cl_blu__number4_icon.pngSelect Remote Control sm_cl_blu__number5_icon.pngSelect Program Remote and follow the on-screen prompts img_remote_control_tv_sol1.jpg You can also use the manual method below: sm_cl_blu__number1_icon.pngMake sure your TV and your receiver are both on. sm_cl_blu__number2_icon.pngUse this tool to look up the 5-digit code for your TV. There could be more than one code for your brand of TV. sm_cl_blu__number3_icon.pngSlide the MODE switch on your remote control to the TV position. sm_cl_blu__number4_icon.pngPress and hold the MUTE and SELECT buttons at the same time until the green light at the top of your remote flashes twice, then release both buttons. sm_cl_blu__number5_icon.pngUsing the number buttons, enter the 5 digit code for your brand of TV. The green light under the TV should flash twice. sm_cl_blu__number6_icon.pngAim the remote at your TV and press the VOLUME UP button. If the volume doesn't increase, repeat Steps 3-5, trying a different 5-digit code for your TV. If your remote control fails to program using all available codes, try scanning for additional codes. If one of the codes worked, proceed to the next step. sm_cl_blu__number7_icon.pngPress and hold MUTE and SELECT buttons until the green light at the top of your remote control flashes twice. sm_cl_blu__number8_icon.pngEnter 9-6-0 using the keypad on the remote control. The green light should flash twice again. sm_cl_blu__number9_icon.pngSlide the MODE switch on your remote control to the DIRECTV position. img_remote_control_tv_sol2.jpg Follow these steps to scan for additional TV codes using your DIRECTV remote: sm_cl_blu__number1_icon.pngSlide the MODE switch on your remote control all the way to the right to the TV position. sm_cl_blu__number2_icon.pngPress and hold the MUTE and SELECT buttons at the same time until the green light at the top of your remote flashes twice, then release both buttons. sm_cl_blu__number3_icon.pngUsing the number buttons, enter 9-9-1. The green light on your remote should flash twice. sm_cl_blu__number4_icon.pngAim the remote at your TV and press CHAN/PAGE UP button. Tap the CHAN/PAGE UP button repeatedly until the TV powers off. sm_cl_blu__number5_icon.pngWhen the TV powers off, press and release the SELECT button. Note: If the green light flashes three times before your TV responds, then all codes have been cycled through. Our remote controls are guaranteed to program to your DIRECTV receiver, but your TV may not be compatible with our remote control.
Jul 08, 2014 | GE JASRM24912 Remote Control
How to program Direct TV remote
How to program your DIRECTV remote control:
Press MENU on remote.
Select "Parental, Favs and Setup".
Select "System Setup".
Select "Remote".
Select "Program Remote".
While aiming remote at device, follow onscreen instructions to program remote to TV, DVD, or other device.
How to program the white DIRECTV remote to your TV
Look up the control codes for your DIRECTV remote control.
Make sure your TV is turned on.
Slide the mode switch at top of remote to "TV".
Press and hold the MUTE button. This is located above the number 1 button.
While still holding down MUTE, press and hold the SELECT button until the green light at the top of the remote flashes twice.
Enter the first TV code you have. The green light on remote should flash twice.
Aim remote at TV and press PWR button once. The TV should power off.
Once the TV is able to power off/on and control the volume, slide the mode switch at the top of the remote back to the left (DIRECTV). Your remote is now programmed.
If the TV does not power off, repeat steps 4, 5, 6, and 7, using the next code for your TV brand.
If remote control fails to program using all available codes, try scanning for the code.
How to scan for TV codes on your DIRECTV remote
While still holding down MUTE, press and hold the SELECT button until green light at the top of the remote flashes twice.
Then enter 9911, the green light on remote should flash twice.
Point remote at TV and press CHANNEL UP button. Tap the CHANNEL UP button repeatedly until the TV powers off.
Note: If the green light flashes three times before TV responds, then all codes have been cycled through. Our remote controls are guaranteed to program to your DIRECTV receiver, however your TV may not be compatible with our remote control.
You can find more help in the Remote Controls section of our Technical Forums at forums.directv.com. You can also use our Interactive User Guide to learn the ins and outs of your remote control.
Apr 11, 2012 | Audio Players & Recorders
Can set up th remote control for this tv with the direct tv cable remote
Here's how to scan for TV codes on your DIRECTV remote
1.Make sure your TV is turned on.
2.Slide the mode switch at top of remote to "TV".
3.Press and hold the MUTE button. This is located above the number 1 button.
4.While still holding down MUTE, press and hold the SELECT button until green light at the top of the remote flashes twice.
5.Then enter 991, the green light on remote should flash twice.
5b. Press 1 again (it will flash twice again), then you press the power on button at the very top right.
6.Point remote at TV and press CHANNEL UP button. Tap the CHANNEL UP button repeatedly until the TV powers off.
*If you hit channel up very fast, you risk going past the code. Pressing channel down will back it up. I alway hit channel up very fast till the tv turns off, then back it up slowly till it comes back on.
7.When the TV powers off, press and release the SELECT button.
*Note: If the green light flashes three times before TV responds, then all codes have been cycled through. Our remote controls are guaranteed to program to your DIRECTV receiver, however your TV may not be compatible with our remote control.
Mar 05, 2011 | Curtis LCD2425A TV
Cant program my rca remote for my LG tv don't have code
Hi! You try using these steps for you to program your remote control to your TV.
1. Manually turn ON your TV.
2. Press and "HOLD" CODE SEARCH
3. Press and release the TV button
4. Release CODE SEARCH.
5. Press OFF/ON repeatedly until the TV turns off (you may have to press up to 100 times at a rate of once per second).
6. Once the TV turns off, press and release ENTER.
7. With the TV on, press any other button. If the TV responds, no further programming is required. If the device does not respond, repeat steps 1-6.
I hope this helps.
Jul 13, 2010 | RCA Universal Remote Control
Need rca crk17sa users guide for codes for Magnavox TV
Ok it took me a while. Go to this link to find the codes for you remote: 10054 is the most used code for Magnavox. I hope this helps you out. Good Luck!!!!!!!
http://www.directv.com/DTVAPP/content/remote_codes
Here's how to program your DIRECTV remote control:
  1. Press MENU on remote.
  2. Select "Parental, Favs and Setup"
  3. Select "System Setup"
  4. Select "Remote"
  5. Select "Program Remote"
  1. Look up the control codes for your DIRECTV remote control.
  2. Make sure your TV is turned on.
  3. Slide the mode switch at top of remote to "TV".
  4. Press and hold the MUTE button. This is located above the number 1 button.
  5. While still holding down MUTE, press and hold the SELECT button until the green light at the top of the remote flashes twice.
  6. Enter the first TV code you have. The green light on remote should flash twice.
  7. Aim remote at TV and press PWR button once. The TV should power off.
  8. Once the TV is able to power off/on and control the volume, slide the mode switch at the top of the remote back to the left (DIRECTV). Your remote is now programmed.
If the TV does not power off, repeat steps 4, 5, 6 and 7, using the next code for your TV brand.
  1. Make sure your TV is turned on.
  2. Slide the mode switch at top of remote to "TV".
  3. Press and hold the MUTE button. This is located above the number 1 button.
  4. While still holding down MUTE, press and hold the SELECT button until green light at the top of the remote flashes twice.
  5. Then enter 991, the green light on remote should flash twice.
  6. Point remote at TV and press CHANNEL UP button. Tap the CHANNEL UP button repeatedly until the TV powers off.
  7. When the TV powers off, press and release the SELECT button.
Mar 08, 2010 | Televison & Video
How do i program my remote control rcu703sp and my
Programming a Device using Code Search:
1.
2.Manually turn ON your device (TV, VCR, Cable Box)
3.Press and "HOLD" CODE SEARCH
4.Press and release the device button you want to set up (TV, VCR, Cable Box) However, if you are using AUX for a device, press and release AUX first and then the device button for the type
of device to be programmed (TV, VCR, or Cable). The selected device button will flash once.
5.Release CODE SEARCH.
6.Press OFF/ON repeatedly until the device turns off (you may have to press up to 100 times at a rate of once per second).
7.Once the device turns off, press and release ENTER.
8.With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6.
Programming a device using the Code Lists:
1.
2.Find codes for each device and brand below.
3.Press and "HOLD" CODE SEARCH.
4.Press and release the TV, VCR or Cable button you want to set up. If programming AUX for a device, press and release AUX first and then the device to be programmed (TV, VCR or Cable).
When the selected device button flashes proceed to the next step.
5.Enter the three digit code from the TV, VCR or Cable Box code lists.
6.Release CODE SEARCH.
7.With the device on, press another button, for example CHANNEL UP. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-5 using
another code number from the lists.
Mar 16, 2009 | RCA Universal Remote Control
Correct code for Magnavox TV modelMMC24T5A not on code list
If code is not on list do auto search for the code.
Automatic Programming
With automatic programming, the remote control tests all the codes available
on the Code List and assigns the correct code for the selected device.
Although this method can be more time-consuming, it eliminates the need to
look up codes and enter them manually.
1. T urn off the device with which you want to use the remote control.
2. Press and hold the corresponding button on the remote control
(TV, VCR, SAT, DVD, CAB or AUD) until POWER INDICATOR illuminates. The
remote control is in programming mode.
3. Press and release . The POWER INDICATOR flashes once and stays on
indicating the unit is in Power Scan mode.
4. Press CHANNEL + or CHANNEL - repeatedly until the device turns on.
5. When the device turns on, press OK to store the code.
Note:
• To exit without storing the code, press BACK.
• The unit will search for the next code or the previous code if you press
CHANNEL + or CHANNEL - after the device turns on.
6. Press any other button. If the device responds, the remote control has been
programmed. If the device does not respond, repeat steps 2-5.
Good Luck and Please Rate FixYa!
Dec 27, 2008 | Brookstone 538744 Remote Control
TV not reponding to remote
Remote IR LED receiver defective located on front edge of PC board.......I will get the part # for you........................T.
Feb 27, 2008 | Televison & Video
The TV does not respond to the remote control nor the buttons in the front panel
Sounds like power supply switch needs to be changed to normal setting. If you are comfortable with electronics i will talk you through it if not you will need a tech or back to cosco it goes if you have a warranty.
Oct 10, 2007 | Maxent MX-50X1 50 in. Plasma Television
Problem with channel changing
You must program the tv. Go into the MENU and find AUTO PROGRAM. Then program it and it should work.
Sep 11, 2007 | Sharp 27K-S100 TV
Philips 47PFL7403D 47 in. LCD TV Logo
389 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
