Question about Logitech Z-5300 Computer Speakers
My three front speakers stoped working
My hole system was working fine, i was running a metronome program and all the speakers were working fine, i went into my sound managment program that tests the speakers to make sure if there running by making each speaker put out a short sound. i did this wile the metronome was running, i tested the speaker and then a window poped up that said something about the midi. now my three front speakers wont work they are on and make sound when windows starts but thats the only time, and non of the speakers will work when i run a music program.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 198 Answers
Ob
viously something reset itself. Do a systerm restore back to a date when everything was working--that should fix you up simplest.
Posted on Mar 10, 2008
I have a RMP-5 Rhythm Coach. I cannot get any sound from the pad when I practice. Help
Hi, after doing a bit of googling it occurs to me that the internal speaker is ONLY for the metronome / click & not for the drum sounds themselves. You will need headphones or some external audio gear like your hi-fi system or oth r amp & speaker. I found this "The pad has 54 sounds in it (covering all parts of the drum kit but mostly snares), which are triggered when you hit the mesh head, but these can only be heard over headphones. The built in speaker is only used by the metronome sound (when there are no headphones attached) and then it only has a beep sound attached to it. However, plug in headphones and you get a variety of available click sounds including a proper ticking clockwork metronome." Hope that helps a little? Good Luck :-)
Dec 07, 2014 | Roland RMP-5 Rhythm Coach
How to turn off Quik time metronome
It doesn't turn off. You simply mute the speaker by pressing the sound button. http://www.qwiktunetuners.com/download/QT5%20Instr.pdf
Dec 23, 2013 | Qwik Time QT5 Metronome
OmniS10 does not work
Mine has issue with the sub input that runs from the receiver sub output. So I don't have the LFE effect. I have to use the secondary hookup which is:
-run your front speaker wires from the receiver into the input. Then run wires out back to your front speakers.
Is your completely dead period? Or is the light coming on? If its dead, it may be a fuse or the power supply has failed....if the light comes on. Try the secondary hookup. Make sure both your reciever and the sub are unplugged. Plug them back in after you have hooked everything up..
Feb 08, 2013 | Mirage OMNI S10 Speaker
No sound from subwoofer, i have a JBL subwoofer the side or small speakers will play but the woofer will not i ran a sound check and it was stated that all speakers was working fine. could it be that my...
Are you using the Creative speaker test program? It usually has a picture of a generic layout of a pc system, with the speakers around it, showing a speaker for each that you should have plugged in. There should be a test button that will play a sound through each speaker. If a sound plays from your center speaker when the subwoofer picture is lit up then you may have a cord plugged in incorrectly on either the subwoofer or on the back of the soundcard. I've ran into this many times.
The best way to set up surround sound is to get your speakers placed or mounted on the wall, then run one wire at a time into the subwoofer, to ensure that the front left is hooked into the subwoofer in the front left, front right into front right, etc. Then once the speakers are hooked into the subwoofer start running the outputs from the subwooofer one at a time into the sound card. After each connection run the test program and watch the pictures light up as the sound plays, and make sure that the speaker playing sound in your place is the same speaker that is lit up on the test program.
I hope that helps, otherwise the amp is probably bad. Let me know if you need more help.
Apr 30, 2010 | Creative Labs Gigaworks S750 Computer...
I have a denon avr 2308. The sound stoped working
when using an hdmi input, make sure the "input mode" is in 'hdmi' or 'auto'. i am sure you can remedy your issues with a trip through the setup menu. it very extensive. good luck
Feb 10, 2010 | Denon AVR-2308CI
I am unable to get all of the speakers to work. I
Depending on the source, you typically only hear program material from the three front most of the time. Ensure that you are using surround encoded source material or try changing surround modes.
Aug 11, 2009 | Supersonic SC-36HT System
Bose Lifestyle 20 system. sound from only two speaker
A lifestyle 20 system is stereo only. Two channels. Left and right.
Jun 04, 2009 | Bose Lifestyle 20 System
Connect Creative 5.1 A500 speaker system to Phillips DVD 3256
Just buy two connectors(shown above). Its having two holes upside.
1. Connect the connector to one hole of the other.
2. Connect the audio cable to the dvd.
3. Then connect the connectors to the other side of the audio cable.
4. Lastly, connect the three stereo output cables of the Creative speakers to the three holes of the connector simultaneously.
I have tried this at home with my Creative Inspire M5300 speakers and philips dvd. All the five speakers are working.
Rovan C
Jan 29, 2009 | Creative Labs Sound Blaster Live! 5.1...
Recording do not sync up
1rst- Maybe you choose the incorrect metronome. On analog audio record use your default audio card metronome and on MIDI audio record, use MIDI metronome!
2nd- Check your memory video card & remember your computer speed is as fast as the lowest speed component on it.
Pardon my poor English!!!!
Good luck!!!
Jan 19, 2009 | Magix Music Studio 2005 Deluxe for PC
No sound, subwoofer or speakers
Er so you plug the speakers into anther system and they work? Blindingly obvious but there is no fault with the speakers.
Oct 06, 2007 | Panasonic SC-HT730 System
Logitech Z-5300 Computer Speakers Logo
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Jerry Umali
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
