Question about Mitsubishi WS-55511 55" Rear Projection Television
Please send capacitor replacement info
Techman, Could you send me the info on reolacing the caps?
  • 4,402 Answers
Know problem of bad caps.
replace DM
Picture of bad caps
The DM board is the one with the digital connectors on the back panel. If you already have it appart, you may as well check the caps on all of the boards. The caps that go bad are typically Jamicon brand caps in 1000 uF and 330 uF values. There are also a couple of 3300 uF caps in the PS that cause problems.
Posted on Jan 08, 2008
Looking For Replacement Display Bulbs......
the bulbs most likely not bad I have always had bad capacitors on the inverter board you should be able to see the capand wherethe bad one as the top will be deformed or/buldged replace all the deformed capacitors and see if that solves your problem you have,
May 16, 2010 | Uniden BC895XLT Base Scanner
Buzzing noise picture getting fuzzy
is a power supply problem, need to be replaced.
Feb 21, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Here is additional info requested, the hardest part is cracking open the monitor case. Prior to working on this you should check to be sure the capacitors are discharged. A good way to do this is to connect a 12V light bulb across the terminals and when it goes out the cap is dicharged. You can also have a look at this page ( )
Spec is:
Cap Xon, 1000 uf 10V, KF 105 deg C, P602 vent
(3) capacitors identified on the board as: C822, C823, C824
They are the 3 right above where the multi color wiring harness plugs into pwr supply board shown in lower right of pic.
John :).
Nov 21, 2008 | Computers & Internet
Blinking green light of death
You can get the V23 DM repair kit at the following link which has the replacement capacitors and the instalation instructions on Cd which has pictures of the repair. Its listed under the repair kit category.
Aug 26, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Hey techman
Mar 31, 2008 | Televison & Video
Horizontal line in top screen
could be vertical output IC or capacitors located close around the IC
Nov 27, 2007 | Zenith B25A24Z 25" TV
Mitsubishi WS-65513 65 in Perpetual Blinking Problem:
Replace four 1000mf/25v caps on DM module.....pix's at...
Nov 25, 2007 | Mitsubishi WS-65513 65" Rear Projection...
You will need the service manual to do this repair. I happen to have it, as this site was suppose to put in the pictures and things to explain that a lot of TV sets are still using this DM board, but they are building them differently. Just follow the directions in the service manual on how to remove the DM board and then follow the directions in the article on repairing the DM board. I will need your e-mail address to forward this service manual to you. Good Luck
Jul 07, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WS-55511 55" Rear Projection Television Logo
475 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
