Question about Philips Televison & Video
My Magnovox TV model RS1965B222, can only get internal channel 1 thru 69, can I get any more like from 1 thru 99 or is this it. Dish Satillite receivers required channel 73 or 74 i.e. as to chellel 3 or 4 Can anyone help
I bought a new TV
Posted on Jun 18, 2009
Will a 7yr old dish receiver work today on dish satillite
With an antenna that is pointed correctly to satellites 110 and 119, the receiver will function, but will not have access to paid channels without authorization from DISH (which you can get by calling 1-800-333-3474). You may have to run a check switch test after connecting to antenna by accessing the menu, system set-up, installation, check switch.
Jan 27, 2013 | DISH Network 311 DTV Receiver
I bought a new Sony ex4/40 tv and programmed my DISH Network remote control for it. Everything works fine when the all the lights are on in the room. Can't change the channels or go to the guide function...
Hello, the problem that you are having is fairly simple to solve. The tv is causing interference with the remote. It sounds like you're at TV1, and TV1 remote is an IR remote. You need to get a UHF remote, and that will stop the interference so that you can continue to enjoy your tv! You can e-mail me at becki.barned@dishnetwork.com if you have any questions or concerns.
Becki Barned
DISH Network Customer Service
Nov 03, 2010 | DISH Network IR Remote Control
Panasonic TX P50V10B Plasma TV
In order to get any of the Freesat channels, you need to connect a Satellite dish to your TV. If you have a Sky dish, you simply need to run an extra Cable from the LNB from the dish and connect to your socket on the back of your TV.
In order to get Freeview channels and Analogue channels, you need to connect a aerial to the back of the TV.
There is a menu option for the TV to start straight to the AV input (your Sky HD box). It is Menu > Setup > Other Settings > Power on Preference. Select 'AV' for your TV to start on Sky HD.
Also even if you have your TV to start on TV, when you turn on your Sky HD box, it should automatically switch to the Sky box.
Oct 28, 2009 | Panasonic Televison & Video
Dvd recorder to satillite
if your dish satellite has an extra A/V output or if your plasma tv has the outputs and the recorder has the same type input AUDIO/VIDEO jacks
Oct 11, 2008 | Televison & Video
Magnovox: model 37MF337B/37 My Magnovox TV changes channels and even turns on and off by itself... I believe its a defect, but want to ask if this is something that has been heard of or reported. please...
There arethree possibilities that cause this symptom.
1. The buttons on the TV are shorted and must be replaced.
2. The firmware must be upgraded.
3.The main bd is bad and must be replaced.
Nov 11, 2017 | Universal Remote Control DIRECTV Universal...
Record tv
The VCR will have to be on channel 60 as well in order to record a program. Hope this helps....accordianman
Apr 25, 2008 | Quasar VHQ400 VHS VCR
DISH dvr 625
Its most likely the secondary dish that is used for international programming. Your signal is probably low on that to begin with and during inclement weather goes out completely. A tech will go out at a cost to you and get that repaired.
Mar 19, 2008 | DISH Network DVR-625 DTV Receiver /...
Satillite
More info needed...
What exactly do you want to do?
Which satellite, which band, what receivers, pay or FTA? etc etc
Jan 08, 2008 | Audio Players & Recorders
Toshiba 32A50
I have the same problem but can't find any adjustment. Thought it was the satillite dish but, no. Network channels come in good but the others are almost impossible to hear. It isn't worth taking to a repair shop - what a waste!
Oct 26, 2007 | Toshiba 32A50 32" TV
Televison & Video Logo
59 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
