How to hook up my wireless router - Computers & Internet
  • 72 Answers
Like this:
modem----->WAN port on router
Turn on wireless switch on laptop and wait for Windows to popup message saying new wireless sources found---->click the balloon.
You should see the brand name of your router on the list at the top with an unlocked symbol next to it. Double click that router to connect, wait for successful connection message and begin surfing the internet.
Posted on Jun 17, 2009
Im trying to hook my desktop up to the wireless router so that me and my dad (both with laptops) will hook up wirelessly. I tried reseting Linksys Broadband Wireless G Router and made sure all of the...
Try: Clarify - the desktop is connected with an ether net cable? Is working? Install router software on desktop to manage router. Trying to connect desktop wirelessly? Wireless card installed? Radio activated? Network detected?
Dec 31, 2010 | Linksys BEFW11S4 Wireless-B Broadband...
How do i hook up a wireless router to a cable router
If you already have a cable router, then you don't want to use a wireless router. You will want to use a wireless access point instead.
The reason for this is that anything plugged-in to your cable router will not be able to access anything connected to the wireless router due to the NAT firewall in the wireless router.
If the wireless router has the option to make it a "Gateway", then that will fix this issue; otherwise, take the router back and buy a wireless access point instead.
As for how you hook up the wireless router to the cable router, you have to unplug the power cord of the cable router for about 15 minutes before hooking the Ethernet jack from it to the wireless router.
Once the 15 minutes have passed, you then can plug the Ethernet cable from the wireless router "WAN" port into an Ethernet port on the cable router and then plug-in the power cord of the cable router.
Once the cable router is finished syncing-up, the cable router should provide an IP address to the wireless router.
If you really have a cable modem instead of a cable router, then you won't have to put the wireless router into gateway mode.
Dec 30, 2010 | Linksys Wireless-G WRT54G Router
We moved and when everything was hooked up i cant get a connection from my linksys wireless router to my laptop
Ok - hook the power to the Linksys - then RESET - the folded out paper clip will work. Once RESET - hook it up to your ISP provided MODEM [ You must have this service to get on the web] now unplug the Modem provided by your ISP or provider - and unplug the router.
WAIT
15 seconds - then
hook up the MODEM from the provider - then hook up the router - then restart the laptop - if wired it will need to be plugged in - if wireless - run your 'search for a wireless signal and you should have it.
Thanks
Gary @ Fix Ya
Sep 06, 2010 | Linksys WRT160N Wireless Router
With the router hooked up getting on the internet is slow. hooked to cable one direct it's o.k.
Your Wireless speed is all down to the quality of the router and wireless card, and where you are in relation to the router.
Hooking up direct is always going to be faster.
You could experiment with the position of the router in the room.
Check your speeds wired and wireless, use www.speedtest.net.
You could buy a better antenna for the router
Aug 25, 2010 | Linksys WRT160N Wireless Router
What do i need to hook up wireless -g 2.4 ghz
I believe the laptop is wireless.
You will need to check the wireless settings of the router.
If your router is already set up and other computers are able to go online using the router then you don't need to change anything on router, you will need to connect to the network only.
Click here for step by step instructions
Mar 15, 2010 | Linksys Wireless-G Broadband Router
No internet signal from router in other ports
Hello, Under the wireless menu on router you must give a ssid name and enable and save to turn on wireless , hoe this helps?
Mar 21, 2009 | Linksys Wireless-G WRT54G Router
Hooking up a wireless router
read this guide:
http://www.microsoft.com/windowsxp/using/networking/setup/adhoc.mspx
http://resnet.uci.edu/routersetup.asp
http://www.microsoft.com/athome/moredone/wirelesssetup.mspx
Mar 20, 2009 | Belkin (F5D7230-4) Router (587009)
Want to hook laptop up to home computer via cable modem
You need a router or a wireless router to do that.
If your cable modem is wireless you can set directly via wireless network a connection with your laptop (the laptop also need a wireless card (if dont have any built in))
The connection must be done in this way
ISP ----->> Cable Modem ---->> Wireless Router o Router ----->> Computer ( 1, 2, or more)
Nov 19, 2008 | Computers & Internet
Belkin54g wireless router
its a belkin
its a static packet data router only so much info gets in before it can unload so it shuts down
get a streaming netgear router basically like a hooking direct to comp
May 25, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
How to hook up this printer wireless to my main computer
We cannot connect the pro l7680 printer wirelessly. Connect the printer to the router via ethernet cable and connect the desktop to the router wirelessly.
May 24, 2008 | HP Officejet Pro L7680 All-In-One Printer
Computers & Internet Logo
115 people viewed this question
Alun Cox
David Payne
David Payne
