Question about Jenn-Air 27 in. Electric Single Wall Oven with Multi-Mode Convection
Jenn-air w156, displays f1 fault code. how do i
Jenn-air w156, displays f1 fault code. how do i fix and reset it?
  • Marvin
    Marvin May 11, 2010
    suggest u try premium question option.
  • 6,784 Answers
This is a Defective touch pad or membrane
Replace touch pad or membrane (this problem is usually the touch pad)
Posted on Jun 23, 2009
    New Friend:
Part for the W156 Jenn-air is no longer available. One company
that I have found will repair your existing part. Contact:
Core Centric Customer Service
175 Wall Street ' Glendale Heights, IL 60139
Toll Free: 866-737-2244 ' Fax: 630-216-5060
Email: CustomerService@CoreCentricUSA.com
I am currently trying to decide if I even want to
have mine repaired or just replace the oven entirely. I have already replaced it twice so I am thinking that the repair cost could go pretty far on a new oven then I am not having to deal with this ever again. I thought early on that it seemed to go out after using the 'self-cleaning' function. Not the case this last time because I had not used the cleaning function.
Does anyone have the dimensions for this oven. I have misplaced my manual. I want the dimensions before I go shopping for a potential replacement?
Thanks,
Marcelle Lewis
Posted on Dec 17, 2015
  • Marcelle Lewis
    Marcelle Lewis Dec 17, 2015
    Link for manuals and parts list for the W156 Jenn-air ovens:
    http://shared.whirlpoolcorp.com/product_...
F1E1 error happened repeatedly, jenn air says cut
F1 - E1
EEPROM checksum error
1.
Disconnect power for at least 30 seconds.
2. Re-apply power and observe for
at least one minute.
3. If code re-appears, replace control board (also
called ERC or clock).
Note: Applies to all F1-E...
codes except F1-E3.
Read more: http://www.appliancepartspros.com/repairtips/repairtips_appliance+fault+codes.aspx#Jenn
Air Range / Stove / Oven Fault Codes#ixzz19GMNtS3r
Dec 24, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
What does F- mean on my jenn air expressions electric wall oven? If it means what I think, then this is the 4th failure in 10 years. This just can't be right!
Common fault codes:
Maytag / MAYCOR / Magic Chef / Jennair / Admiral
Oven Fault Codes
Display Condition Remedy
F0 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F1 Defective Touch Pad or Membrane Replace Touch Pad or Membrane
F2 Oven over heat defective Relay Board or (if present) or defective Sensor
F3 Oven Sensor Open Replace Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Hardware, safety circuits disagree Replace Clock
F6 Missing AC (power) signal Check for proper voltage (plug, breaker, etc.)
F7 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F8 A/D Warning Replace Clock
F9 Door Lock Warning Check door lock circuit or Replace Clock
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
May 22, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
Fault code F1 on a Jenn Air WM2780. Upper oven
Usually this is a problem with the control board. The board can be repaired at www.fixyourboard.com.
May 21, 2010 | Jenn-Air JJW8230D Electric Double Oven
What does F1 mean on my oven
F1 code for Jenn Air is related to the main electronic control board. If you can turn your breaker off for a few minutes then back on it may reset. If not you will most likely need a new control board. Depending on your model number and age there may be extended warranty on the parts, check with Jenn Air to be sure
Apr 24, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
How to fix F1 error code on jen aire oven
HI There
I have this code for you to read and this is helpful. Let me know how it goes.
F1 Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common problem. Refer to F1 test at the top of this page for more information.Thank you for writing to fix ya.
Best Regards Richard
Jan 05, 2010 | Jenn-Air JGW8130A Electric Single Oven
I had an F1 Code on my Jenn Air WW2780B Double Wall Oven, and turned both ovens on to heat up, which they did, and the F1 code never came back after that... so far. Could it be fixed?
Hi, This code is an indication of a fault that exist within the actual relay board. It is malfunctioning at this time, and should be replaced asap, if possible.This relay board is located inside the unit, mounted on the cooling fan shroud. Once replaced, the F1 code will be cleared automatically.
Relay board part number: Y04100261
Click here to view an exploded diagram of the cooling fan shroud, with relay board attached. The relay board is labeled number 9, and the shroud is labeled number 1
Oct 27, 2009 | Ovens
Beeping and displaying F1. Press stop and 30 seconds later it starts again.
too high temp F1 fault code its either the keypad, or the control board.if the thermostat or oven sensor is bad,it could have got the keypad or control board too hot, and caused the F1
Aug 30, 2009 | Jenn-Air 30 in. Pro-Style Electric Single...
F1 fault code on Jenn-Air jwg 8130
hi,
The F1 ErrorOn a number of ranges this can mean a number of things, the most common being a failed ERC(EOC, Clock assembly)or a faulty touchpad. Firstly if you are using a recent Maytag range it may pay to test the oven sensor as described above as this may cause an F1 error if faulty (may apply to some other ranges as well) this is not a common cause but is worth discounting. To check the ERC and touchpad
Disconnect the power
Gain access to the back of the ERC
Disconnect the ribbon cable that connects the ERC to the touchpad
Check nothing will short when power is reconnected
reconnect the power and switch on
Watch for F1 and listen for the beep
If you get the F1 and the beep this means the fault is with the ERC and it will need replacing
If after 30 mins you do not see the F1 error and hear the beep, replace the touchpad
or follow the link for more info:
http://www.appliancefactoryparts.com/applianceshvac/help-center/fault-codes/fault-codes-ranges.html#Admiral
thanks for your question.
Jan 03, 2009 | Jenn-Air JGW8130DD Gas Single Oven
Jenn-Air Wall Oven Model #WW30430P F5 Fault Code
I have the exact same problem with an F5 fault code. I also have a new clock assembly. RepairClinic.com said "Jenn Air fault code F5 = Hardware and watchdog circuits disagree / Replace clock assembly (also called the ERC)
Jenn Air Fault code for newer models F5 = Power to element relays disabled in cook mode
1. Intermittent oven temperature sensor or wire harness or,
2. Intermittent contact on power relay board"
This doesn't help since it is too technical. What should I do next?
Oct 19, 2008 | Jenn-Air WW30430P Stainless Steel Electric...
Jenn Air W131 F1 error code
This means that the Power to element relay energized during time of day display. You have a problem with the wiring harness and it is shorted or you need to change the power relay board (PRB). If it is a double oven, you need to change second oven board.
Jan 07, 2008 | Jenn-Air JJW8230D Electric Double Oven
Jenn-Air 27 in. Electric Single Wall Oven with Multi-Mode Convection Logo
899 people viewed this question
Top Jenn-Air Ovens Experts
Oloyede Monsuru
Craig Butler
Craig Butler
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
