Question about Whirlpool ET8CHEXSQ Dryer
My whirlpool washing machine wont turn on. I checked the fuse and the socket which are working perfectly well. It doessnt seem like there is any power in the machine.
  • 121 Answers
1) Check to see if your door switch is working
2) Check to see if your getting any power to your machine with another cycle
3) check to see if breaker isnt tripped
Posted on Jun 18, 2009
Duet washer console lights out
Check your socket on the wall with some other gadget to see if there is power there. Next check your plug, if it has a fuse that could be blown. Next take off the plug from the wall socket to check all wires; disconnect and re-connect one by one.
\helped?
Apr 09, 2013 | Whirlpool Washing Machines
No power in whirlpool washing machine
hi mine did somthing similar not sure what the part is called but it looks like a silver battery thing about 4 inches long about 2 inches around with a few wires comming out of it mine blew this and the house fuse couldent miss mine as it was black changed this and it was ok hope this helps ivan
Sep 25, 2012 | Whirlpool Washing Machines
Washer does not start, replaced lid switch, and timer still doesn't work. when parts mentioned were replace. washer did start and fill but then stopped.
Hello there and welcome to fixya
I am sorry to hear that you are having problems i will post some information on some more parts that need to be tested ok?
Washing machine is dead, wont start Obviously the first thing to check is that the socket is supplying power by plugging another appliance in such as a lamp. It is less likely to be the socket but you'd be daft not to check it out before calling an engineer as it does occasionally turn out to be a faulty wall socket. This is only necessary though if there are no led indicator lights lit up on your washer as any light that's on shows that the machine is getting a live and neutral supply from the socket.
The second thing to check is the fuse in the plug. Either put the fuse into something else and check the appliance still works or try another fuse that you know to be OK in the washer. Make sure you use a 13 amp fuse and never by-pass a fuse! If both of those are OK, then the most common cause for a washing machine that wont start is the door interlock, particularly if the mains lights on the washing machine has come on, but nothing works. However, the fault could also be in wiring to the door interlock or even the door catch not activating it properly, or the on off switch or the main control module. With some Indesit and Hotpoint washing machines even an open circuit heater or motor can cause the entire washing machine to stop working except the led lights.
You need to know what you are doing to trace this type of fault so if it isn't the wall socket or the plug you'd be better getting an engineer to trace it. Do not work on a live washing machine. Engineers should use a continuity test meter to trace faults with the washing machine unplugged and never test with a live washing machine.
Sep 24, 2011 | Maytag Washing Machines
Have a GE Select washing machine that won't start or operate ? Can you help ?
Hello there and than you for choosing fixya
Feb 06, 2011 | Washing Machines
Washing machine wont work at all
Mar 19, 2010 | Washing Machines
My Whirlpool stylemaster 907675 Washer wont spin.. The lid switch is fine.. Washes fine and all other cycles work.. just wont spin.
Hi, stylemaster washing machine won't spin on the top half. The bottom part spins perfect. the top doesn't seem connected. What
should I do ?
TIA
RJ
Jan 08, 2010 | Washing Machines
Make sure there's power getting to the washer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the washer, if this is the case, the wiring must be repaired or replaced.
Jun 17, 2009 | Whirlpool Washing Machines
Wont start
If your washer doesn't seem to work at all, check these:
No power
Lid switch
No power Check to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped?
Lid switch If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it.
Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
Mar 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool ET8CHEXSQ Dryer Logo
176 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
