Question about Refrigerators
Evaperator icing up. timer r/r 3 weeks ago for same reason by a refer tech. started icing again yesterday.
  • Refrigerators Master
  • 4,655 Answers
Then there are other reasons for the icing. The defrost heater is defective, defrost thermostat, loose connections to defrost heater or low on freon. If you have a multimeter or ohm meter we can check the electrical. Lack of freon shows as a few rows are freezing on the evaporator and the other rows show only moisture. Let me know, Thanks, Sea Breeze
Posted on Jun 17, 2009
I have a kenmore refrigeator with bottom freezer. #596628322200, made by Amana. I bought it used two weeks ago from a dealer. The top started getting too warm a few days ago. The Freezer was fine. I...
Hello, Thank You for using FixYa. I will be helping you today.The defrost timer is on bottom behind the front kick plate. Open freezer door remove lower grille or kick plate and you will see it.
Thank You and please rate my answer if it was helpful..
Jun 11, 2011 | Kenmore 65234 Bottom Freezer Refrigerator
What causes freezer to ice up and the refridgerator not get real cold, with all vents unblocked.
((((( In Lamens Terms ))))) The evaperator gets so cold it frosts up. This is caused because freon is compressed and shot out into the evaperator making it cold. There is a fan circulating the air over the evaperator to cool the air in the freezer. As this continues, so much frost can start to block the air flow. (( so what they did, is put a heater in there with a timer so it would defrost the evaperator every 8 to 10 hrs, so the air would keep flowing )) Now if the heater quits working then it will frost and creat a block of ice. The block of ice, blocks the air flow and the air quits getting colder. Also after time the compressor will over heat and shut down untill it cools or burns up.
Jan 12, 2010 | Refrigerators
I had a huge block of ice on the bottom of my freezer that I got rid of yesterday. Over night the ice started to form again. What could be wrong? The unit is only about 8 years old and we've already had...
This can be caused by the drain hole below freezer coil being blocked by ice. You MUST remove all ice in drain under freezer coil. Use turkey baster to squirt hot water into hole and use hairdryer to defrost. Possible defrost thermostat is defective. Unit never goes into defrost, ice forms on coil and in floor of freezer. After defrosting may work OK for a week or two but gradually gets warmer because ice is blocking ports where cool air gets to refrig. May also have water in refrig box. Can also be caused by defective defrost timer.
Aug 19, 2009 | Refrigerators
SAMSUNG RS263OSH SIDE BY SIDE REFRIGERATOR DEFROSTED
sounds like a bad timer in the defrost cycle.  Call a tech repairman
Mar 21, 2009 | Samsung RS2630SH Side by Side Refrigerator
My new Whirlpool Refrigerator the water and ice still stink
We have the same problem. Started 2 weeks after purchase. (6 months ago). Tech. replaced fliter, worked for another 2 weeks, then water & ice awful again. Tried to live w/ it - ordered another filter a week ago. Replaced & within 24 hrs. problem was back. Called Whirlpool. Said tech who came to my househad written in his report that tap water & fridge water tasted the same. A lie - he agreed w/ me that the water from fridge was bad, & replaced filter which had a musty odor. Whirlpool basically called me a liar but agreed to send another tech to check it out. I will never buy another Whirlpool product & plan to tak this problem as far as I need to in order to get satisfaction. This is ridiculous!
Dec 19, 2008 | Whirlpool Refrigerators
GE side by side not working
Defrost cycle not functioning. Could be defrost timer, timer motor, or defrost heater. I detailed this for someone else. see other solutions.
Nov 05, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Please help!!!
If not defrost, could be timer, or heater is not working for some reason. Bad time can cause lots. Compressor could run during defrost, heaters not working, and such. Doubt that the t'stat would be the fix. Could be having a defrost cycle that is too short. Repairing all 3 plus the cost of a tech could get very pricey.
Sep 30, 2008 | Freezers
Evaporator fan blade jams in ice buildup
check the defrost bimatal or defrost thermanstat it will be located on the evaperator suction line (large line) it should read continuity with the ref cold if it showes continuity then the defrost timer is the problem
Apr 13, 2008 | Refrigerators
GE TPX24BPBGBB fresh food section won't cool
Have you noticed any ice built up on the rear freezer wall? it is very likely that you have a defrost problem situation,IE: Heater,Defrost Thermostat,Defrost Timer any failure in these components will cause an icing problem and therefore you will not get sufficient air flow to the Food Compartment
Sep 20, 2007 | Refrigerators
Refrigerators Logo
71 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
