Question about Canon PIXMA MP160 All-In-One InkJet Printer
Paper will not feed into the printer - Canon PIXMA MP160 All-In-One InkJet Printer
    Problem Solver:
  • 24 Answers
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
ptttq13
Posted on Sep 05, 2009
  • Canon Master
  • 365 Answers
Look at where the paper loads and you should see a grey rubber roller about 1 inch in diameter.Try to print without paper and see if the wheel tries to grab paper.If it does take some cleaner ,isopropryl alcohol or swabs should do,and clean the roller rotating it by hand.
Posted on Jun 17, 2009
A sheet of paper had remain in the cylinder
  1. Remove the rear cleanout from the printer.
  2. Gently remove any jammed paper or bits of paper.
  3. Close the HP Paper Feed Cleaning Kit software on the computer.
  4. Load plain paper in the printer paper tray.
  5. Press the Power button to turn the printer off.
  6. Press the Power button to turn the printer on.
  7. Try printing again. If the printer still does not pick up paper or if a paper jam occurs again, service the printer.
Other solutions customers found helpful » HP Paper Feed Cleaning Kit -- Clean the Paper Feed Rollers with the HP Paper Feed Cleaning Kit in Windows XP and 2000 » HP Deskjet, Photosmart, and PSC All-in-Ones -- 'Out of Paper' Error Message and the Printer Does Not Pick Up or Feed Paper » HP PSC 1600 and 2350 All-in-One Series Printers -- 'Paper jam: Press OK to continue' Message Displays on the All-in-One
Dec 15, 2010 | HP PSC 1610 All-In-One InkJet Printer
PRINTER SAYS 'PAPER EMPTY/ LOAD PAPER' -- BUT SHELF IS FULL. WILL NOT PRINT/ FEED PAPER
IP4700 series has 2-way paper feeding. Please check you paper feeding from bottom cassette or rear auto feed!
Before perform the printing job, you may notice on your printer right side can select paper feed from rear or bottom.
Enjoy printing.
May 29, 2010 | Canon iP4700 InkJet Photo Printer
My printer won't feed paper. All of a sudden my printer quit feeding the paper - the error light comes on and states that there is no paper in the feeder - but there is paper in the feeder
Check the paper feed switch, you have a choice to feed paper from the back or the cassette under the paper exit. Either put paper in both or select the proper source by pressing the feed switch.
Dec 30, 2009 | Canon Pixma MP500 All-In-One InkJet...
Hp laserjet p3005dn tray1 manual feed problem
you can choose mp first in "paper handing" printer menu or print tray1 is A4 default in properties of printer software.
Jul 25, 2009 | HP LaserJet P3005n Printer
SAME PROBLEM LEXMARK X2350 STARTS FEED PAPER AND PRINTER HEAD MOVES AS PRINTING BUT WILL NOT FEED PAPER WHILE PRINTING? ARE THERE 2 FEEDERS IN THIS PRINTER? HOW TO FIX?
transfer roller that starts the paper and feed that feed the paper. have you had a paper jam and torn a piece of paper off inside the feed mech? i dont remember if this one feeds off the motor or a belt. either way you would have to disasemble the printer to determine where the problem lies. might be more econimical to replace the printer.
Jul 13, 2009 | Lexmark X2350 All-In-One InkJet Printer
Paper feed problem
Check all this-----
1.check the printer paper feed roller jam.
2.check the paper sensor, It is working or not.
3.check the paper tray(clean it)
4.service the printer, (If possible).
Goodluck
Mar 10, 2008 | HP Photosmart 3210 Printer
Paper feed rolls is rolling over the paper...how to get access to those rolls
  1. Feed the paper manually into the printer:
    1. Place a sheet of plain A4 paper in the paper feed tray.
    2. Move the paper support on the left-hand side to the left end of the paper.
    3. Press the paper feed button.
    4. If the paper does not feed, continue with step 2.
  2. Check for any obstructions in the paper feed path:
    1. Disconnect the cables from the back of the printer.
    2. Open the front of the printer and check for anything that may be blocking the paper path.
    3. Close the front lid and remove any paper from the paper feed tray.
    4. Holding the printer in both hands, turn it upside down to see if anything falls out of the paper feed area. (Sometimes objects such as pens, paper clips and so on can fall into the paper feed area and cause blockages.)
You can clean with special cleaning paper which ca be used clean the rollers............
Dec 08, 2007 | Lexmark X5470 All-In-One InkJet Printer
Lexmark x3350
Nov 20, 2007 | Lexmark P4350 All-In-One InkJet Printer
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
109 people viewed this question
old marine
old marine
