Question about Miele 30 in. KM443 Electric Cooktop
Amps what kind amprage is needed to operate miele KM 443 cook top
    Top Expert:
  • Miele Master
  • 81,342 Answers
60 amps and 220 volts
Posted on Jun 17, 2009
How do I deactivate demo mode in my Miele cooktop?
PDF]Miele Ceramic Cooktop - Customer Care
customercare.concordadex.com/.../Miele_Ceramic_Cooktop_KM5840-5860-5880.pd...Operating and Installation. Instructions. Ceramic Cooktop. KM 5840. KM 5860. KM 5880. To prevent accidents and appliance damage, read these instructions before installation or use. .... work should be performed by a Miele authorized service ...... Deactivate demo mode (see "Programming"). The cooktop turns off while it ...Missing: my
deactivate demo mode Miele cooktop Google Search
Feb 25, 2018 | Miele Cooktops
Miele KM 3474 stove top lights but turns off after 30 seconds
Does the burner attempt to re-ignite after it goes out? If so, it's probably the therocouple. If not, it could be the burner valve. Be sure the caps and rings are correctly seated on the burners and be sure to firmly press the burner knob down to start the flame.
Feb 04, 2010 | Miele 36 in. KM3474 Gas Cooktop
Miele KM 320 G gas cooktop ignitor
I had a similar problem and discovered that the control knob had fried itself, most likely due to liquid penetration down the shaft of the control knob and into the control knob electronics. Inside is a printed circuit board with resistor, diode and a rheostat. The surface of the board was charred beyond repair.
To trouble shoot the problem, open the cook top and hook the burner in question to one of the known good control knobs. If it ignites, then it is the control knob electronics. If it doesn’t, then there is something wrong with the igniter.
Note: The 2-zone Wok Burner had a different control knob that the other burners.
To open the cook top, do NOT loosen any of the Phillips screws on the sides. Here are the instructions from the user manual:
Disassembly
Shut off gas supply, disconnect the manifold pipe, disconnect the electrical power. Remove pan supports, burner heads and burner rings. Remove control knobs.
In the event that the hob is built in, undo the bracket clamps underneath the work surface. Lift the hob on to the work surface. Unscrew the venturis on the high-speed and super high-speed burners using a 20 mm wrench. Lift and remove the burner rings and burner base plates. Disconnect the wires from the ignition plugs. Keep the wire from dropping into the undertray by inserting it in one of the slots in the burner supports.
Remove the three screws securing the dual ring wok burner. Remove the wok burner base plate. Lift the ceramic tray from the hob.
Note: Each regulator shaft is equipped with a black ring. This ring may cling to the rubber seal in the ceramic tray. Check and remove the rings from the rubber seals.
To order parts, call 1-800-245-8215, 8:30 AM to 5:00 PM EST
Mar 04, 2009 | Miele 35 in. KM326G Gas Cooktop
Miele 30 in. KM443 Electric Cooktop Logo
169 people viewed this question
Top Miele Cooktops Experts
Marvin
Marvin
mpservices
Are you a Miele Cooktop Expert? Answer questions, earn points and help others
