Question about Yamaha DVD-C920 Multi-disc DVD Player
DVD Tray stuck open
I cannot get the DVD Tray on our dvd player to close it will power on and off and such, but when i try and close the tray it acts like it is stuck on something and won't close. Any Suggestions? Thanks!
    President:
  • 1,285 Answers
The tray is not catching (underneath the tray is ridges). unplug the dvd player from the wall for 5-10 min...plug back up and give the tray a lite push while tapping the open/close button
Posted on Jul 17, 2010
My DVD tray on my Yamaha DV C6480 (it holds 5 DVDs) got stuck in the half open half closed position. It may have come off the track. I opened the case and reinstalled the DVD Tray. Now the tray...
This happens to us all the time. Here is the note I keep on how to fix it quickly:
When tray gets messed up, the drive wheel (with pegs that interlock with pegs on the tray) needs to be such that the tray slides in and out freely. Push tray all the way in. Turn on.
Hope that gives a hint.
Nov 04, 2010 | Yamaha DV-C6480 Multi-disc DVD Player
When the open/close button is push , the DVD tray open and it close immediately without pushing button.The tray won't stay in the open positions.
check the close circuit switch inside the system. its maybe stuck, try to wiggle it a bit and it might work again.
the switch is at the end of the tray when it is closed, its a small black push botton swith.
be careful not to fry it when installing a new part
Aug 26, 2010 | JVC HR-XVC16B DVD Player / VCR Combo
DVD tray stuck in the closed position
Is it jammed?
Still has a CD/DVD still in it?
Is so try cycling the power to see if it will kick it out.
Otherwise it's most likely a hardware problem like a bad tray motor, broken gear, or perhaps a bad/stuck switch on the tray assembly.
If it's still under warranty, call the manufacture technical or customer support for a possible replacement.
Jul 20, 2010 | iLO DVDR04
My dvd tray is stuck...I think it's a dvd stuck in the tray
unplug the player for 5-10 min...once you plug it back and power on quickly tap the open/close button (the player by default will try to load the disc)
feel free to rate help
Jun 26, 2010 | Yamaha DVD-C996 DVD Player
Rosen entertainment DVD player in a '04 Yukon will not eject
One of the biggest problem facing CD/DVD players are the drive mechanism. When the stay shut or chatter when you try and open them, means the through mechanism that ejects the tray will not push the holding tray open. If you want to open the tray by hand, there is a small hole whereby you can push a pin or paperclip into and push open the tray by hand. That is the only way to open and hand shut the tray into the player and get it operational. Other than that, replace the DVD device...no other choice.
Feb 03, 2018 | Car Audio & Video
Jammed tray
try checking the tray for something that jams the tray.
May 27, 2009 | Yamaha DV-C6660 Multi-disc DVD Player
E1 (rear) error. DVD tray will not open.
there might be a possibility that as soon as the tray closed the dvd shifted inside the machine. the dvd is stuck yes which means that the tray wont open because the dvd is blocking the gear turning. if so you are going to have to take it to your Dealership to open up the player and remove the disk. you can try it yourself but it's not recommended. tray gears will have to be tested to see if the tray will open once the disk is out though
Mar 29, 2009 | Philips Magnavox DVD/VCR Dual Player
Dvd tray won't open dvd stuck
I had this happen when someone put a DVD in the tray when there was already one in there. I managed to pry the tray out to retreive the DVD's, but when I closed the tray it was stuck for good. I wouldn't bother doing this because you'd probably have to take the player apart for it to work again anyway.
I took it apart and found that the gears were thrown off from the jammed tray. If you have some mechanical ability, you should be able to see where it is off track. Most likely you would just have to snap the gears back in place, hopefully none of them broke. Also, when you have it apart, you can manually open and close the tray part to assure that it's corrected.
Mar 08, 2009 | Aspire Digital AD-1000 DVD Player
I would like to change regions on my portable Durabrand DVD player model PDV-722
Alright, just follow these steps and let me know if you have any problems or questions
  1. Power and switch on the Durabrand DVD player.
  2. Open the DVD disc tray tray or lid.
  3. Press Stop.
  4. Press 3 - 5 - 9 - 7 (3597 in sequence). Can be done on remote control.
  5. Hidden DVD Region menu appears. Select region 0 or 9 using up or down button on remote control
  6. Press OK.
  7. Close the disc tray and press Standby on the DVD player front
Dec 19, 2008 | Televison & Video
Door will not open or close
i ended up retrieving the dvd out of mine after it quit coming on by taking the top cover off and taking the cover off the dvd it just snaps in place by clipping on each side.
Feb 17, 2007 | Emerson EWD7003 DVD Player
Yamaha DVD-C920 Multi-disc DVD Player Logo
1,163 people viewed this question
Top Yamaha Televison & Video Experts
 Grubhead
Grubhead
Are you a Yamaha Televison and Video Expert? Answer questions, earn points and help others
