Question about Jack Lalanne Power Juicer 250 Watts
Motor not running
My juicer doesn't work. I have pulled it apart right down to the motor. When I touched the switch, the rotor started turning, however the outside switch doesnt work. Help
  • 139 Answers
The stainless bar has a safety cut off switch at both ends. You have to put it back the same way to make the outer switch work.
Posted on Jul 15, 2009
  • Arthur Bautista
    Arthur Bautista Jul 15, 2009
  • Arthur Bautista
Juicer does not turn / rotate. Does this mean the motor is burnt out ?
It could mean burnt motor, but it could mean that it's simply got gunk in it, and it needs cleaning/lubricating. You'd have to take it apart to tell. A burnt motor has a very specific smell. If you take it apart, and there's no burnt smell, likely cleaning and lubricating will fix it.
Jun 10, 2015 | Braun MPZ-22 Juicer
Not sure how to assemble juiceman jr juicer,
Model #JM01C K: The motor works. The black start button works. The on-off Switch does not engage with the start button when moved up and down. Am I missing a part?
Dale
dale@webr4m.com
Jan 03, 2011 | Salton Jr. JM1 Juicer
How do you take apart the jack la lannes juicer for cleanning
I had the same problem because I bought it used. After reading that I needed a key that fit in the holes I used a pair of chop sticks and it twisted right off.
Sep 15, 2009 | Jack Lalanne Power Juicer 250 Watts
How do you take the filter and blade off to clean? it came together easily, but having trouble taking it apart...
It should unscrew in the opposite direction that the blade turns. Check the blade direction by momentarily spinning the motor with it's own power (don't touch it!). Once you know which direction it goes, unplug it and turn the blade in the opposite direction to remove.
Aug 19, 2009 | Jack Lalanne Power Juicer 250 Watts
It want turn on in smells burned
Assuming the motor is not totally burned yet, Make sure the blade is fiitted in its place right. Take the blade out again and fit it right along with the strainer. If it is not seated and fitted well, it will touch the upper cover and will not turn and will smell burnt.
Jun 04, 2009 | Jack Lalanne Power Juicer 250 Watts
Juicer will not start when switch is turned on
Make sure the stainless bar running across the top is snug on the left and right groove. It has a shut off switch when not installed properly.
Mar 26, 2009 | Breville JE3 Juicer
Jack LaLanne power juicer 250 no longer works.
The stainless bar should be on the correct slots on top of the juicer. It has a safety switch on those bars. Smell the motor from under the juicer, it should not smell like burnt. Press hard on the switch, it might be loose.
Jan 28, 2009 | Jack Lalanne Power Juicer 250 Watts
Juicer no longer works !
the motor uses a tiny fuse in the windings and it might be hard to find and rated up to 15 amps... it blows sometimes for no reason and especially on cold starts.
also the on-off switch wears out.. and lastly the ac cord breaks inside from stretching too much.
Jan 30, 2008 | Champion 2000+ Household Juice Extractor
Juicer problem
The fuse blew on mine, that could be it. I'm looking for a replacement fuse.
Mar 21, 2007 | Waring JEX 328 Health Juicer
OPENING the JC-250 Juice Extractor
Hey, you probably have figured it out! I just got a juicer without a manual and couldn't find a way to dismantle for cleaning but I got it!!!!!!!!! Just put it upside down and twist and turn. Everything will fall off ( cutter and container). I'm so happy to help!!
Jan 22, 2007 | Brentwood JC-250 Juice Extractor 350 Watts
Jack Lalanne Power Juicer 250 Watts Logo
383 people viewed this question
Top Jack Lalanne Juicers Experts
Starnley Johnwells
Starnley Johnwells
Cory Koby
Cory Koby
Are you a Jack Lalanne Juicer Expert? Answer questions, earn points and help others
