Question about Maytag Atlantis MAV6451 Top Load Washer
Maytag 6300 won't agitate durring wash cycle
Everything else seems to work fine, but the agitator won't work.
  • 6,784 Answers
HI. this is usually caused by a faulty drive assembly(agitator gear components and clutch malfunction).
I recommend replacing the agitator components by purchasing a Agitator replacement kit. and, replace the clutch assembly as well. this will fix this issue.
Posted on Jun 17, 2009
What needs to be replaced? I installed a new motor but my washer still won agitate or spin.
check / replace the start run capacitor for the motor
have a electrician do it or a service technician if you do not recognize it
it is normally up near the control panel
Oct 19, 2015 | Haier HLP21N Washer
Our Kenmore 110-21252110 Washing machine is not agitating, what could be wrong?
Wil,
IT could be the agitator dogs that are chewed up and not gripping like they should. I am including a link to the Sears parts direct website so that you can see what they are. Second link is to a video on how to change them.
Washer Agitator Dogs Part Number 3366877 SAME DAY SHIP GUARANTEE from...
How to repair the Agitator Dogs in your Kenmore or Whirlpool or etc Washer
Jul 07, 2015 | Kenmore Washing Machines
The air con won't work. How do I fix it, everything seems to be set up fine. I thought all I had to do was turn it on and the air con would turn on, but it won't
Check that the master switch on the external condenser fan housing is turned on, it is a sliding button like switch.
Feb 25, 2013 | Heating & Cooling
Hoover 500mb washing machine failing to spin.
my does everything but it just wont spin drye
Mar 25, 2012 | Hoover HTC243 Top Load Washer
The agitator is no longer attached
There is a small set screw located lower on the agitator. Locate the set screw and tighten. This should solve the problem.
Jan 05, 2010 | Maytag Washing Machines
My agitator is not working in my washer- it is a kenmore elite. the agitator seems locked up. Everything else works fine.
The agitator is driven by a couple of different methods. The first is the agitator is splined and slips onto the matching splines of the agitator shaft from the transmission. The second is the use of a bell coupling which is splined to the agitator shaft as well and the agitator snaps onto the coupling. If the agitator does not agitate, first remove the agitator and watch the agitator shaft to see if it is working properly. This will require a small load setting of water and the machine set to run. If the agitator shaft is working properly, it is either the splines on the agitator or the bell coupling that is defective. If the agitator shaft does not work properly, the problem is in the transmission.
Hope this helps.
Aug 07, 2009 | GE WBSR3140DW Top Load Washer
Ge elite 110 23012 100 top load washer
look on the inside your agitator makesure it not strip out cauing your agitator be lose might need to replace agitator
Aug 08, 2017 | GE Washing Machines
The top half of the agitator (near the fabric softner comp) is skipping while it is in wash cycle
yes the top half seperates from the bottom half inside the top half are 4 little parts called dogs. the part number is 241341. replace the dogs to fix it
Nov 27, 2007 | Kenmore 22932 Top Load Washer
Maytag Atlantis MAV6451 Top Load Washer Logo
181 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
