Question about HP DeskJet 880c InkJet Printer
Inserted new cartridges..orange light still on
I have inserted new black and tri-color ink cartridges, but the orange "out of ink" light is still blinking. We have turned the printer off and back on and still blinking
  • 72 Answers
Try re-seating the ink cartridges. A lot of times, the electrical contacts on HP's ink cartridges do not make a solid connection.
Posted on Jun 17, 2009
Need to replace ink cartridge and I forget how to replace ink cartridge
1. Remove the black ink cartridge from its bag.
2. Carefully remove and discard the orange cap.
Handle ink cartridges carefully to avoid ink transfer.
3. Insert the black ink cartridge into the printhead.
4. Press down on the ink cartridge until you hear it click
into position.
5. Open and uncap the color ink cartridge. Insert it into
the printhead.
6. Press down firmly on the ink cartridge until you hear it
click into position.
7. Close the printer access door.
Here's the link if you want some illustrations. Link
Chapter 3, Page 5
Thank you for posting..
Jun 30, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
I am refilling the black ink of my canon printer using continuous ink container but the black color doesn't flow into the end of the hose and it didn't print at all, please help
  • Check the printer's power/alarm light. If it is flashing orange, count the number of flashes. Look up the flash code in your printer's user manual to diagnose the problem.
  • 2 Remove and reinstall the ink cartridges if the power/alarm light flashes 5, 7 or 15 times consecutively. This indicates that the issue is a cartridge error, an incorrectly installed cartridge, or an unrecognized cartridge. These errors can be fixed by reinstalling the ink cartridges. Make sure that you are using the correct ink cartridges for your Canon printer.
  • Turn on the printer and open the front cover. The ink cartridge holder should move to the replacement position.
  • 4 Verify that the colored ink cartridge is inserted in the slot on the right and the black ink cartridge is inserted in the slot on the left. Swap the cartridges and reinstall them in the correct slots if necessary.
  • 5 Check to see that both ink cartridges are level with one other and parallel to the top of the ink cartridge holder. If either cartridge is wedged at an angle, gently apply pressure to the cartridge until it clicks into the correct position.
  • 6 Close the front cover of your Canon printer and wait while the printer initializes the newly installed cartridges. This can take a minute or two.
  • Jun 12, 2011 | Office Equipment & Supplies
    I am having problem on how to change the ink cartrdges. I can't get it to go to the center to be able to change the ink. Pls. help
    hi,
    following images and steps may guide you.
    first know the parts.
    Tear open the black ink cartridge bag at the notch and remove the ink cartridge.
    IMPORTANT: Insert the ink cartridge immediately to prevent any drying of the ink.
    Remove and discard the orange cap.
    IMPORTANT: Handle ink cartridge carefully to avoid ink transfer.
    Insert the black ink cartridge into the printhead. User's
    Press down on the ink cartridge until you hear it snap into position
    Tear open the color ink cartridge bag at the notch and remove the ink cartridge.
    Insert the color ink cartridge into the printhead
    Press down firmly on the cartridge until you hear it snap into position
    regards,
    cseian
    Feb 16, 2011 | Kodak EASYSHARE 5300 All-In-One InkJet...
    My printer has a new ink cartridge but does not recognize the ink
    What model printer do you have and can you list the print cartridge?
    Also have you selected on the onboard printer menu that you have inserted a new cartridge?
    Jul 28, 2009 | Epson Stylus Multifunction Inkjet Printer/...
    Install black cartridge, but will not print
    Lets do it this way. Follow these steps again carefully and try to install the Ink.
    Introduction
    Follow the instructions below to replace the ink cartridges.
    Replacing the ink cartridges
    1. Verify that the unit is on.
    2. Open the ink cartridge door.
    3. Squeeze the gray tab below an ink cartridge slot to release the gray latch and then lift the latch.
    1 - Ink cartridge latch for the black ink cartridge
    2 - Ink cartridge latches for the color ink cartridges
    NOTE: The ink cartridge areas are color-coded for easy reference. From left to right, the ink cartridges are black, yellow, light cyan, cyan, light magenta, and magenta.
    4. Pull the ink cartridge toward you out of its slot to remove it.
    5. Remove the new ink cartridge from its packaging.
    6. Hold the ink cartridge by the handle and then slide the ink cartridge into the empty slot.
    NOTE: Make sure that the ink cartridge is inserted into the slot that has the same shaped icon and color as the ink cartridge. The copper-colored contacts should be facing the printer as the ink cartridge is inserted.
    7. Press down on the gray latch until it clicks into place.
    8. Repeat steps 3 through 7 for each ink cartridge that needs to be replaced.
    NOTE: All six cartridges must be installed. The printer will not work if an ink cartridge is missing.
    9. Close the ink cartridge door. Print a test page.
    If after doing this it does'nt work, then i will ask you to unplug the printer cable from the computer and uninstall the printer driver/Software completely.
    Shut down your computer and restart it.
    Re-install the printer driver/software from the start as you did when you bought it.
    Good luck
    Apr 18, 2009 | HP Photosmart C6180 All-In-One InkJet...
    Canon PIXMAR MP150 E5 problem
    hi,
    CANON PIXMA MP160 All-In-One InkJet Printer
    has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
    http://www.canon.com/printer/prob676ijt65/solution
    toi-i-28
    Apr 10, 2009 | Canon PIXMA MP160 All-In-One InkJet...
    Pic`s wrong colors
    you need to check
    1) same color ink of the cartridge almost empty, change a new ink cartridge or refill the color ink (there is only one ink cartridge)
    2) the cartridge ink channel dryer and constipated, take out the cartridge put the bottom surface touch down clean water (a little) 1 hr, then set back if the cartridge has enough ink.
    Feb 05, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
    New Cartridge error message
    Follow the steps below to remove and replace the empty ink cartridge.
    1. Turn the printer on.
    2. Open the ink cartridge door. Figure 1: Opening the ink cartridge door c00819080.gif
    3. Squeeze the gray tab below an ink cartridge slot to release the gray latch and then lift the latch. Figure 2: Lifting the latch c00819081.gif 1 - Ink cartridge latch for the black ink cartridge 2 - Ink cartridge latches for the color ink cartridges
      NOTE: Theink cartridge areas are color-coded for easy reference. From left toright, the ink cartridges are black, yellow, light cyan, cyan, lightmagenta, and magenta.
    4. Pull the ink cartridge toward you out of it's slot to remove it. Figure 3: Removing an ink cartridge c00819082.gif
    5. Remove the new ink cartridge from the packaging.
      NOTE: Makesure that the ink cartridge is inserted into the slot that has the sameshaped icon and color as the ink cartridge. The copper-colored contactsshould be facing the printer as the ink cartridge is inserted. Figure 4: Inserting an ink cartridge c00819083.gif
    7. Press down on the gray latch until it clicks into place. Figure 5: Closing the gray latch c00819084.gif
    after Doing this all Follow the next step :-
    Please Try This, I am sure it is going to workout.
    Resetting the All-in-One
    Press the On (fa37665.gif) button to turn off the unit.
    • Disconnect the power cord from the back of the unit.
    • Connect the power cord to the back of the unit.
    • Press the On (a477fdf.gif) button to turn on the unit.
    Oct 21, 2008 | HP Photosmart C5180 All-In-One InkJet...
    Printer will not print black ink
    Hi please try these steps:::
    Right-click the printer icon, and then select 'Properties'.
    2. Click the 'Maintenance' tab, and then click 'Deep Cleaning'.
    3. Select 'All Colors', 'Black' or 'Color' for the print head to be cleaned.
    4. Read the message displayed, and then click 'OK'. The power lamp blinks and print head deep cleaning starts. (Do not perform any other operations until print head deep cleaning is complete. Print head deep cleaning takes about 1 minute.)
    IF ABOVE STEPS DOESN'T WORK TRY THESE STEPS BELOW
    Check ink tank vent hole The ink tank requires air to flow through it so ink can move from the reservoir to the print heads.
    1. Confirm there is no orange tape across the top of the ink tank
    2. If the orange tape is as shown in Figure (1), it is properly removed.
      *BCI-3's shown in this example.
    3. If the orange tape is as shown in Figure (2), remove the remaining tape to the level shown in Figure (1).
    4. Make sure each ink tank is snapped into the printer.
      IF THESE STEPS DIDNOT WORK THEN YOUR PRINTER NEEDS REPAIR(You might need to change the printer head.)
    Jun 09, 2008 | Canon i850 InkJet Photo Printer
    Orange cartridge light error keeps on blinking!
    clean the carriage home
    check the data cable for the carriage home
    check the media sensor on the left of the plotter media bar
    Mar 12, 2008 | HP DesignJet 450c InkJet Printer
    HP DeskJet 880c InkJet Printer Logo
    541 people viewed this question
    mukhtar21 shaikh
    mukhtar21 shaikh
