Question about Dell Inspiron 9100 Notebook
The Flickering White Lines
These lines show up out of nowhere and the only way they leave TEMPORARILY is if i tap the screen or varies parts of the computer help me btw i have a HP Pavillion dv2000
    President:
  • 2,653 Answers
Your lcd is going out. The problem will get worse and worse until it eventually dies.
Good news for you though, that lcd is fairly inexpensive to replace with one from ebay.
Best of luck!
Oh, one more thing you should try updating the bios firmware, and video drivers to see if that solves the problem, it won't but...it's still a good idea to have the latest versions anyways.
Best of luck!
Posted on Jun 17, 2009
3 white lines flickering at the bottom of the screen
it is the problem of the screen itself, you need to change the screen
Aug 21, 2012 | HP G70-460US Notebook
Picture flickering and faded on left had side of the screen
if rebooting the monitor would do no good, try to get a spare monitor cable if the same flickering issue took effect. If it is so, then call your pc provider to repair your monitor..
Nov 26, 2011 | Philips 47 in. LCD HDTV
SCREEN HAS VARIES RED -BLUE-WHITE- LINE SHOWING, I TRIED USE THE
It needs to be repaired by having the convergence ICs replaced or resoldered (if intermittent).
Parts are STK 392-570. Be sure to use thermal paste on the ICs.
Jul 02, 2010 | Mitsubishi WS-65809 65" Rear Projection...
I HAVE A VERTICAL WHITE LINE (1" WIDE") ON MY DISPLAY
If it runs all the way from top to bottom, will not go away, and perhaps flickers or vibrates, it is quite possibly a symptom of a faulty LCD panel. Attach a second display using the auxiliary display port on the rear. If the white line does not show up on this display, your main LCD panel is faulty.
Main LCD panel replacement on this model is not a difficult job for a certified tech. The panel can be had for $80 used (17" screen; other sizes may vary).
Feb 14, 2010 | Apple iMac G4 Desktop
Laptop screen constantly flickers and whites out
Your Bulb is DUE, you need to change it, Don't do it your self contains mercury. Your LCD is good IF you do not have bad PIXELS. This white and pink lines shows as pixel problem but it migth also short on LCD, if you placed something heavy on Laptop. You may remove and sent the LCD for repair or all laptop to tech.
You may also need to check inverter. I give service around the Country but it is up to you. My company name is JMC TECHS INC. Registered in Miami Florida. (Check SUNBIZ.com) jmctechinc@gmail if you like to contact me.
JMC
Aug 15, 2009 | Toshiba Satellite Pro M300-S1002X Notebook
What component failed in my 17"CRT 753s model samsung moniter?
Your vertical deflector circuit is going out. This is really not economical to repair, the chip alone is $12-15 plus if you have any other parts in the circuit going out plus labor. You can pickup 17" CRT monitors for less than $15 from goodwill or craigslist.
Sorry to say but I think its time to retire your 753s
Buddy
Corporate Computer
Jul 14, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
White line in the center of my screen
harware problem, it has to be repair.
Jan 31, 2009 | Computers & Internet
Flickering multi-colored line in the middle of the screen.
You have a failure in the vertical deflection circuit. This could be either a bad vertical chip, the power supply that runs the chip or a bad capacitor in that circuit. This is usually a repair best left to a professional. There is a small possibility that it could be bad solder connections. If genlty tapping the unit temporarily solves the issue you can try and resolder the pins on the vertical chip LA7841 is the part number. There is also a resistor 1 ohm 1 watt. If that resistor is open you can assume the IC is bad
Oct 26, 2008 | Sanyo DS27800 27" TV
HTC TOUCH WHITE SCREEN
Just forget the support from HTC. They have very poor customer service. You paid thousands and purchased it but who cares?? I am fed up with HTC. No support, No warranty....
Jul 01, 2008 | HTC Touch P3450 Smartphone
Razr inner screen fading, flickering
take the phone and have the LCD replaced on the phone.
Jun 27, 2008 | Motorola Mobility RAZR V3
Dell Inspiron 9100 Notebook Logo
208 people viewed this question
Alun Cox
