Question about LaCie 250GB Ext/Firewire 7200 250 GB Hard Drive
LaCie drive will not mount
My LaCie external hard drive is not mounting.Mac OS 10.5.4
  • ben4705 Jun 17, 2009
    I have several firewire drives connected together. Suddenly two of them stopped working.
    Help!
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 72 Answers
Try to reinstall the firmware drivers and itry to get it to mount again, if this doesn't work you'll have to reformat the system and do a clean install of mac osx.
Posted on Jun 18, 2009
    Brigadier General:
  • 3,917 Answers
Does the LaCie drive stay plugged into the computer all the time? Have you ever disconnected it from the computer, unplugged its own power supply, or switched it off without first unmounting it from the desktop, and received a "The device you removed was not properly put away" error message? If so, did its failure to mount begin after that?
Have you tried connecting the drive directly to your computer, omitting the hub and leaving all other FW devices disconnected? If that doesn't cause the drive to mount, try another FW device on your Tibook's FW port to make sure the port isn't bad. Then try using a different FW cable with the LaCied rive, in case the cable is bad, and test the LaCie drive's cable with a different device. If the port and cable both work OK with other devices, boot to a Mac OS installer disc, connect the LaCie drive, and see whether it is recognized by Disk Utility, running from the startup CD or DVD. If it is, there's a software problem on your hard drive that is preventing detection of the drive. If your port and cable are proven good, but DU doesn't see the drive even when the Mac is booted to an OS installer disc, It would appear there's a hardware or very low-level software problem with the LaCie drive itself, and you should consult LaCie about it.
Thanks for contacting Fixya
Posted on Jun 17, 2009
The icon for my lacie exyernal hard does not show
Here's two suggestions. (If your using Mac OS X 10.x)
Make sure external hard drives are to be shown by clicking "Finder" in the menu bar then "Preferences" and under the "Sidebar" section selecting "External Disks".
Also check that the hard drive is mounting by opening "Disk Utility" by first opening the "Applications" folder then the "Utilities" folder and double clicking "Disk Utility" and in the left sidebar checking to see if your external hard drive is listed as one of the mounted drives. Hope this helps, don't forget to comment/vote if this helped. Thank you.
May 30, 2010 | Apple Computers & Internet
LACie disks are mounted on the desktop
http://www.pricespider.com/products/454765/LaCie-D2-301110U.html
This link has product reviews and problems others have had with it. It may be worth checking out.
Let me know how it goes,
Thanks
yalmer
Mar 14, 2008 | LaCie External USB 2.0 500GB 7200 RPM 500...
Will not mount on a Mac Book Pro 17"
try to connect lacie to windows base computer if it work, there a problem, with your mac book check if device manager recognize lacie drive if not check for the fire wire port.
Apr 10, 2010 | LaCie 1TB D2 HD Quadra FireWire 400 Hard...
"The disk LaCie was not repairable by this computer. It is being made available to you with limited functionality. You must back up your data and reformat the **** as soon as possible. Am using it as
Bob,
I had a similar problem with two LaCie external hard drives.
LaCie doesn't manufacture hard drives, they only purchase drives from other companies, like Seagate, and mount those drives in LaCie external enclosures.
If the drive is nearing the point of total failure, then your Mac is letting you know that point is very close. You had better find a new backup device to use. The Mac will let you access the drive for a while longer, but if you do not act, there will come a point when the Mac will not be able to read the data on the drive and any backups you have there will be lost.
When you get a new external hard drive to use for backup, you may not need to do anything with the current drive that is failing, as long as you do not anticipate that you will need anything from the backups that it contains. You can set up the new device as your primary backup. I would then advise that you perform a total backup on the new device ASAP, so that you are not left without at least one good backup.
Sep 27, 2017 | LaCie (300740) 160 GB Hard Drive
Cannot find the lacie driver on my mac
Chances are the drive is bad. Try taking it to another computer- if it doesn't work there, then the prognosis is poor. Data recovery services are available, but pricey.
Feb 05, 2009 | LaCie d2 Extreme (301033) (301033A) 160 GB...
Lacie 1TB external hd won't mount!
check wires connecting them together first, ok?
then, turn off the LaCie, connect to your MacPro, and then turn on the drive..
that should show as a mounted drive.
need printer drivers update?
Mar 09, 2008 | LaCie Big Disk Extreme with Triple...
Lacie d2 external drive
I support the comments of (fire sine) I have the d2 120gb Lacie and it was down for two years.  I took it to my apple guys and they said that I needed to go to a data recovery service which would cost a gang of money.  Come to find out, when I decided to update my internal hard drive on my Mac Pro, I had to buy a SATA, IDE, USB 2.0 adapter to back up the internal and transfer to the new internal. Long story short, something said, Hey try and open the Lacie and bypass the board in the enclosure and connect directly to the Western Digital drive inside.  AND WHALA! I got my info, so all I need is a new enclosure.
Sep 24, 2007 | LaCie d2 (300769) 200 GB Hard Drive
Mounting an external hard drive onto my I Mac
Hi, I have just checked the LACIE website, So Google LACIE, click the second result [Lacie's own site] you will get a page up with a choice box, select Australia/go click the desktop HDD. click the 500Gb usb, this will give you a page with a support and a download link. click download, here you will find a manual and drivers. Goodluck mistyman
Sep 03, 2007 | Computers & Internet
LaCie 250GB Ext/Firewire 7200 250 GB Hard Drive Logo
564 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
