Question about HP L1706 17" LCD Monitor
Windows XP Missing configuration?
When i turn on my windows xp the moniter light goes green then yellow for a second then back to green. sometimes it goes to the first page(Compaq in big letters and the F1 and ect buttons at the bottom.)and it sais /WINDOWS/SYSTEM32/CONFIG/SYSTEM/ is missing what do i do? (i dont heva the start up disk)
  • 23 Answers
The first thing you need to do is get the "Legal OEM XP Restore CD and Drivers" for your Compaq PC Model ####
If you have access to the internet on another PC or plan on visting the local library to use the public PC, contact Compaq and request a new copy of the CD's. You will need the Model Number and Serial Number. If the XP OEM sticker is still on the PC, copy down the numbers in case.
www.compaq.com or www.hp.com
Once you have the XP CD in-hand:
Insert the Windows XP CD-ROM into the CD-ROM drive, and then restart the computer.
Click to select any options that are required to start the computer from the CD-ROM drive if you are prompted to do so.
  1. When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
  2. If you have a dual-boot or multiple-boot computer, select the installation that you want to access from the Recovery Console.
  3. When you are prompted to do so, type the Administrator password. If the administrator password is blank, just press ENTER.
  4. At the Recovery Console command prompt, type the following lines, pressing ENTER after you type each line: md tmp
    copy c:\windows\system32\config\system c:\windows\tmp\system.bak
    copy c:\windows\system32\config\software c:\windows\tmp\software.bak
    copy c:\windows\system32\config\sam c:\windows\tmp\sam.bak
    copy c:\windows\system32\config\security c:\windows\tmp\security.bak
    copy c:\windows\system32\config\default c:\windows\tmp\default.bak
    delete c:\windows\system32\config\system
    delete c:\windows\system32\config\software
    delete c:\windows\system32\config\sam
    delete c:\windows\system32\config\security
    delete c:\windows\system32\config\default
    copy c:\windows\repair\system c:\windows\system32\config\system
    copy c:\windows\repair\software c:\windows\system32\config\software
    copy c:\windows\repair\sam c:\windows\system32\config\sam
    copy c:\windows\repair\security c:\windows\system32\config\security
    copy c:\windows\repair\default c:\windows\system32\config\default
  5. Type exit to quit Recovery Console. Your computer will restart.
Note This procedure assumes that Windows XP is installed to the C:\Windows folder. Make sure to change C:\Windows to the appropriate windows_folder if it is a different location.
http://support.microsoft.com/kb/307545
Posted on Jun 17, 2009
  • 72 Answers
Sounds like you may have bad RAM. Try removing all of the RAM modules on your motherboard and put only one in the first slot. Start the computer and see if it works.
Ntldr is missing press ctlr+alt+ and delete to restar and i did and don't workz
First I have to assume that you are running Windows XP. This solution should work for other versions of Windows.
The "NTLDR is missing" error displays very shortly after the computer is first started, immediately after the Power On Self Test (POST) is complete. Windows XP has only initially begun to load when the NTLDR error message appears.
Causes of NTLDR Errors
There are a number of possible causes for NTLDR errors, including the most common "NTLDR is missing" error message.
The most common reason for this error is when your PC is trying to boot from a hard drive or flash drive that is not properly configured to be booted from; in other words, it's trying to boot from a non-bootable source. This also would apply to media on an optical drive or floppy drive that you're trying to boot from.
Other possible causes include corrupt and misconfigured files, hard drive and operating system upgrade issues, corrupt hard drive sectors, an outdated BIOS, and damaged or loose IDE cables.
How to Fix NTLDR Errors
1.Restart the PC. The NTLDR error could be a fluke.
2.Check your floppy and optical (CD/DVD/BD) drives for media and disconnect any external drives. Often times, the "NTLDR is Missing" error will appear if your PC is trying to boot to a non-bootable floppy disk, CD/DVD/BD, or external hard drive or flash drive.
Note: If you find that this is the cause of your problem and it's happening a lot, you might want to consider changing the boot order in BIOS so the hard drive with Windows installed is listed first.
3.Check the hard drive and other drive settings in BIOS and ensure they are correct. The BIOS configuration tells the computer how to use a drive so incorrect settings can cause problems, including NTLDR errors.
Note: There is usually an Auto setting for hard drive and optical drive configurations in BIOS which is usually a safe bet if you're not sure what to do.
4. Restore the NTLDR and ntdetect.com files from the Windows XP CD. Restoring these two important system files from the original Windows XP CD may do the trick.
5. Repair or replace the boot.ini file. This will prevent the NTLDR error if the cause of the problem is a boot.ini file that is not configured properly for your Windows XP installation.
6. Write a new partition boot sector to the Windows XP system partition. If the partition boot sector has become corrupt or isn't properly configured, you may receive the "NTLDR is Missing" error.
7. Repair the Windows XP master boot record. NTLDR error messages may also appear if the master boot record is corrupt.
8. Reseat all internal data and power cables. NTLDR error messages could be caused by loose or malfunctioning IDE cables.
Try replacing the IDE cable cable if you suspect it might be faulty.
9. Update your motherboard's BIOS. Occasionally, an outdated BIOS version can cause the "NTLDR is Missing" error.
10. Perform a repair installation of Windows XP. This type of installation should replace any missing or corrupt files. Continue troubleshooting if this does not resolve the issue.
11. Perform a clean installation of Windows XP. This type of installation will completely remove Windows XP from your PC and install it again from scratch. While this will almost certainly resolve any NTLDR errors, it is a time consuming process due to the fact that all of your data must be backed up and then later restored.
If you can't gain access to your files to back them up, understand that you will lose them all if you continue with a clean installation of Windows XP.
12. Replace the hard drive and then perform a new installation of Windows XP. If all else has failed, including the clean installation from the last step, you're most likely facing a hardware issue with your hard drive.
NTLDR Errors Apply To
This issue applies to the Windows XP operating system, including Windows XP Professional and Windows XP Home Edition.
Windows 8, Windows 7, and Windows Vista utilize BOOTMGR, not NTLDR.
Still Having NTLDR Issues?
See Get More Help for information about contacting me on social networks or via email, posting on tech support forums, and more. Be sure to let me know what steps, if any, you've already taken to fix the "NTLDR is missing" issue.
Jan 29, 2014 | Microsoft Windows XP Professional
My windows XP has an error message when started. It says "MISSING NTLDR, PRESS CTRL, ALT, DEL TO RESTART" I tried restart with boot disk but nothing. Please help!?
  1. Restart the PC. The NTLDR error could be a fluke.
  2. Check your floppy and optical (CD/DVD/BD) drives for media and disconnect any external drives. Often times, the "NTLDR is Missing" error will appear if your PC is trying to boot to a non-bootable floppy disk, CD/DVD/BD, or external hard drive or flash drive.
  3. Check the hard drive and other drive settings in BIOS and ensure they are correct. The BIOS configuration tells the computer how to use a drive so incorrect settings can cause problems, including NTLDR errors.
Jan 22, 2014 | Belkin Basic Wireless Router
Picture enlarged
PC or laptop? Sometimes I find on my PC if I just shut off the moniter and turn it on again, it reverts to normal. Something in the conection, I think.
Mar 18, 2013 | Microsoft Windows XP Professional
How to fix a NTLDR is missing error
Fixes for NTLDR Errors
Apr 06, 2012 | HP Pavilion 513n (P9850A#ABA) PC Desktop
Lg Flatron 17" monitor turns on you see the green light then
it's prb.. your video card not the moniter if a moniter goes from green to yellow " standby" it's prb the computer not the moniter
Dec 27, 2009 | LG Flatron L1715S 17" LCD Monitor
Have just hooked up my Viewsonic VA720 moniter as the main moniter to a new laptop that I have. The laptop is an ACER Travelmate 6293 running windows XP. When I come to start up my computer each morning...
You most likely have a capacitor that has changed value. When a capacitor goes bad it will work after it heats up. Sometimes a bad cap will have a bulging top or show signs of leakage. Sometimes can only be checked with a meter.
Oct 04, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
Gateway desktop xp starts then flashes blue screen for split seco
Sometimes they make the recovery disk with windows on it, but not the programs that start windows during the boot up phase. One of the three main files that boots into windows is corrputed or your Master Boot Record is missing. There are two options you can try without the OS disc so lets see if one of those will work: 1) boot up and press F8 to enter safe mode. Once in safe mode sometimes you can also get into window because just the minimum of the program is loaded. F8 Safe Mode>in windows>click start>accesories>system tools>system restore. It will allow you to restore your computer to a prior date before you have problems. 2)if that don;'t work then F8 safe mode and while in safe mode choose Last Known Configuration. Kinda works the same way as restoe but you don't have to be in windows to do it. If those don't work then get your hands on a windows xp disc, anyone's will do, don't have to be yours. Let me know how it goes.
Rate this solution. You can also find out about this at support.microsoft.com>help and support>type in Windows XP boot disk in the search engine.If those don't work let me know and we'll move on to phase II.
Mar 14, 2009 | Gateway Computers & Internet
Monitor goes blank less than a second after turning on.
the moniter may be having  some technical errors   maybe the IC's has got corrupt
you need to call the seller of the moniter
Sep 06, 2008 | BenQ FP71G 17" LCD Monitor
HP L1706 17" LCD Monitor Logo
254 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
