Blower wont run
Hi, I have a Bryant model fb4anf030, the blowerstopped running. I replaced the capacitor but didn't fix. Tested for current at the yellow common 120v and the black at the fan relay 120v so I figured the motor was bad. I replaced the blower motor but it still won't run, please help
  • seth veloso May 11, 2010
    did you make sure the relay was getting energized. At this point I would think you have a bad relay, or a control voltage issue. If you can find the terminals for the coil, check that you have 24 volts across it. let me know.
  • 116 Answers
Make sure getting 220 v ac on imputs the relay my be bad hook up fan man to power check to see if getting a call from stat to make fan run green to common 24v ac hope this helps
Posted on Jun 17, 2009
Model 393 Bryant furnace fan or motor makes noise when first starting. Then it's quiet.
https://www.repairclinic.com/PartDetail/Bryant-Furnace-Dual-Run-Capacitor/P2914553RS/2386586?ss=a36b380&mr=0
That part is probably going bad. The motor uses it to get moving and when it fails then the motor wont start, makes buzzing or humming noise due to phase loss.
Jan 28, 2017 | Bryant Heating & Cooling
I have a bryant gas furnace plus 90 the furnace kicks on and the pilot lights but the fan that blows the heat thru the house wont turn on! I keep getting error code 44 and 41 what can i do to fix that?
make sure fan wheel turns freely
check for voltage to fan--if you have voltage check capacitor output against capacitor rating, must be withing 5%, if that checks out replace blower motor
Jan 17, 2014 | Heating & Cooling
A/c blower turns slow and makes puffing sound. bryant 80% avac system.little cold air from vents
Hello, replace the capacitor as when there are storms sometimes they can cause a voltage spike and damage the capacitor. The capcitor will be a round or oval metal looking can next to the motor. When the blower motor runs slow the coil can start to freeze due to lack of airflow and this is why little air is coming out of the vents. If the capacitor does solve the problem then the motor will have to be replaced.
Jul 01, 2012 | Bryant Heating & Cooling
I have a Bryant Model 340MAV and the airconditioning fan is loud when running but seems to operating fine otherwise..fan is running and cooling great..the oustide coil was replaced in April. Please advise
Sounds like the motor is going bad in the air handler/furnace now...
Open up the blower compartment and spin the blower by hand with the power off...you should be able to hear if the bearings are rough or if the blower is hitting something... then you will know what you need to fix...
heatman101
Aug 29, 2011 | Heating & Cooling
I have a Bryant Model 593C central air - 6 years old - the fan on the outside unit won't run. I checked the breaker and it is fine.
Hello, this could be either a bad capacitor or bad fan motor. If the fan starts by giving it a push then replace the capacitor, if it does not start the motor needs to be replaced.
Jul 07, 2011 | Bryant Heating & Cooling
MY BRYANT AIR CONDITIONER OUTDOOR AND IN DOOR FANS ARE RUNNING BUT COMPRESSOR MAKES A CLICK NOISE
If the compressor is not clicking on then the relay or the capacitor is defective. Remove the unit out if the compressor is not working and check the relay unit , if the contacts are good , the check or replace the capacitor.
If however the comprssor is not holding on , the current drain must be checked using a clamp tester . if high the compressor can be faulty and might need an overhaul.
Sep 01, 2010 | Bryant Heating & Cooling
Ac compressor runs, no blower fan. fan and capacitor ok. bryant
so the outside compressor and fan are working good ? If the fan and capacitor check out good then check that the wire from the thermostat for the fan (usually green and tied to grey on a bryant) has voltage and if it does the control board needs replaced because it contains the fan relay
Aug 19, 2010 | Bryant 462AJC021BA Air Conditioner
What is the seer rating and tonnage of a bryant model fb4anf030
The Tonnage appears to be 2 1/2 ton,
024=24,000 BTU=2ton
030=30,000 BTU=2 1/2ton
036=36,000 BTU= 3ton
I dont think you have the correct Model Number, Look
on the outdoor unit, the model number might start with a 38. Hint Carrier and Bryant Products are the Same, just different nametag
Feb 17, 2010 | Heating & Cooling
Bryant furnance clicking, won't fire
try checking the pressure sensing switch,it has a tube that should run somewhere close to the inducer fan.sometimes this hose fills with liquids,and makes the units act funny.I don't know if you have a condensing unit or what.the furnace wont try to light if it cant tell the inducer motor is running.any induced draft unit will work this way.you can also do a temp. bypass of the pressure switch to make sure the contacts on it are closing just be sure your inducer fan is running,and you cant leave it like that its just a test.that is a safety feature you really need.
Mar 11, 2009 | Heating & Cooling
Heating & Cooling Logo
310 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
