Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
Light picture and getting lighter
This is a 43PP6360 and is 5years old. The picture just seem to be getting whiter and whiter. We have tried to adjust contrast - brightness & those controls without success. Wondering if bulbs need replaced
Dust build up on lenses
Posted on Jun 18, 2009
My wonderful Coolpix recently seems to be letting in too much light when I go to take a picture..worked fine before
It is mostly due to changing the exposure compensation. You can change it from +2 ....0 ....... -2. +2 Makes it Brighter while -2 makes it darker... On the back of the camera you will see an OK button surrounded by a disk that on the right side shows [+/-]. You use this to change exposure compensation. When you get the camera READY to take a photo you can use that [+/-] button. When you push it you can adjust it to zero (o) normal or to make it lighter or darker.
Sep 29, 2015 | Nikon Coolpix S3300
Is there an auto adjust for this monitor? It seems like everything is washed out - too light. When I adjust the brightness and contrast, pictures, faces are too dark
Is it an old one. The tube ones? There is adjustment on the back of the picture tube. About five of them. You need a flat head screwdriver. Not sure which one, but you can boost up different things. Each color and bright contrast. Gamma.??? Don't touch the wrong thing. If it is doing that then what you got to loose, right?
However, mine was doing that, on an old computer. I thought it was monitor. But it was the video card. Have you tried another one? And the drivers and all? I would do that first.
Dec 17, 2010 | Computers & Internet
I have a ultrak kc552bcn camera with a ultrac cctv lens 7-70mm f1.8 lens on it that goes complete white in the day and is seens ok a dusk and not to bad in low light cant seem to adjust for day use almost...
The toggle switches on the back will turn features on and off...just test cameras during the day when it is really bright, switch toggles one by one off, then back on if it doesn't help. One of those switches will resolve your problem. Otherwise, the lens you have on there may have an aperture adjustment, just turn it...similar to the focus dial, and you will see the picture get darker or lighter depending on your application of the camera. An auto Iris camera eliminates the need for this dial.
Jun 09, 2010 | Cameras
Dark picture
Hmm my dad's old t.v. just cut out on him it took awile to turn on this my be the end of ur tv so this might be a power problem but older t.v. loose there colour on the screen my uncle had a like 10-15 year old t.v the screen was like green when it was light but when u turned of the light or closed the blind's it's picture was ok so try that.
Feb 02, 2010 | Hitachi 53FDX01B 53" Rear Projection...
WHAT IS THE BULB NUMBER FOR THE BRAKE LIGHT ON 2005 TRAILBLAZER
2005 CHEVROLET Trailblazer
Low beam headlamp
9006
9006SU Silverstar ULTRA for Ultra Night Vision - The Whitest and Brightest Halogen
9006ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen
9006EB EcoBright - Your Environmental Choice
9006XV XtraVision Halogen - The Brighter Light
9006CB Cool Blue Halogen - The Whiter Light
High beam headlamp
9005
9005SU Silverstar ULTRA for Ultra Night Vision - The Whitest and Brightest Halogen
9005ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen
9005EB EcoBright - Your Environmental Choice
9005XV XtraVision Halogen - The Brighter Light
9005CB Cool Blue Halogen - The Whiter Light
Parking light
3757ALL
Front turn signal
3757ALL
Rear turn signal
3157LL
Tail light
3157LL
Stop light
3157LL
High mount stop light
Assembly
Fog/Driving light
880
880ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen
893
893ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen
License plate
2825
2825LL Long Life Upgrade: Up to twice the life of the standard lamp
Back up light
3157LL
Front sidemarker
194
194LL Long Life Upgrade: Up to twice the life of the standard lamp
Glove box
194
Map light
194
Dome light
212-2
Step/Courtesy light
194
Trunk/Cargo area
212-2
Nov 19, 2009 | 2005 Chevrolet TrailBlazer
Canon ImageClass MF 6550 prints light text
I mean can you scan a text document with the "photo" option and see if you are still encountering problem. And check this out, he tells how to reset to factory and test scanner. http://www.fixya.com/support/t342579-just_started_printing_blank_pages
Apr 27, 2009 | Canon imageCLASS MF6550 All-In-One Laser...
IMAGE TOO DARK ON GEI GRAPHIC ZOOMER POSTER BANNER SYSTEM
First I would give the optical area a good cleaning --- mirrors, lens, etc.. If this device has the 'slide' adjust for the image quality, the slide may have come out of the holder. Try seeming if the slide is seated properly. If this is the 'thumb / circle ' adjust, the POT ( value adjust on the board) may need to be reset. There is always the chance the the board is cracked or has a cold solider joint (pins) for the adjuster. IF you are inclined, that the cover off and check for crack, if no crack heat and re-solider the pins for the adjust switch.
Dec 30, 2008 | Standard Registar SD650 Color Copier
Sony KP-51WS510 has a haze or back glow that cant be adjusted
It seems U are having no screen voltage.
U need to get it repaired
Rifaa
Nov 10, 2008 | Sony KP-51WS510 51" Rear Projection...
Le40m86bdx picture not sharp
I have a two and a half month old Sharp, LC-19SK24U-W. It was fantastic with fantasic, clear, beautifully colored picture until two weeks ago. All of a sudden, the picture starting getting darker and darker. Nothing had been adjusted from day one when I set up contrast, etc. This comes and goes but most of the time is an issue. I can make it a bit lighter but then it is so fuzzy and grainy it is a very poor picture. Also, while this began, one time the television turned itself off and then back on without a power surger or anything.
HELP!
Jan 09, 2008 | Televison & Video
Pictures are underexposed
When you are photographing scenes with mostly light objects (for example, snow, water, and sand), the picture is usually underexposed (darker than it really is). The camera meter registers the brightness of the scene and tries to set the camera lens and aperture for an exposure based on average brightness levels (18% reflectance) causing it to underexpose, as in the following picture. When you are photographing scenes with mostly dark objects (for example, shade, shadow, and overcast skies), and very few light objects, the camera may overexpose the image, causing it to be too light. If you have a flash on your camera, you can compensate by adding "fill flash" for some extra light. If your camera has an exposure compensation adjustment, you can increase or decrease the exposure to correct for these exposure problems. Increase the number to make the image lighter, and decrease the number to make the image darker. You may want to try a series of shots with different exposure compensation adjustments to get a feel for how much difference these adjustments make.
Aug 29, 2005 | Kodak EasyShare CX7530 Digital Camera
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
94 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
