Question about PfaFF Sewing Machines
An old Pfaff machine has been donated to my project but I cant work out how to insert the needle.
    Sergeant:
    Champion:
  • 240 Answers
If the machine bobbin area opens at the front then the flat side of the needle needs to be facing the back. If the machine opens at the side then the flat side faces into the machine to the right. There should be a little screw to the side of the needlebar to keep the needle in.
Posted on Jun 17, 2009
How do I change needles on the pfaff 145 machine and re-insert them?
Here's a manual for your machine. There is also a needle/thread combo chart you should find helpful. Allow time for it to load... takes a bit.
http://s2.vsmgroup.com/VSM/Pfaff/pfaffmanual.nsf/1fd5659e6f37141041256697003e64c0/666a90d970e3e10f852575f300570b06/$FILE/Pfaff%20145%20.PDF
Aug 05, 2012 | PfaFF Sewing Machines
Needle keeps falling out of Pfaff Creativ 2170
change ur needle bar and also check needle size before insert in it.
Sep 14, 2008 | PfaFF Sewing Machines
My Pfaff 4.0 breaks needles and shreds thread when free motion quilting
a sewing machine I work on last week, I put a new needle in the needle clamp & thought I had it correctly inserted,, but it wouldn't work,, so I went back & checked the needle again & found I had to unscrew the needle clamp screw even more than normal to insert the needle then it work perfectly.
some needles & thread don't work togeather--here's a tip
Cut 6-8 inch piece of thread of the spool you are going to use for your project
Take the needle you are going to use for the project
& insert the thread thru the eye of the needle
& lift one end of the thread to a 45 degree angle
& if the needle is the right size for the thread it will slide down the thread
But if the needle hangs on the thread you need one size larger needle for the thread
also clean under the needle plate where the feed dogs are for lint
& also in the bobbin area for lint & loose threads
Nov 18, 2010 | Sewing Machines
I have a PFAFF 207, with the same problem as above (top thread keeps breaking) but if I lower the tension, the bottom stitch becomes loose???
replace the needle-make sure the needle is inserted correctly
top thread tension 3 or 4
rethread the machine
some needles will not work with some thread-here's a tip
Nov 16, 2010 | PfaFF Sewing Machines
Machine is skipping stitches, possible causes? needle has been changed and machine re-threaded and still skips.
some times the needle & thread are not compatable,, I learned this tip from a needle & thread expert
try & see if it will help you
I would also suggest cleaning out from under the needle plate & also the bobbin area, making sure there is no lint or loose thread
Oct 26, 2010 | PfaFF Creative 7570
Pfaff 260 bobbin thread not picking up
Hi. This can be terribly frustrating, but the most likely cause for the bobbin thread not catching is that the needle is inserted wrong. There is a flat side on the shank of every needle and that has to be facing a specific way on your machine or the needle's grooves can't make the stitch. On most modern machines, it's my experience that the flat side goes to the rear, facing away from the operator, but some of my older machines need the flat side facing to the left or to the right.
Another thing that can cause the bobbin thread not to pick up is a bent needle, but in my experience it's usually the needle not in correctly.
(Cost me $85.00 to find this out!)
Let me know if this works, ok?
Happy Sewing!
Robbie
Apr 01, 2010 | PfaFF Sewing Machines
Needle will not pick up thread from bobbin
Was the old needle picking up the bobbin thread ok? If it was, then there's nothing wrong with the machine. Check that the needle is inserted correctly--there's a flat side on the shank of the needle and where that goes varies widely by machine. Then check that it's threaded properly.
(I once had my needle in backwards and threaded wrong--took the machine to the shop cause I was sure my baby was broken. Cost me $85.00 to find out that on that particular machine the flat side of the needle faces left!)
Let me know if this helps!
Robbie
Jan 24, 2010 | PfaFF Sewing Machines
Pfaff 1171 - inserting new sewing needle
Hello make sure that the needle is a front or side loading in the needle bar. the easiest way is to tell take the the needle with the flat side turn to the right or the left and see if it sides in either way hope this helps
Jan 24, 2009 | PfaFF Tiptronic 2030
Pfaff 796
The needle must be inserted so that the long groove faces you and must be inserted all the way up. If it is in correctly, the left needle will appear to be shorter than the right needle.
Rethread the machine and make sure to thread the needles last.
If this doesn't solve your problem, look at your needle plate and see if a finger is broken, bent or missing.
Sewman7
May 09, 2008 | Sewing Machines
Pfaff hobbylock 794
The needles are changed by inserted the hex wrench into what looks to be holes on the front and left side where the needles go into the machine.I'm not sure what size the hex wrench is but it's pretty small. From the manual,
"Removing Needle: Unplug the machine. Turn the handwheel counterclockwise to raise the needle bar to its highest position. Loosen the needle clamp with the allen wrench and pull the needle out." and
"Inserting needle: When the neddle bar is at the highest position, insert a new needle in the needle holder, making sure that the groove of the needle faces you. Push the needle as far up as it will go and tighten the needle clamp screw." "Removing Needle: Unplug the machine. Turn the handwheel counterclockwise to raise the needle bar to its highest position. Loosen the needle clamp with the allen wrench and pull the needle out."
The machine takes DB x 1, or 1738 needles, and a size 14 needle is recommended.
Hope this helps!
Mar 31, 2008 | PfaFF Hobby 4260
Sewing Machines Logo
32 people viewed this question
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
