Question about American Audio Velocity MP3
Wacky lights, skipping, American Audio Velocity (Silver)
When I turn on my American Audio Velocity (silver) everything lights up weird and flashes. If I disconnect the right side (the cable going from the cd player to the turntable) then the left side goes back to normal and then I can plug the right side in and it will be normal. I have to play a cd in both sides for awhile and let them skip before it starts reading the disc properly. If I let it play a CD for awhile it will start working perfectly fine (sometimes) but, I don't want to go through that every single time I want to use it. Sometimes the problem won't resolve, it will just continue to skip and crackle. Does anyone know what's going on with it or if there is anything I can do to fix this problem? Thanks in advance.
Confused and frustrated.
4 Suggested Answers
  • 1285 Answers
SOURCE: American Audio Velocity CD Players Won't Play Discs
are your cd-r data or audio..(maybe AAV cant play the data disk) make sure its audio can also try wiping the disk with a dry paper towel in a circular motion only (one way)...get any fingerprints /oils off the disk...
Posted on Jun 30, 2010
  • 3 Answers
SOURCE: American Audio Mcd-810 dual cd/mp3 player
i know its the tray belt.because,the same thing happened to player would sometimes say error. or sometimes it would not read any cds.because,the tray would not close shure its an easy fix.i did mine by my self.
Posted on Jan 13, 2011
  • 75025 Answers
SOURCE: This American Audio twin Cd palyer DCD-Pro 310
There are tw possibilities for thei fault witn American Audio. The first one is, trouble with the CD mechanism. If CD try does not engage well into, and the CD 'IN" sensor leaf switch does not engages, the system control IC wont get any CD IN pulse from the mechanism and will behauted. The second one is with voltage, that goes ot the second CD section. There are seperate regulated voltages for both CD sections. As your complaint post indicates, that theere is no voltage now with this section, as no display is there, and Cd tray won't come out, and pitch preference selector LEDs blinks. The fault is actually with the internal circuit, especially to system control section itsef. You have to check all the voltages to that section, by referring to its schematic diagram. Actually, this is a very skilled work as system control section can be considered as the 'brain' of the whole system, and ultimate care should be given when servicing these circuits. A very high quality digital multimeter, capable of measuring all functions including frequency and even waweforms of different test points. I advice you, not to make any repair with this set if you are not sound knowledge in digital elelctronics and experience in servicing such complicated circuit parts. The fault may be simple, but detecting the actual point of fault is a skilled work.
If you think you can, and have confidence; just proceed with. Otherwise get it repaired, either by any well experienced service technician of by the Authorised Service Center for American Audio at your town. OK.
Posted on Aug 26, 2011
Can colloidal silver help in body treatment?
Yes. Colloidal silver can be/is used to treat certain body treatment cases. It involves fungal, viral & bacterial infections. Also, it involves wounds & cold/flu treatment. It has also been used to treat body inflammatory conditions too. You can check this link to get more details about it soci?t? Katharos
Jun 13, 2017 | Health & Beauty
What is the wideness of the strap? I want to change it, and I don't know which strap's size should I buy.
At the point where the strap attaches to the watch - take a ruler (with metric on it) and measure the mili-meters (MM's) between the LUGS (points of attachment). That will give you the size of your band.
Dec 09, 2014 | Casio American Apparel Womens Silver...
American audio velocity cd not eject
Check its loader mechanism. Check loading belt, and loading motor. It will be best to replace its loader mechanism, as it is an easy to get part. Won't cost more, and can be purchased from most of the electronic spare part selling shops at your town.
Apr 16, 2012 | American Audio Velocity MP3
Jun 28, 2010 | American Audio Velocity MP3
Tower turns on but nothing else does! Not the monitor, keyboard
Inside the case there will be a small Silver battery its only flat and not that big But if that dies then pc is unable to store boot up date even if pc isnt plugged in
So Replace that battery Put side case back on the pc Then plug in and turn on, It should boot up without any bleeping. And once replaced them battery's last for ages .
Jun 27, 2010 | Velocity Micro Edge Gaming Desktop PC ...
When I power up my HP 1220C printer, the power light goes on, it makes some noises and turns the drive rollers. Nothing else - the cartridges stay over to the far right. Then the feed rollers stop and the...
Jun 15, 2009 | HP DeskJet 1220c/ps InkJet Printer
Drive case flashes
The first thing you need to do is figure out if it is the Hard Drive itself or the enclosure.
The best way to do that is remove it from the enclosure & test it either in a PC directly or in another enclosure. If it works, then you can test the enclosure by inserting another Hard Drive & testing it. This should tell you which component is bad.
May 14, 2009 | Thermaltake Silver River 3.5" Encl Silver ...
  1. press and hold the "clock" button. The time should start flashing.
  2. Adjust the hour by using the square silver buttons for "skip backward" or "skip forward" on the CD controls.
  3. Press the "clock" button again so that the minutes are now flashing.
  4. Adjust the minutes with the same buttons used to adjust the hour.
  5. Press the "Prog Set" button to conclude the process.
Oct 27, 2008 | RCA RS2620 Single Cassette Deck
Over exposed
I just fixed mine. Part of the shutter got stuck, so it was taking in too much light from outside.
You can see if this is the same problem by looking in your lens and zooming in--see if anything looks weird; you should just see a reddish circle in the center of the lens.
I had to take the silver piece off that says "Olympus lens" and whatnot, then turn the camera on and use something ( in my case, a twist-tie) to push the stuck part of the shutter up, through an opening under the removed silver piece. My pictures now look fine as they did before.
To remove the silver piece, just turn it with your fingers counter-clockwise with the camera off.
Hope this helped a little. My warranty is gone anyway so I had nothing to lose. I'd send it back if you still can before doing this.
Apr 27, 2008 | Olympus FE-210 Digital Camera
American Audio Velocity MP3 Logo
124 people viewed this question
Top American Audio Audio Players & Recorders Experts
Gil Shultz
Are you an American Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
