Question about Akai LCT2721AD 27 in. LCD Television
My Akai LCD TV/Dvd player will not turn on
My Akai LCT TV/Dvd player will not turn on unless I unplug it and then plug it in and push the TV on button immediately.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 64 Answers
Http://www.fixya.com/support/t1661054-akai_lcd_tv_power_light_stays_red_turn
Posted on Sep 09, 2009
TV won't turn on
It sounds that, the memory IC to your TV has damaged. This IC can be located very near to main system control IC. A very small one, with 8 solder terminals. Even though it is very small, function of it while the TV works is great. The work is a semi-skilled one, and you must have some knowledge in electronics to proceed.
Jul 09, 2012 | Akai Televison & Video
AKAI 32" Power Malfunction
check all 1000mf-16v & 470mf-16v in power supply. may be blow.
May 06, 2010 | Akai LCT2662 Television
TV will not start easily. Akai LCT2721AD
You only have to unplug it for 30 seconds. Also, make sure it does not have a DVD in it when you turn it off as the TV will try to default to the DVD all the time. Resetting the power (I use a surge protector) allows it to turn back on normally. Based on the comments I've seen this TV has terrible sound with DVD, doesn't want to turn on, and is hard to mount on a wall.
Nov 18, 2009 | Televison & Video
I have 32" akai that won't turn on - it is plugged in
I had the same problem witht he same tv that was given to me! I just took off the cover to the DVD player and unpluged all the connectors to it and then the TV worked. Now you will not be able to use the DVD player but you can hook one up externally
Oct 23, 2009 | Akai LCT3201TD 32 in. LCD Television
Akai lct 2070 tv switch does not turn on tv-no sound-no tv
Most failures on this TV are due to defective power supplies. If the TV does not turn ON, you should replace the power supply.
Check this website to buy the power supply adapter and hopefully that should fix the TV.
Jan 21, 2009 | Akai LCT2070 20 in. EDTV-Ready LCD...
Akai LCT 26AE Universal remote codes for RCA remote
i cannot find the model # to my akai tv/dvd combo where is it? AND ALSO I DO NOT HAVE THE REMOTE TO IT LOST IT DURING MY MOVE. HOW CAN I PURCHASE I NEW REMOTE OR WHICE UNIVERSAL ONE SHOULD I BUY! PLEASE HELP
Nov 02, 2008 | Akai LCT2715 27 in. LCD Television
Akai tv
The power supply most likely failed on your LCD.
How old is your LCD?
Jul 26, 2008 | Akai LCT3201TD 32 in. LCD Television
AKAI LCT 2715:
Its busted. Try resetting it as a last resort, unplug the AC, wait 1 minute, then plug back in. If that doesn't work, its in need of professional service.
Jul 17, 2008 | Akai LCT2715 27 in. LCD Television
Progressive scan
Approach 1: Try unplugging the DVD player from the wall for an hour, then plug it back in. It may or may not reset to the factory default settings, which might put it back to "interlaced" output.
Approach 2: When a DVD player is switched to progressive scan, it uses outputs different from the coax cable "TV out" and the COMPOSITE outputs (often yellow, white and red RCA jacks. If you have the proper cables, you can connect them to both the DVD player and the TV, then cycle through the AKAI TV's "source" settings to switch the TV to the new cable input location.
For example, if the DVD player has "component" outputs (marked Y, Pb, and Pr) hook up RCA plug cables between those jacks and the AKAI TV's Y, Pb, and Pr jacks. Connect the Y to Y, the Pb to Pb, and the Pr to Pr, of course. The LCT3285TA has two sets of these jacks. Either will do, but note if you use YPbPr1 or YPbPr2. Once this is done, push the source button on the side of the TV (or on the TV's original remote) until it shows YPbPr1 or (...2 if that's what you connected). If the DVD player is on, you should now see the DVD menu or the picture from the DVD. Now you can use the DVD remote to switch back from progressive to interlaced video. The picture may go blank at this step.
Now push the TV's source button again until you see "3" or whatever channel you had been using in the upper left of the TV screen. You should see the DVD output picture (menu) again. Back to normal.
If your DVD player doesn't have YPbPr connections, it may have a HDMI or DVI jack.
The AKAI TV also has a HDMI input, you *could* get and HDMI cable (or DVI to HDMI cable if the DVD player doesn't have HDMI), hook it up, then cycle through the TV's source inputs until you see the HDMI in the upper left... in the manner I've just described.
Final Note: The progressive scan output of your DVD will actually give you a much better picture on your AKAI TV than its interlaced output. To take advantage of that, you'll have to hook up YPbPr or HDMI cables between player and TV and switch sources when you want to watch DVDs instead of TV programs. You may need additional cables to send the stereo audio output from the player to the TV for the progressive source hookup.
Jan 05, 2008 | Akai LCT3285TA 32 in. LCD Television
sounds like the pwr supply is suspect....
Oct 23, 2007 | Akai LCT2721AD 27 in. LCD Television
Akai LCT2721AD 27 in. LCD Television Logo
289 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
