Question about Sikes Cookers CK300 Grill
Need Manual for Sikes 3 ft Cooker
I recently acquired a used Sikes 3ft. Portable Gas Grill but no manual. Am having a problem regulating the flame. Anyone know where I could find a manual for this?
  • 867 Answers
No manual needed, to much preassure means the preassure regulator is shot(the round thing on the supply line). not enough flame is usually a corroded burner
Posted on Jun 17, 2009
Out Door grill flame.
replace the gas regulator
check for blockages in the gas hose
Jun 15, 2016 | Grilling
Adjusting Air/Gas mixture on a Glem Gas cooker
The only change I know of is a jet change, from bottled gas to natural gas . it may pay to have the regulator pressure checked .
Aug 03, 2015 | Kitchen Ranges
Grill is one old and won't light. There is no gas coming from the tank to the grill. Is it the regulator?
age of the grill is irrelevant, i am old and i still can do few thingzzzz...
i assume that your regulator is connected directly to the bottle, then hose to your bottle, then hose is connected to the regulator and other end to the grill?
or it is bottle, hose, regulator, grill?
you need to follow the path regardless, be outside, light breeze is better, no open flame in at least 20m (yards) radius in any direction.
1. close gas bottle/tank
2. disconnect, everything from the bottle
3. crack open tank valve and hear if gas is escaping, close valve back
4. connect regulator to the bottle and again crack open the valve, hear if you have esacping gas, allow actually whiff of gas against your cheek or wetted finger to establish the flow. close the valve
5. connect hose to the regulator (procedure is reversed if first is hose and then regulator), crack open the valve, hear for escaping gas, check against wetted finger and cheek if there is flow, close the valve
6. connect your grill open all valves on it and open valve on the tank/bottle. allow free flow for about 30sec, close valves on grill. vent grill for about two minutes, try to ignite any of the burners. if burner ignite, you solved the problem, if they do not, and you did have flow on all previous stages, close bottle valve, disconnect everything from grill, clean grill valves and nozzles (burner have nozzle inside!), reconnect and vent again, try ignite, if ignition occures, you solve the problem, if not, then you are due for new grill...
if at any stage you do not have gas flow, this meant that this particular piece of equipment is in trouble, this particular piece of equipment need then repair or replacement, under no circumstance pull apart the reducer! NO OPEN FLAME DURING TESTING!!!
Jul 27, 2010 | Weber Q Grill
Inadequate flame and heat
I'd change the regulator, clean the burners and the surrounding area. Make sure that the air intakes around the burners aren't blocked , plugged..
Also check the gas orifices for cleanliness... outdoor grilles are nutorious for bug hotels... these little critters move in, lay eggs and it can screw up the burners, orifices... I've several times needed to remove orifices to clean the inside of mini spider nests... Look them over closely..
Jun 01, 2010 | Weber Genesis Silver B Grill
Dual fuel thermos m#461262006 swicth back to propane
You can get the manual on the link below. Make sure you have the right regulator for the propane and not one for Natural Gas.
http://www.managemylife.com/mmh/lis_pdf/OWNM/L0807110.pdf
Apr 28, 2010 | Thermos Stainless Steel Gas Grill
No Gas Getting to Back Burners
sounds like you have debris in the gas regulator,remove the tank and look into hose end to see lf its clear.sometimes just tapping lightly on the reg,will release the debris.u may need to replace hose and regulator to burner assymbly.if this doesnt fix it.
Apr 13, 2010 | Weber Genesis Silver C Grill
MY PORTABLE GAS WEBERHAS A WEAK FLAME FROM THE
The regulator is probably bad and nees to be replaced.
Jan 01, 2010 | Weber Gas Go-Anywhere Grill
Yellow flame from all carryover tubes. This grill is brand new
if the unit is running on natural gas, this is not unusual. if running off propane tank something is wrong with the regulator
Jul 05, 2009 | Char-Broil CharBroil Master Flame Gas...
Heat is about low or just a little higher on high setting
Low flame, low temperature, yellow flame: This has become the biggest problem with many grills these days and it's almost always because of the regulator (the funny UFO shaped thing on the gas hose). Regulators seem to be stickier these days and when they stick you don't get enough gas to generate a good grilling temperature. To get your regulator unstuck you need to release the pressure on it. Follow these steps exactly:
  1. Turn off the gas at the propane tank
  2. Disconnect the gas line from the tank
  3. Open the grill lid
  4. Turn all control valves to high
  5. Wait for about a minute
  6. Turn all control valves to off
  7. Reconnect the gas line to the tank
  8. SLOWLY turn on the gas at the tank
  9. Light the grill normally
  10. Your grill should now heat normally
To keep the regulator from sticking again make sure that you turn off the control valves first, then turn off the tank valve. Always open your tank valve slowly. If this doesn't work give it a second try. If you still have low flame then you probably have a faulty regulator that will need to be replaced.
May 24, 2009 | Kenmore 774 sq. in. Cooking Area Gas Grill...
Need owners manual, Perfect Flame Grill, Model #E3520-LPG
I have a perfect flame gas grill E3520LPG and it takes a hour for it to heat up
Apr 11, 2009 | Grilling
Sikes Cookers CK300 Grill Logo
178 people viewed this question
Top Sikes Cookers Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Marvin
Marvin
Are you a Sikes Cookers Grilling Expert? Answer questions, earn points and help others
