Question about Dell 964 All-In-One InkJet Printer
The exit tray scensor is broken - Dell 964 All-In-One InkJet Printer
  • 523 Answers
Try to put any paper or any plastic thing where the sensor is broken so you can cheat the machine, and it will work
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
Posted on Jun 17, 2009
How to output bin empty ?
  1. The output bin may be full. Empty the output bin. Printing resumes automatically.
  2. Take a close look at the flaps hanging out the exit of the printer. They should move up and down freely. If one of them is stuck up, broken or dislodged, then a bin full error is displayed.
  3. Open rear exit tray and power on the printer. If the printer comes to a Ready state, close rear tray and try printing.
  4. Clean the paper path below the toner area and exit assembly at the back of the printer. Ensure there is no pieces of paper stuck in the paper path of the printer.
Jan 20, 2015 | HP LaserJet 5200 Printer
Red flashing light still on even after replacing p4014n catridge
Could be a paper jam inside the machine(pick up: between the tray and cartridge compartment or EXIT: Between fuser and EXIT UNIT.
ALSO could be BAD SEPARATION ROLLER IN THE PAPER CASSETTE TRAY and UPPER SEPARATION ROLLER OR BROKEN FUSER. Question? call 917-359-7432
Jun 10, 2014 | HP LaserJet P4014n Printer
Error code sc726 savin copier 2545
SC726 indicates a finisher shift tray malfunction.
Nov 02, 2009 | Ricoh Aficio 1035 Copier
Standard top bin full remove paper
Greets!
Firstly, is the exit bin full of paper? If it is, just remove it.
If not, then it's going to be a sensor that recognizes the paper amounts in the exit tray. Check for broken plastics and possibly stuck plastic flaps in the exit tray.
If it's neither of those, try turn it off, unplug, then reverse.
Other than that, if no go, then it's an internal sensor issue. At that point, probably the best bet is to replace as repair costs would outweight a new unit cost most likely.
Feb 26, 2009 | HP LaserJet P3005 Printer
Paper exit tray broken
ebay might have another printers like yours that you can buy cheap
.r got to dell there's a phone no for customer service there. and if it looks like it was installed at the factory it might be part of the printer case.
Jan 11, 2009 | Dell 962 Photo All-In-One InkJet Printer
Hp 3800dtn standard top bin full remove paper error
Maybe your paper sensor flag is stuck or broken if you pull the tray out of the machine there should be a little black plastic sensor flag hanging from the top middle of the slot where you pulled the tray out from if its stuck up or broken the tray will always sense its full of paper.
Jun 20, 2008 | HP LaserJet 3800dtn Printer
Brother HL2030 laser printer. Paper jam, single sheet in machine, I do not have instruction booklet. Paul Bentley
There are several sensor flags along the paper exit route, if
any one of these flags stick or have broken the printer will
take the paper so far then shows jam.
remove the drum unit first then the paper jam, look directly
into the printer to where the drum unit sits and check to see
if one of the flags is sticking up-rite in the centre area.Its spring
loaded so as you push it back, it springs forward again thats ok
Remove base paper tray:
The other flag is at the rear and can be accessed by opening
the rear door and then by opening the inner paper exit ***'y
you can then see the flag on the exit ***'y,this is also spring
loaded. If any of these are out of place/stuck or broken a paper
jam will always occur.
let me know what you find!!
mongrelken
Jun 07, 2008 | Brother Office Equipment & Supplies
Output tray is full
Hi, there must be an actuator of the output tray sensor.It is placed above paper tray, just in place when paper exit from machine.Try to clean sensor,or to place actuator in proper place-pull it down.Also,maybe is actuator broken.
Apr 03, 2007 | Xerox Phaser 7700DN Laser Printer
LG DVD+RW door won´t close
Deliverance
this problem can happen if tray-in sensor not sense. their r a small liver which press tray in sensor automaticly when tray stay inside. liver and sensor location is near emergency exit hole (when u use a pin for emargency exit actually u press this liver then it release try-in sensor). check this liver and its path any pice of cd is their or not. (to check open ur drive cover. to open it at first use emeargency exit hole to open tray then open cover)
Dec 19, 2006 | LG (GSA-4120BK) DVD±RW Burner
Dell 964 All-In-One InkJet Printer Logo
66 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
