Irons Logo
A
Anonymous Posted on Apr 11, 2014
Need to disable or fix auto shut off - Sunbeam Irons
Angelia Saucier
Level 1:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Contributor 66 Answers
  • Posted on Mar 27, 2015
Angelia Saucier
Contributor
Level 1:
New Friend:
Cheetah:
Answers
66
Questions
6
Helped
24487
Points
82
How to disable the auto shut off switch?
You can't. it needs to be repaired.
Shark g1468 auto shut off (iron won't come/stay on)
First let me say I HATE AUTO SHUT OFF!!! It sounds like it has wore out. the computer part that tells it when to shut off it not working. It would be cheaper to buy a new one vs fixing yours. If I were you, find an older iron that has LOTS of steam vents and NO AUTO SHUTOFF at your local goodwill, thrift store or garage sale.
2answers
Iron with auto shut off will not restart, why?
The thermostat is the problem, I used aew3656's solution posted elsewhere, and took care of the same problem on my steamer, just take out the damaged thermostat and use it as a sample to get a new one from any electronics supply store, BTW dont forget to buy thermal grease, it helps dissipate the heat so your steamer won't overheat, and the thermostat wont't go off every 2mins.
1helpful
PS-200 Iron with Auto Shut-off: Can you really fix problems with a steamer? Is ...
The thermostat is the problem, I used aew3656's solution posted elsewhere in FixYa, and took care of the same problem on my steamer, just take out the damaged thermostat and use it as a sample to get a new one from any electronics supply store, BTW don't forget to buy thermal grease, it helps dissipate the heat so your steamer won't overheat, and the thermostat wont't go off every 2mins.
2helpful
My iron will not stay on.
that is probably the auto shut-off in the iron causing it to turn off, check the manual for how to disable it
4helpful
2answers
Rowenta DM880 Auto shutoff - Shuts off too frequently
This is a problem with a lot of Rowenta irons. It is the auto shut off that is not working properly and the only way to fix it is to have it disassembled and the switch hardwired to be on whenever the iron it plugged in. It is a thermal metal switch and it just stops working and then the iron will not turn on and the yellow light blinks.
3helpful
The light is on...but no heat at all?
1helpful
Premature shutting off
the only thing you can do is change out the motion sensor which is 1n the machine or disable it
Apr 21, 2008 • Irons
Iron Shuts off Automatically when using iron.
The cord is broken...
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Top Sunbeam Irons Experts
ADMIN Andrew
ADMIN Andrew
Ngoro
Are you a Sunbeam Iron Expert? Answer questions, earn points and help others
