Question about Ertl 580 Super M Series II Tractor
How to adjust brakes on a case tractor - Ertl 580 Super M Series II Tractor
  • 110 Answers
Which tractor??
Or is it a backhoe?
Posted on Jul 02, 2009
Parking brake does not seem to hold on moderate incline. Footbrake will sometimes not stop the machine. Are there any known issues with braking on X320
Most all mowers and tractors have mechanical brake rid adjusters..just follow the linkage from the pedal to the brake rigging...you should find some adjusting in the linkage...good luck..
Sep 03, 2015 | Garden
Case tractor
the brake come apart, worn out, or need adjusted.
Dec 05, 2013 | Garden
Adjusting brake on Craftsman LT 1000 lawn tractor manual
underneath by the right side tire turn in the adjustment nuts on the brake rod. if brake is bad the disk will have to be replaced see a manual.
May 02, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a model 1691931 12LTH36 the brake did not work or was stiff at first. Adjusted according to manual, pedal does not release and brake is stuck and still not working properly. brake spring is rusted,...
Standing behind the tractor, look under the RIGHT
rear, between the tire and the trans case. You will see a small brake disc protruding slightly from inside a brake caliper.
1) Remove the cotter pin, nut, flat-washer and plate in the center of that assembly. You should now see a threaded stud in the center, the ends of two round pins on either side, and two bolt-heads on the outside.
2) Pull the two pins out with pliers. clean, wire brush and grease these two pins. DO NOT remove the two bolts on the outside.
3) Reassemble in reverse order and use the center nut to adjust. A small adjustment goes a long way here.
4) Test brakes with rear tires off the ground in a SAFE manner, while still using the center nut to adjust.
5) Once you have good brakes and good release without any load on the tires, set the unit down and test ride... make final adjustments if needed.
Hope this helps!
Oct 01, 2009 | Garden
My mower brakes do not work
The adjuster is on the right side just in front of the rear wheel. its the clutch rod / brake rod . you will see a spring on the shaft with two nuts one used to lock the adjustment. loosen the nuts and turn the nuts so the nuts go towards the back of the tractor. keep checking the peddle for brake .
Sep 17, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Clutch/brake adjustment
adjust clutch
Jul 06, 2009 | Garden
Need to adjust brake/clutch 14hp craftsman lawn tractor
The brake is on the right side of the transaxle. There are two mounting bolts and one 1/2 nut in the middle that is your adjustment. Tighten it 1/2 turn at a time and hold the brake down and try to roll it until it holds.
Jun 09, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Toro lawn tractor : tractor will not start
On most riding mowers there are several switches that must be actuated before it will start. First, make sure that blades are disengaged. Also, if there is a handle that engages and disengages the blades, you might try holding it in the dis-engage position in case the switch is out of adjustment. There is probably one under the seat also. This switch kills everything if you are not sitting in the seat for safety reasons. The switch here could be out of adjustment or mis-positioned. Also, make sure the parking brake is set, and the gear is in neutral, and not forward or reverse. Also, even if the parking brake is set, you might try pressing the brake all the way down while starting, as this switch might be out of adjustment. All of the switches should be easy to locate and adjust. Also, you should check the battery. It is possible that you left the key on by mistake and drained it.
Hope some of this helps.
C
Oct 03, 2008 | Garden
Ertl 580 Super M Series II Tractor Logo
1,914 people viewed this question
Top Ertl Toys Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Ron Knox
Ron Knox
Level 1 Expert
Are you an Ertl Toy Expert? Answer questions, earn points and help others
