Question about HP Officejet Pro L7680 All-In-One Printer
HP 7590 office jet pro scanner does not communicate
Set up wireless and print function works fine. Fax function works too. Receive an error message - no scan options when pressing scan operation button on HP machine. Previously received a 'no communication' message.
  • HP Master
  • 1,684 Answers
The scanner function is not available when you are connected wireless, you must be connected via USB to your PC for the scanner to function correctly.
Buddy
Corporate Computer
Over 21 years of PC and printer support/repair
Posted on Jun 18, 2009
Sorry I was wrong about the number on the computer but the question is the same how come I can't print or fax ?
Do you receive any type of error message? It seems for some reason your wireless printer is not communicating with the PC/laptop. Also, printing and faxing each require different forms of communication. In printing, you PC is just telling the printer to print what is on the screen; faxing requires the use of a phone line that needs to be set-up properly. Although the wireless setup btw the printer and PC must be working first.
Try uninstalling and reinstalling the software with the printer not plugged into the PC until the software is installed. Also, reread your manual carefully for insights about your issue.
Mar 25, 2015 | Dell All-In-One Wireless Printer V515w -...
My Hp office-jet Pro X576 printer is connected via a network and if l send a print job it displays printer error switch off machine and the printer restarts .if l use usd it works fine
I would ensure that you have the current firmware installed on the printer and make sure that you are sending the job via network with a correct driver. If you manually set the IP address on your computer and the printer you should be able to connect direct using a crossover cable, I do that in the shop all the time.
Dec 11, 2014 | HP Officejet Pro X576dw Network-Ready...
Can I received fax on my pc for my HP office Jet Pro 7580L
Hello.
The Fax can only be received and printed from the unit.
If you have a 56k modem in your PC with a phone line input you can set up a fax through windows. Simply go to control panel, printers and faxes and follow the instructions to install a fax driver.
Then you can receive the fax directly to your PC without having to go through the HP Printer at all.
Regards GM
Aug 01, 2011 | HP OfficeJet Pro L7580 Color All-in-One...
Receive message "cannot install" after
Good day. If you're getting this kind of message there's a big possibility that your installer for hp office jet pro is already been damaged or got corrupted. What you can do is to download another driver to resolve the problem.
You can download this driver scanner so that once it is installed on your system if will automatically update or install the driver for your hp. Here's the link
http://drivers-driver.com/hp-officejet-pro-l7700
remember:
1. click download now
2. then install
3. then run the driver scanner and just follow the direction to fix the driver for your hp office jet
If you think that it didn't resolve your issue you can just uninstall it from your computer.
Hope this help you a bit. Have a great day.
May 23, 2011 | Computers & Internet
I need a test fax to see if i can receive on my hp office jet pro 8500.
Send a one page black and white text fax to 1-888-hpfaxme (1-888-473-2963).
When your fax is received by the HP Test Fax Service, It will generate a return fax to you within five minutes confirming that we received your fax. This verifies that you can both send and receive a fax with your fax machine.
Thank you for contacting FixYa Team
* Please rate this solution with Thumbs up and comment to help us improve providing support
Nov 13, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
Will not receive incoming fax. Everything tests OK
First, Connect the Phone line in Line 1 EXT at back of printer
Check the No. of Rings on your Answer machine.
If you have 4 Rings set on Answer machine then you need to set 6 Rings on the printer ( as simple 2 rings more than your Answer machine )
And you need to turn off ECM on the Printer setup
Press Setup button
Scroll till you find Fax Settings - Press OK
Choose Rings to Answer - Set it - 6 ( based on the Rings on Answer machine ) - Press OK
Check for ECM - Error Correction Mode - Press OK
Turn it OFF - Press OK
Check for Auto Answer option - Turn it ON too.
Try to receive Fax.. it should come thru.
Jul 01, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
I need fax confirmation sheets printed when I fax from my HP Office Jet 8500. How do I get them to print?
on the printer itself --> press the setup button--> use the arrow keys on the printer and move to print report option --> press ok when you select print report--> Find out fax confirmation option and press ok --> turn it on.
If you do not find the Fax confirmation option under print report then find it under Tools option.
Press setup on printer --> press arrow key on printer and finid tools --> under that try to find the fax confirmation option.
once you switch on the fax confirmation option on the printer. every time you send a fax you will receive a fax confirmation also.
May 05, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
Initialization failed - Unable to acquire TWAIN-compliant device
I have seen your message stating that "Initialization failed - Unable to acquire TWAIN-compliant device" error is received when trying to connect USB-Parallel type to your Laptop.
Well,  Printer  Panasonic UF4100, recommends to use only " Printer/Scanner Interface as Bi-directional Parallel (IEEE1284) " means you need to use Parallel cable to connect Printer to the Computer/Notebook.  You may receive some communication error messages if you are using a  "PORT REPLICATOR CABLE"( USB TO PARALLEL connector).  The error message that you have received is related to the communication error. Futher, if you use same USB- Parallel cable for long time the Printer Hardware functionality might go bad, since Printer memory gets confused and will not read or detect the Cable , since it is not a cable to use  mentioned by Panasonic Manufacturer.
Let me tell you, general functionality of Printer like Printing would work even if you use USB-Parallel cable. But it is not a case with Scanner and Fax functionality.
Hence, I recommend you to use only Parallel cable to connect your Printer to the Laptops.
I hope that this will resolve the issue for you.
You can email me at thumuvikram@rediffmail.com if you need further assistance.
Bye.
Oct 17, 2007 | BafoTech BAFO BF-1284 Parallel Adapter
HP Officejet Pro L7680 All-In-One Printer Logo
976 people viewed this question
Seeker5211
Seeker5211
