Question about Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive
Wd my live duo solid yellow light - Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive
Wd 62628 lamp indicator light is solid yellow / orange what needs to be done
Your lamp cover is not installed. That is what causes the LED to light amber. Remove and re-seat the lamp cover door. There is a switch it hits to tell the TV the door is shut. This is to protect you from electrocution.
Sep 13, 2016 | Mitsubishi 915P026010 LAMP WD-52627,...
Turns on with snow and yellow light under lamp. Why does it shut down after 20 seconds?
yellow steady light is overheating. you have a stuck fan or its all clogged with dust. The only way to fix it is to find what is causing it to overheat or prevent the fan from spinning. It is not lamp related unless you bought a lamp that does not have an Osram bulb inside.
Sep 08, 2015 | Mitsubishi WD-65734 65" HDTV
Blinking yellow light on Mitsubishi wd 57731
Based on the service manual:
Blinking yellow= Lamp cover is open.
It could be something else!
www.aaatvservice.com
Aug 09, 2014 | Mitsubishi WD-57731 57" Projection HDTV
Why is tv blinking 4 red lights and 8 yellow lights
An error code of 48 indicates a main power board failure. There is a short down the 3.3v or 5v switched supply.
recommend replace main power board.
part# 934C409001
see the following website:
http://www.shopjimmy.com/mitsubishi/wd-73c11?cat=59&q=WD-73C11&tv_models=Mitsubishi+WD-73C11
Jul 01, 2014 | Mitsubishi WD-73640 73-Inch 1080p...
Wd-52627 tv turns off on its own,then solid red light
I just replaced my lamp and it worked for a day. TV only gives me sound. Black screen. Light goes from green to red lamp light after about 30 seconds. Did you get a fix?
Jun 04, 2014 | Mitsubishi WD-52627 52" Television
We have a wd 57732 a solid yellow light on when turn tv on message air flow block shut down in few seconds shuts off with two green lights flashing and solid yellow acks as if room temp to warm. sometimes...
The lamp needs to be replaced. It's on the back and easy to do. I replaced mine about 3 months ago and it was about $182.00. Hope this works, I know it's hard to fork out that kind of money at this time but once you do the TV will be as good as new. Take care
Jun 09, 2011 | Mitsubishi WD-57732 Projection Television
Solid Yellow light and blinking yellow status light after bulb replacement. TV wont turn on.
Sounds like Mitsu is getting sued left and right about their DLP problems. There is a potential overhaul if you contact their parts department.
Oct 13, 2009 | Mitsubishi WD-52327 52" Rear Projection...
I just changed lamp on 4.5 year old Mitsubishi WD-62525 without any issues...except the yellow light remains on. Through research I learned I needed to check filter and lamp doors to be sure they are...
Did you unplug the set and see the "new bulb replaced?" screen come up when you plugged it back in? You could try resetting the TV. There's a little access hole you put a toothpick into. Yellow (solid) light means lamp time is over 4000 hrs. This sound's like the lamp life counter needs to be reset.
Sep 12, 2009 | Televison & Video
Mitsubishi tv solid yellow light how to fix
willshar2, by the way... nice tv, your tv chassis is a v33 chassis try the lamp sensor pt#299p313010a it's on the lamp housing,but again i wish you would let your favorite tv guy do the work.
Jun 11, 2009 | Mitsubishi WD-52631 52" Projection HDTV
Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive Logo
799 people viewed this question
Top Western Digital Computers & Internet Experts
Ekse
Alun Cox
Marvin
Marvin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
