Question about Adaptec SCSI Card 29160N [ 1835000 ] (112304)
Adaptec 29160n vista support issue
I have tried to install vista home premium 64 bit on a new pc using my two previous hard drives both are maxtors connected through a adaptec 29160n scsi controller card. Setup would stall at expanding files so i tried an ide drive no problems at all, i have then tried to transfer files from one of the larger scsi drives onto vista (the ide drive) and it completly stalls vista a file as small as 256kb wouldn't even transfer.
Has anyone come across this and have they fixed it
    President:
  • 688 Answers
Vista has a major issue with allowing even the admin to move and transfer files and folders.
I have run across a fix that helped me gain more control, but you probable need to get drivers for Vista from the scsi controler card manufacturer.
and for the drives.
Vista is a terribly restrictive OS.
WARNING: please do not do this if you can't reverse it on your own if needed. Editing your registry can be risky so use extreme caution.
if you follow this it helps.
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Windows Vista Admin Hack
click start and run,
type in regedit
when Registry editor opens
click on HKEY Local Machine
click SOFTWARE
click MICROSOFT
click WINDOWS
click CURRENT VERSION
click POLICIES
click SYSTEM
HIGHLIGHT SYSTEM
in the area where there are values right click and select new/ DWORD
enter "EnableLinkedConnections"
press enter
right click EnableLinkedConnections and chose MODIFY and change the value to 1
Save and exit Registry Editor.
Posted on Jun 17, 2009
What do I need to Switch from a vista 64 bit Operating System to vista 32 bit Operating System?
You'll need an installation disk, but why would you want to invest the time and effort with Vista. Upgrade to Win7 instead (stay away from 8).
Jun 12, 2014 | Microsoft Corporation Microsoft Windows 7...
I could not upgrade neither windows XP, Windows 7 of this Product Model: GT5662. Would you assits? Thanks.
Hello kelvinvu, according to the information that I gathered from this computer model, it has Windows Vista 32 bit home premium installed on it. Windows XP is an older operating system so you can't "upgrade" to it. You could however install a fresh copy (more likely completely erasing all your previous information on vista and data files) or you could upgrade to Windows 7. Since you are using "Windows Vista 32 bit home premium", you have to upgrade to "Windows 7 32 bit home premium" or better. So if you were trying to "upgrade" to Windows 7 Home Basic, it will not allow that since it considers that a downgrade in the Operating System. You should actually be able to pop in the Windows 7 Home Premium CD while vista is running and start the upgrade process pretty painlessly that way. Just access the CD and walk through the menus for upgrading Vista to Windows 7. As a reminder, you must use the 32 bit discs. If you try and use the 64 bit discs (a different operating system as far as windows is concerned) you will have to go through the same process of installing a new version of windows (not upgrade). I hope this has solved your specific problem kelvinvu, have a great day!
May 15, 2011 | Gateway GT5662 Desktop PC
Not sure what happened ,lost parts of my os for vista home premium 64 bit ,no sound, not even beepcodes,no text when atempting restore ,limited control in command promt, still have some stuff ,pictures...
Which do you have - Vista Home Premium or Vista Home Basic? The title of this question category and what you said you have doesn't match. I'll assume you had Home Premium 64 Bit. Yes you can upgrade to Windows 7, 64 Bit. Please be aware that there is the 64 Bit and the 32 Bit versions. Check with your OEM of the computer before you upgrade. In the upgrade process, Windows 7 will create a folder called "windows.old" once the install has completed. There you will find the data you had from the old operating system like pictures and documents. Before you do the upgrade, I recommend downloading and installing the Windows 7 Advisor to check on any software and hardware issues - the advisor will list those problems before you can upgrade so that you can make the corrections.
Dec 17, 2010 | Microsoft Windows Vista Home Basic for PC
I have the photo printer for 4 years, just installed it with original ink cartridges, the printer prints regular text just fine, but in trying to print photos, the photos come out very red with no...
HP Print Diagnostic Utility was created to help users troubleshoot and correct many common problems on Windows-based computers that can prevent printing.Follow the on-screen instructions to run the utility. Details and specifications File name: s.gif HPPDU.exe [1/1, 1.54M] System requirements: s.gif No additional prerequisites Released: s.gif 2010-08-13 Version: s.gif 3.0.0.013 Compatibility: s.gif Microsoft Windows Vista, Microsoft Windows Vista Home Premium (32-bit), Microsoft Windows Vista Home Basic (32-bit), Microsoft Windows Vista Business (32-bit), Microsoft Windows Vista Ultimate (32-bit), Microsoft Windows 7 (32-bit), Microsoft Windows 7 Home Basic (32-bit), Microsoft Windows 7 Home Premium (32-bit), Microsoft Windows 7 Professional (32-bit), Microsoft Windows 7 Enterprise (32-bit), Microsoft Windows 7 Ultimate (32-bit), Microsoft Windows 7 Home Basic (64-bit), Microsoft Windows 7 Home Premium (64-bit), Microsoft Windows 7 Professional (64-bit), Microsoft Windows 7 Enterprise (64-bit), Microsoft Windows 7 Ultimate (64-bit), Microsoft Windows 7 (64-bit), Microsoft Windows Vista (64-bit), Microsoft Windows Vista Home Basic (64-bit), Microsoft Windows Vista Home Premium (64-bit), Microsoft Windows Vista Business (64-bit), Microsoft Windows Vista Enterprise (64-bit), Microsoft Windows Vista Enterprise (32-bit), Microsoft Windows XP Fix/Enhancement: s.gif This version of the HP Print Diagnostic Utility provides an improved user interface in multiple languages, improved diagnostic and problem resolution capability, and support for usb and network connected devices.
Oct 28, 2010 | HP Photosmart 8450 InkJet Printer
Maxtor Mini 4 (250GB) is not supported on Vista Premium 64bit
microsoft tells it's 64 bit compatible:
http://www.microsoft.com/windows/compatibility/Details.aspx?type=Hardware&p=Maxtor%20OneTouch%204%20Mini%20-%20hard%20drive%20-%20250%20GB%20-%20Hi-Speed%20USB&v=Maxtor&uid=&pf=0&pi=0&c=Storage%20Devices&sc=Hard%20Drives%2C%20External&os=32-bit
you have an USB issue
try to download all patches for your 64-bit windows from microsoft
Jun 25, 2009 | Maxtor OneTouch USB (A01B120) 120 GB Hard...
Get windows vista home premium
You can run a 32 bit technology OS on a 64 bit technology platform.
It will run pretty fast.
You just can't run a 64 bit technology OS on a 32 bit technology platform, though the 64 bit OS is recommended on a 64 bit platform.
Love your brother, he did you no wrong.
Mar 30, 2009 | Dell 24x CD±RW/DVD Serial ATA Internal...
Software incompatibility on my acer aspire6930-6455
Well, we wont know until you try. In my opinion, your 32/64 bit issues will be solved, but you would still have the normal vista/xp compatibility issues.
But that is to be expected, like when we all upgraded from win98 to XP.
So - I would recommend downgrading to Vista 32 bit, or getting the 64bit software version of the programs you want to use.
Good Luck, and let me know what you did, and how it turned out! :)
Jan 07, 2009 | Acer Aspire AS6930-6455 16" Notebook PC
I purchased a Gateway LX-6200 with Vista Premium 64-bit tonight and my problem is that it won't recognize my I/O Magic 250GB "Gigibank" external hard drive. It worked earlier this evening when I loaded all...
Did you load software ? You have a 64 bit Operating System (OS) and MANY companies don't make 64bit software. 95% of PCs are 32 bit. This is same problem other external drive makers are having, Vista 64 bit was sold as "typical" PC when it's for very powerful users. Many "drivers" that talk to the equipment must be written for 64bit software. Check the companie's site to see if it's VISTA 64 bit compatible. Bet it's not ! !
Nov 27, 2008 | IO Magic Corporation GigaBank (I250HD35)...
Adaptec SCSI Card 29160N [ 1835000 ] (112304) Logo
249 people viewed this question
Top Adaptec Computers & Internet Experts
Rommel Balcita
Robert Graf
Timothy Van Der...
Are you an Adaptec Computer and Internet Expert? Answer questions, earn points and help others
