Question about Acer Aspire 3000 Notebook
What is the driver for e735 mouse pad - Acer Aspire 3000 Notebook
A small orange light is on showing on the mouse pad and cursor won't work. If I use a conventional mouse, it will make the cursor move
Hi
It look like your mouse pad has malfunctioned, or the drivers have not been loaded during the boot process or the drivers are corrupted. To update the drivers go to device manager in control panel and right click on the mouse pad device, click properties at the bottom of the menu that comes up and click on update driver and this should then make the mouse pad work unless it has a fault.
Cheers
Sep 28, 2014 | Computers & Internet
Mouse touch pad not working
Try to Upgrade your Mouse Pad driver.
Your problem would be solved by doing so.
I have faced the same problem. I did upgrade Mouse Pad driver and Yes my mouse pad working fine.
Apr 24, 2013 | HP EliteBook 6930p Notebook PC
I HAVE BLOCKED MY CURSOR ON ACER LAPTOP BY MISTAKE
When your mouse pad is not functioning, it's hard to get most anything done on your computer. The fortunate side to all this is that getting a mouse pad to work again on a laptop is not an overly complex procedure. A few troubleshooting techniques will quickly lead you on your way to productivity again.
Examine your mouse pad. Dirt and grime can affect performance and slow down mouse sensitivity, if not shut it down altogether. Make sure the surface of the track pad is clean and that there is nothing that has managed to get beneath it or around any trackball buttons that could affect the pressing and depressing of the component. Check to see if your mouse pad has been turned off. If the Fn (Function) button at the bottom left of the keyboard is pressed in conjunction with some other key on the keyboard it can result in the disabling of the mouse pad. To enable your mouse pad on a Windows PC go to the Control Menu. Under the Printers and Other Hardware option, click on Mouse. Then, click on the tab on the top of the pop-up menu that says Device Settings. The touch pad for your computer should come up as a selectable option. Click on it and you will see the option to enable your device, then click OK. If this does not work, proceed to the next Step . Check the manufacturer of your laptop (for example, Toshiba) and then navigate to their official website. Find an area for Software and Drivers, and move on to that area. Enter your laptop number (check your documentation/manuals and/or the bottom of the computer) and look through the drivers that are presented as a result of this number input. It could be that your mouse pad simply needs updated drivers. Find the driver that corresponds to your computer and mouse pad (for example, most Acer laptops use a Synaptics touch pad). Then, click on download. Once the drivers have downloaded, double click them to ensure they install, restart your laptop, and your mouse pad should be working again. Hope this helps.
Jan 08, 2013 | Acer Computers & Internet
CURSOR IS BLOCKED
Jan 08, 2013 | LG X-Note LM50 Notebook
How di make my mouse work
usb mouse or mouse bad ?
Look at the type of mouse you have.
To date, there are three types of mice: the USB mouse, the PS/2 mouse and the Bluetooth mouse.
USB mice connect with a USB adapter, which has a rectangular shape. Conversely, the PS/2 mouse uses a PS/2 adapter, which is round.
Finally, there's the Bluetooth mouse, which has no external adapters.
Plug the mouse into your machine.
Now, how you do this will depend on the mouse you're using.
With a USB mouse, simply plug your device into your laptop's USB adapter, which will also be rectangular in shape.
For PS/2 mice, you'll need to plug it into a PS/2 adapter. Plug your mouse into the PS/2 end then plug the other end into your laptop's USB adapter.
And for Bluetooth mice, no plugging is required.
Install the mouse drivers.
If your mouse is not plug-and-play, you're going to need to install its drivers. To do this, insert the CD or diskette that came with your device.
The installation should occur automatically.
Pair your mouse, if using a Bluetooth mouse.
At this stage, non-Bluetooth mice are ready to be used.
However, if you are installing a Bluetooth mouse, you must perform one additional step: pairing it to your machine.
To achieve this, use your laptop's touchpad and right-click on your Windows screen. Select the option "Pair Device." From there, follow the on-screen instructions to sync your mouse with yourcomputer.
Place your mouse onto a mouse pad. Before using your mouse, you need to place it onto a mouse pad.
This should be done for all types of mice, whether they are wireless or trackball.
Otherwise, movement will be difficult
mouse pad
hope this helps
Sep 09, 2012 | Compaq Presario CQ57-339WM
My touch pad is not working but if i attach an external mouse the curser works. how do i activate my touch pad?
See if you have a driver problem with the mouse. You can check this in device manager. You you see problem, then update driver. If you don't see driver problem just try updating the driver. If this fails then you might have a bad mouse pad. There is a small board that controls the mouse pad. Take to local shop to have it replaced. Good luck
Feb 25, 2011 | Computers & Internet
I have compaq 610 laptop window7 . frequently external usb mouse stopping to work as well as showing that one usb device attached with this computer, window is not recognising it. By clicking i knew that...
hey Windows 7 stated, first time here in days, nobody ever tells OS.
you are a winner for savvy award 1000
old relic COMPAQ LT.
your LT now has 2 mice, and if you run 2 mice what happens
they try to get in a fight.
we must shut off the mouse pad first.
I guess this mouse is a MS mouse, no mouse name stated.
I shut off the mouse pad in device manager.
look for the USB mouse not, is this unstated mouse wireless, if yes a new battery is now needed. and matching usb dongle.
now plug in the mouse. PC goes DING donng.,
and it loads a driver
be in the internet to W7 can find the driver.
if still dead, go to device manager,
see that mouse there under. mice and other pointing devices
mine shows, HID mouse here.
if missing , plug the mouse into all USB ports 1 by one and listen for the DINGDONGg (means new USB device discovered)
if still fails buy a new mouse, gee barrow one for a day.
if that mouse works , trash the dead one.
you can not have 2 mice at same time or you get into trouble.
the old mouse pad , we had to use disable in device manager to kill it.
on the new HP we have newer driver and it has this.
" tab, automatically disable pad mouse with usb mouse active"
but old ones dont have this
I too hate pads. when the thumb hits the pad, I want to kill that pad fast.
one ebay a 5 pack of mice is $14
a 5 year supply, all mine fail in 1year, the wires snap near mouse inside, easy;
Jun 18, 2017 | Compaq Computers & Internet
Touch pad faulty and cursor jumps and cannot read emails, or type replies, using external mouse, but cursor will wandering. Less tha one year old.
Clean your Pad with a moist wet tissue and dry.
In Control Panel -> Devices manager -> uninstall the mouse/pad driver and either use detect new plug-and-play hardware via the top of the tree in the device manager listing (eg. you Computer name) context menu or simply reboot to force a new re-install of the driver for your Pad and Mouse and see if it solves the problem.
If your Pad is the Synaptic type, install your Netbook driver for the Pad.
Hope that re-installing the driver and Pad utility solve your issue let me know how you go.
ps. Worst case, your Aspire One should still be under manufacturer warranty.
Sep 27, 2010 | Acer Aspire One PC Notebook
No mouse control via wireless mouse, or touch pad
IT SOUNDS LIKE YOU HAVE MAY HAVE DRIVERS OR IRQ THAT ARE CONFLICTING, TRY UNINSTALLING THE DRIVERS FOR YOUR WIRELESS MOUSE, AND REINSTALLING THEM, MAKE SURE THE WIRELESS MOUSE IS UNHOOKED BEFORE YOU REINSTALL THE DRIVERS.
Mar 11, 2010 | Toshiba Satellite Pro L300 Notebook
Acer aspire 5612zwlmi web cam and mouse pad
Mouse pad jumping can be common symptom of Synaptics pads (is it Synaptics?) - look for driver and install it.
Also, try switching it on from off and do NOT touch the pad for several minutes.
Common symptom when people just use very light pressure on mouse pad within first few minutes. Latest driver should fix.
also try pressing whole palm down on touchpad for several seconds - this can reset the software on some touchpads.
As for webcam, disconnect it, uninstall drivers, re-install drivers and then re-connect it. If it is built in then go to Device Manager - Hardware and find the device - click on uninstall driver - then re-install the driver.
Jul 22, 2008 | Acer Aspire 5610-4648 Notebook
Acer Aspire 3000 Notebook Logo
18 people viewed this question
Alun Cox
Steve Sweetleaf
Steve Sweetleaf
