Question about Audiovox Mobile DVD Player Car Video Player
Advent dvd player problem
I have a similar problem, a new clean disc won't play-"bad disc" display, and a few of the old scratched discs will play! Mine is a advent car dvd player
3 Suggested Answers
  • 9 Answers
SOURCE: my advent car dvd player will not play movies
That not even a real car.
Posted on Aug 24, 2009
SOURCE: Advent DVD player in car won't eject DVD
Same problem for me, but believe it or not, we tapped on the DVD player with our knuckle (not bang on it) then hit eject and the disc came out.
Posted on Mar 03, 2010
Dvd player will not play dvd disc keeps saying cannot execute command
Some DVD players may display a Check Disc error.
Use a soft cloth to clean the disc; the disc may have fingerprints or smudges.
Examine the disc for any cracks or scratches that might be interfering with playback.
If attempting to play a DVD-R, DVD-RW or other recordable DVD format, make sure the disc format is compatible with the DVD player. For more details
Professional Quality Bulk DVD Replication Services Scotland UK...
Jan 12, 2014 | Element Electronics EDBCO11 Blu-Ray Player
I have a sony blueray dvd player. When I try to play a disc, "no disc" comes on the screen. What do I do?
Well I assume you are placing a Blu-ray DVD in it right?
*See if the disc is not scratched .
*clean the disc with Banana, windex, and toothpaste (it worked on mine)
* try it a few times and see if it works
Sep 03, 2013 | Sony Video Game Consoles & Games
The dvd player will not read the disc
If it won't read any disc you put in, consider getting a new DVD player, the eye is most likely gone bad. If it is only one disc that you can't read i would suggest a Scotch DVD Cleaner kit. Cleans and Repairs discs, helps prevent skipping and mistracking, and repairs minor surface scratches improving disc audio and image quality.
Jul 28, 2011 | Cyberhome CH-LDV1010A Portable DVD Player
It says unable to read disc when i put the game in.
Please Rate me!
What Is It? The Disc Read error is a simple one. It simply means that the Xbox is unable to read the disc that you have placed in the drive. In the majority of instances, this error has nothing to do with the functionality of the console, but, rather, hinges on the actual disc that has been inserted into the DVD tray.
Disc-Related Errors The most common reason for Disc Read errors are related to the disc itself. Numerous conditions can keep the laser from reading the information contained within the game, DVD or CD in the DVD drive.
  • The disc is scratched - Game discs, audio CDs and DVDs can become scratched very easily. Usually this is because they have not been kept in their cases, but left in the open. Simply resting two discs atop one another can scratch the bottom disc. If discs are sufficiently scratched, the data contained on them will be inaccessible to the drive.
  • The disc is dirty/dusty - Dirt and dust can build up on the faces of discs left exposed. When sufficient dirt or dust has built up, it can block the laser beam used to read the disc, resulting in a Disc Read error.
  • The disc is the incorrect region - DVDs come in formats called "regions." These regions match the region specified in the software of the DVD player. Some games also have these regions. If the region of the DVD and that of the player do not match, the disc will not play.
Can I Fix These Errors? Repairing disc-related issues may or may not be possible. If the cause is simply dirt and dust, you can certainly repair the disc. However, if the cause is due to extreme scratching, then replacing the disc is likely your only choice. If the disc is from the incorrect region or from another country, you will have to obtain the correct region. Returning the disc to the retailer for exchange may work.
Non-Disc Related Errors As mentioned, there can be some Disc Read errors that have nothing to do with the disc at all. In this case, it's time to troubleshoot the Xbox.
  • First, simply try to reboot the machine. Often, this will flush the cache or other error and allow the game to operate or the disc to play.
  • Second, try removing the hard drive and/or memory units. Once removed, reboot the console and attempt to load the disc with the hard drive and memory out of the unit. If this works, you can simply shutdown and reinstall the hard drive.
  • Attempt to play the disc in another type of player. For instance, attempt to play the DVD in another DVD player or the CD in a CD player. If the disc plays in these players, you may need to clean the Xbox DVD player.
  • Check to make sure that all air vents are open and are able to provide sufficient airflow. Overheating can cause Disc Read errors, as well. In addition, ensure that the power supply is unobstructed and uncovered. Much like the Xbox 360, the power supply can become quite hot and can cause errors if unventilated.
  • Check for disc tray errors. Depress the eject button and watch the tray extend. If the tray partially extends and then retracts immediately, you may have a problem with the DVD drive. If your Xbox is under warranty, this can be replaced at no charge. However, if you are out of warranty, you can install a new DVD drive on your own.
  • As a note, make sure that the new DVD drive comes with the same firmware as your original console, or you may experience additional error codes after the installation of the new DVD drive.
May 09, 2011 | Video Game Consoles & Games
My cd player stops while playing and shows er on the display
Try checking for dust on the laser eye, A fine, clean and very soft artists brush will do for cleaning or perhasp the CD has a miniscule scratch on the surface. You'll know if it is a scratch as the CD will always stop in the same place. CD's and DVD's should only be wiped clean with a very clean duster in the direction of from the centre hole to the outer rtim of the disc. Never ever wipe anything across the whole surface from one side to the other or wipe in a circular motion. There a quite a few products on the market that will help you keep you discs clean. Just google CD (or DVD) cleaner. CD's and DVD's are quite forgiving in how badly scratched they can be and still play. It only takes a small scratch or dent that can only be seen under magnification to deflect the laser beam off track.
Mar 15, 2011 | Memorex MD6451R Personal CD Player
Wont read games only reads dvds
This is going to be a bit long -- but very detailed, so please read it carefully. There are several reasons that an xbox 360 system will have problem reading discs. The error messages also vary from unreadable disk, no message at all but the game skips, "please insert disc in a 360 console" to "open tray." There are a few reasons this may happen:
1.Bad disc. Check the back of your disc for scratches. If it looks good (or plays fine in another console), then the disc is probably fine. Also-- try more than 1 game to be sure.
2. Bad laser. The XBox 360 has a DVD drive very similar to a PC's DVD drive inside. The drive contains a bunch of parts including a few motors and gears and a laser.The laser is the part that actually reads the disc. The reality is...with all the hours and hours of game play, lasers do eventually wear out. The laser isn't very easy to replace, but it is replaceable. You can find any and all XBox 360 lasers at the following website:
http://store.richspsxparts.com/xb360ac.html
3.Bad DVD Drive. Sometimes other components inside of the DVD drive can become bad such as the motor that spins the disk, the motors that open the tray, etc, etc. You can get a new DVD drive to just replace everything,including the laser, in one shot but there is a catch. The XBOX 360's DVD drive is tied to the motherboard using a software lock.The easiest way to overcome this lock is to buy the exact same manufacture DVD drive that is in your system now, remove the circuit board from the old DVD drive (which contains the software key) and transfer the circuit board into the new DVD drive that you purchase. If you do this simple procedure, there is no flashing involved. The following website carries DVD drives and also provides instructions on swapping the circuit board from the old drive into the new one.
XBox 360 parts: http://store.richspsxparts.com/xb360ac.html
DVD Drive Swap Info: http://store.richspsxparts.com/imnooninxb36.html
May 15, 2010 | Microsoft Xbox 360 Pro System Console
Is not reading game disks
This is going to be a bit long -- but very detailed, so please read it carefully. There are several reasons that an xbox 360 system will have problem reading discs. The error messages also vary from unreadable disk, no message at all but the game skips, "please insert disc in a 360 console" to "open tray." There are a few reasons this mayhappen:
Apr 14, 2010 | Microsoft Xbox 360 Console
When i try to play a game it keeps sayiny play dvd
Jan 15, 2010 | Microsoft Xbox 360 Console
Xbox 360 wont load any disc and have tried 7 steps of repair on your websitse and it still wont work
Car Audio & Video Logo
141 people viewed this question
Top Audiovox Car Audio & Video Experts
xxxxxx xxx
Jaime Hernandez
Marvin
Marvin
Are you an Audiovox Car Audio and Video Expert? Answer questions, earn points and help others
