Hitachi UltraVision CineForm 55VG825 55 in. HDTV Television
Problem for Hitachi UltraVision CineForm 55VG825 55 in. HDTV...
Picture has 3d effect.
By joliverfile_ on Jun 17, 2009
there r 2 pictures one is shadowing the other. i am not sure of the model number but it is a hitachi projection tv 46'
Solution #1
posted on Jun 20, 2009
Not Rated)
Ecollier2012
Rank: Guru  Hitachi Expert
Rating: 93%, 560 votes
Your TV most likely a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Was this helpful?
Yes
No
Solution #2
posted on Jun 17, 2009
Not Rated)
centerhill
Rank: Master
Rating: 94%, 10 votes
You have a problem with what is commonly called "convergence". There are 3 beams of light that are focused on a lense that is then projected onto the screen. Unless you have a lot of expertise in this area, I recommend that you take it to a repairman that knows what he is doing. It is a 10 minute fix, but probably impossible to explain here. Wish I could help more as this is incredibly easy with the correct knowledge.
Was this helpful?
Yes
No
Popular Solutions for Hitachi UltraVision CineForm
Questions and Unsolved Problems for Hitachi UltraVision CineForm
Do you recommend Hitachi UltraVision CineForm 55VG825 55 in. HDTV Television?
Answer
Answer
At the top, it looks as if there is a second screen behind the first, and it is falling off. As a... (More)
Answer
image around the screen that is yellow , replaced bulb but still there.
Answer
My Hitachi Ultravision powers after after being on for 5 to 10 seconds..Won't cut back on by... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Projection... Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(21591) 042-9690
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
