Question about Rinnai Toyostove Direct Vent Heater: Toyostove Laser 73 Shipping
Laser 73 the wires came loose on the igniter then all the lights started blinking and now it wont work
  • 126 Answers
Your igniter is shot. The wires are embedded during the manufacturing process. Don't even try to solder them, it will never work. Get a hold of your local Toyo dealer and get a new Igniter. BY all means don't keep trying to start the unit. Everytime you try it pumps fuel into the pot. After a few tries fuel will come out the igniter hole. Big mess.
Tom Hawkins
Posted on Jan 07, 2009
  • 625 Answers
Hot surface ignitor or spark type of ignitor? does it look like a ceramic tube going into the pot? look on your computer board for the abbreviation brn. put the ignitor leads here.
Posted on Nov 04, 2007
Ready light on. Error light blinking once/second.
In some KonicaMinolta loose counter wire make start button blinking, fix wiring.
Sep 14, 2015 | Konica Minolta PagePro 1350W Laser Printer
Toyostove Laser 73 heater will not run, and the low/med/hi lights flash on and off?
Remove front grille by taking out two screws at lower right and left front sides of stove. slightly pull botom front of grille toward you and lift up and off. Look for two red wires going into burner chamber, the wires will be incased in a gray plastic sheath as they enter chamber. Push on buton like you are trying to start the heater. While it is going through start up process hold the gray plastic sheath with two fingers and see if the sheath does not get warm in a short period of time the igniter is bad and will need to be replaced. This can be cause by water getting into the burner chamber and causing the igniter to crack.
Jan 05, 2013 | Rinnai Toyostove Direct Vent Heater:...
Speedometer fluctuates and drive light starts flashing then engine light comes on
I had the same problem, if your car is rather new model, what I mean is if it is mostly electronics than this is a problem...
Lights that go on and off is indication of a short somewhere, if this is caused by a ground wire being loose than the problem can escalate to more serous problem... like burning of components, what happend in my case is there was a loose ground wire, this burned out my ignition, the ignition made all the electronics shut down, including head lights at 9pm in the evening...
hope it helps
Feb 16, 2012 | Honda CR-V Cars & Trucks
Laser 73 will not have ignition , it has fuel it start with a green light and in about 3 to 4 mintues the fan start to run then i get a error 2
ee 2 is the code for no ignition. This can be caused by a dirty fuel filter or dirty fuel strainer. The flame rod may need to be cleaned. The igniter may be burned out. Could also be a circuit board problem. If the fuel pump makes a loud ticking or thumping noise then it is a fuel flow problem and I would check the filter and strainer first. When checking the flame rod be sure to unplug the heater first.
Dec 12, 2010 | Rinnai Toyostove Direct Vent Heater:...
Laser 73 fire will start but the circulation fan will not start. will eventually overheat and then shut down with EE 2 error. Whats up?
Because you have the EE2 error I would say there is nothing wrong with the circ fan. Your are either having a problem with fuel flow or the igniter. Feel around the two red wires when you try to start the heater. If they get hot you have a fuel problem. If you also hear a thumbing noise you have a fuel problem.
Sep 27, 2010 | Rinnai Toyostove Direct Vent Heater:...
Need to reset temperature control on my toyostove laser 73
I'm not sure if I'm answering the question right, but the reset light should reset when the heater cools down. If not you may have a problem a circuit board or a bad temperature sensor or loose wire. You should find out why the heater overheated. It could be a dirty fan or fan cage or something else blocking the air flow.
Jun 30, 2010 | Rinnai Toyostove Direct Vent Heater:...
Lost manual stove is blinking code ee2
No ignition. Check the igniter by feeling around the two red wires when you try to start the stove. They will get very hot so be careful. If the igniter gets hot you have a fuel problem. No fuel, low fuel or dirty filter.
Keep us posted,
May 10, 2010 | Rinnai Toyostove Direct Vent Heater:...
Starts go go but dont throw heat
You can check the igniter by touching the cover over the igniter. It should be warm not long after you start the heater. If you have a clamp on type ammeter you can clamp around just one of the igniter wires and you should see somewhere in the range of 2 - 4 amps. No current means your igniter or the ciruit board isn't working. You can check the 2 pins where the igniter connects with a volt meter and should get 120VAC when the heater is trying to light.
Feb 23, 2010 | Rinnai Toyostove Direct Vent Heater:...
Ok we were given a laser 73 and we have checked and there is kerosene reaching the heater but it wont lite what could i do
Check to see if Igniter is working (Dont touch)
just feel close to it, should be warm and you should see a glow inside the peep window.
Ask about service history It may be time to get it fully serviced
Good luck
call me if you need more help
Total Toyo
(907) 488-9179
Dec 07, 2009 | Rinnai Toyostove Direct Vent Heater:...
Rinnai Toyostove Direct Vent Heater: Toyostove Laser 73 Shipping Logo
165 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
