Question about Pentair 250k Minimax Ch Ng Mv Heater
Pentair Minimax 250M
Pentair 250 CH LP will not ignite. Pilot works fine, main burners will not come on. Red LED blinks once every 7 seconds on the Honeywell control module. How do I test the thermostat & pressure sensors? What resistance should they be?
    Champion:
  • 246 Answers
How many times it blink will tell you what is wrong check at the codes. unplug thermostat check fo homs 10 k around is fine at 80 degrees pressure switch require a by pass but DO NOT RUN THE HEATER WITH A BY PASS ANY CONTROL!!!!
Posted on Sep 19, 2009
Pentair 250 pool heater
check gas pressure and when it goes out check voltage from transformer
May 28, 2013 | Pentair 250k Minimax Ch Ng Mv Heater
Can Mini max ch 250 M be converted to LP
not advisable safety orfices nad gas valve and regulator to be changed then mark unit propane
Jun 15, 2012 | Pentair Minimax Ch 250,000 Btu Natural Gas...
I have a Pentair Minimax CH 250M pool heater. When I opened my pool, the heater started up fine and heated the pool initially. However, since the initial heater it has not come back on, and the pool is...
Do you have 24V at the brown wire of the gas valve? If you do then it is probably a bad gas valve.
If you don't have 24V on the brown wire it is probably the ignitor.
Jun 04, 2011 | Pentair Minimax Ch 250,000 Btu Natural Gas...
Pentair Minimax CH Propane Millivolt Ignition Heaters error E05 what is it?
If you are firing, and then going off and getting an E05, your igniter is to blame. It may be glowing but it's getting weak. The diagnostic goes further but that is usually the fix.. With inactivity, the igniter is always to blame. You really need to fire it off weekly to make it reliable and make sure that your heater is serviced at least one time a year to keep all the internal components operating as designed.
  • PILOT ASSY LP MV CH150 IID
  • Manufacturer: PENTAIR WATER POOL AND SPA INC
  • Manufacturer Part #: 471291
  • Description: Propane pilot assembly for heaters with millivolt ignition.
  • Retail Cost: Approximately $65.00
Dec 08, 2010 | Pentair Minimax Ch 200,000 Btu Propane...
The pilot light on my pentair minimax ch 250m will light, but when i switch button from pilot to on the flame goes out on the pool heater.
More than likley this is a bad thermocouple and will need a new pilot assembly. But it can also be a short in the safty circut, rat chewed wires or a bad gas valve. It may be best to get a repairman involved. Or you can just drop each switch out of line and jump past them to check. But part changeing can get pricy. Good luck.
Jun 23, 2010 | Pentair Minimax NT Heater
Pentair minimax 250 leaks onto burner
Unfortunately it is usually caused by a bad heat exchanger. Not too expensive, but a dirty, time consuming job to replace.
Aug 09, 2009 | Pentair 250k Minimax Ch Lp Mv Heater
to test the presure sensor jump the wires that plug in to the sensor if it turns on the presure sensor is bad and the the thermostat do you mean thermo sensor the one that checks the water tep follow the wires to were they plug in turn power off get your finger wet and put it were it plugs in on the 2 prong and turn it on the heater will light up if the sensor is bad
May 11, 2009 | Pentair 250k Minimax Ch Lp Mv Heater
Pentair Minimax 250 does not light everytime
that one think thats bad with pentair heaters they say when you turn one on stand to the right cause the door can blow off because the way there burner are set up u need to take out the burner trays and clen them this problem does not happen with raypak heaters
Apr 18, 2009 | Pentair 250k Minimax Ch Ng Mv Heater
Pentair 250k Minimax Ch Ng Mv Heater Logo
665 people viewed this question
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
