Compressors Won't kick on
Have 2 FAH125 thru-the-wall units. Both 3 yrs old. Fans run on both but compressors will not kick on. No clicking noise or noticeable attmpt by compressor to kick on. Power to both is 220. Tested the outlet - is OK.
Is this a cleaning probelem or compressor failure
    Sergeant:
  • 340 Answers
Could be tripped on high pressure id clean both . Tom
Posted on Jun 18, 2009
Intermitent clicking noie...all else ok...help!
Hello Neal;
My name is Peter. I am a retired field service refrigeration technician.
A clicking noise can come from several different areas of your unit:
1.) Your freezer cooling coil fan striking ice.
2.) Your bottom condenser fan striking a bent frame.
3.) Your Ice Maker.
4.) Your overload relay, which is mounted on your compressor and acts like a started for your compressor.
Are your fans running?
Are you cooling - freezer - fresh food section?
Send me the model number. The model number is on a label on the side wall near the top in your fresh food section.
Tell me what is going on and I will help you.
Jan 01, 2015 | Refrigerators
Compressor won't kick on 12,000BTU Frigidaire window A/C After cleaning
Is everything dry? Do you hear any noises like the compressor running it is just not cooling?
Aug 04, 2012 | Frigidaire FAH106N1 Wall/Window Air...
Came home to find water on floor ,opened freezer to find its not working fans on no cool air , checked frig side same problem , i could here it kick on buzzes for a second and shuts off , so it seem like...
The clicking could be the start relay.If the start relay is bad, the compressor will not start and you will hear a clicking noise in 2-5 minute intervals. The clicking noise is the overload cutting the compressor off when it overheats from trying to start with a bad start relay. To find out if this is bad first unplug the refrigerator. Remove the lower cover from your refrigerator. Then take the cover off that is on the side of the compressor,you will see wires going to this. Now you should be able to see the start relay plugged on to the side of the compressor and unplug it. Now the best way to tell if it's bad is to shake it. If it rattles, it's bad and needs to be replaced. If not, most of the time it's ok. But rather than saying the compressors bad, you might want to replace it anyways because it does not cost much. A quick check on the compressor is to remove the start relay. You will see 3 pins connect a multi meter set for continuity. You should have continuity between any of the 3 pins. If you do not the compressor is bad. Also check from each pin to a good ground on the cabinet. There should be no continuity if there is the compressor is bad. If you replace it and it doesn't work then the compressor is bad and you'll need to call a repairman. (Note that compressors are very costly and are normally not worth fixing).You can enter your model # at http://appliancehelponline.com/referclicking.html for diagrams and illustrations or to purchase a start relay. A 3 in 1 start relay will also work fine. All parts come with installation instructions. Not all models are available.
Dec 09, 2010 | Whirlpool GS5SHAXN Side by Side...
I have a Model ER8AHMRQOO 18 Cubic Whirlpool only 4 yrs old. Few weeks ago I noticed when the controls in Refrige needed to shut off/on I could here it trying to over and over it would run and click run...
Is there is frosty ice on the freezer back wall, if so. Based on your symtoms I would suspect page 1, Item #4 Adaptive defrost control #4388931 Est $85 -120, Other issues, page 2, compressor start device, #22 start device #2225929 Est $45 - 65
Ric
Mar 10, 2010 | Refrigerators
I have 3 compressors, all of them refuse to stop compressing until i manually shut them down,husky 26 gallon upright 5 yrs old, porter cable pancake 2 yrs old. and a master elite? came from home depot as...
the regulator/switches are either rusty, clogged, or need to be replaced. if you have some machanical aptitude and common sense this should be easy, if not have a pro or someone some knowledge of this type of thing handle it for you. in the future drain your compressor DAILY to avoid this problem
Nov 13, 2009 | Porter Cable Air Tools & Compressors
Compressor kicks out and it's new
First of all, clean your outside coils so that you are assured of good cooling air. The compressors have an overtemp device that is usually internal to protect them against heat. If you have an air compressor use it to blow out the coils good. If the compressor will start, the capacitor is good so it sounds like a cooling problem with the compressor
Jun 25, 2009 | Ruud UAMB Air Conditioner
The fan runs constantly. The compressor starts,
Check the compressor run capacitor first.
Jun 21, 2009 | Kenmore 53701 Dehumidifier
INTERMINENT BUZZING NOT COOLING
from your description it sounds as if the compressor is not starting up. the buzzing noise usually occurs approx. ever 3-5 minutes and is followed by a click. this indicates either a bad start relay or a stuck compressor. and from the model you listed it is most likely the compressor. if the unit is under 5 yrs old it should still be in warranty thru sears.
Thanks for using FixYa Peyton
Feb 18, 2009 | Kenmore 71812 / 71814 / 71819 Bottom...
Kenmore (253.51399104)side by side making buzzing/humming noise
It will rattle slightly, this is normal. The ones that are burned out will sound like they have gravel in them, you can defininely tell something is wrong.
The problem with diagnosing Kenmore fridges with this problem is that there are different manufacturers. Yours is built by Frigidaire and probably has a Tecumseh compressor. We find more failed compressors with the Tecumsehs than we do with the models that have Embraco compressors. The models with Embraco's generally have more relay failures.
You should not hear the buzz/hum at startup. You will need to replace the compressor, which will be replaced at no charge to you if it is less than 5 yrs old.
If it is older than 5 yrs, you can have it replaced, but it will be almost as expensive as a new fridge. You can buy an aftermarket start device called a 3-in-1. This has a start capacitor built in to give it a little more boost on start up. I don't recommend using them unless it is a short term fix until the compressor can be replaced or if it is out of warranty and there is nothing to lose anyway.
Thanks/Mike
Dec 06, 2007 | Maytag MFI2568AE Side by Side French Door...
Heating & Cooling Logo
139 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
