Does anyone know how to fix this issue? It seems that a lot of people have this problem. Thanks.
Comments:
Jun 20, 2009
- Thanks for your help. I only have one drive, for both DVDs and CDs. The drive still works fine for DVDs, but for some reason it no longer recognizes CDs. At first I thought it had to do with settings in Adobe Reader, because the CDs I was playing were PDF files. I changed the Reader settings, and then one CD was recognized. But after that no CDs have been recognized. It's a mystery what happened, and why the DVDs are still readable and play fine.
ok if it reads dvds and no longer cds did it ever read cds i am asuming that you have a 2 drives one for cd and one for dvd and i asume that it did read cd no you didfnt say what happen ok sometimes when the cd does not work and the dvd drive does work some time but not always either you cd drive laser is either dirty or the plug in side of the computer is off the data cable the silver and red conected to the cd and it also could be loose from the mother board or it is bad meanig you might have to replace it but first check inside the computer you have to take the cover off and inspect now after you have done that make sur you cables and power plug going in to the cd is secure and tight then put cover on back again and restart you computer and see if the cd is working now some time windows does not load all the driver for the hardware so after it is restated check the cd and if not go to the cd drive properties in the cd and see if it is enabled or working if it is and widow says it has no problems then you might have to get a cd len cleaner disc and if that dosent work then the cd drive is died and you have to replace the drive other wise you would have to go to the registry and maybe some time when you clen you registy and see if the disc is fragmented sometimes it will work i am just giving you some starting points because you did not say what you were doing and what caused this see if i knew what you were doing and more imformation i couls have toy fix it your self
won,t let me download any thing put a cd in the e-drive an it says that i don,t have an e drive at...
(More)
won,t let me download any thing put a cd in the e-drive an it says that i don,t have an e drive at all which I KNOW THAT I DO
I was burning some CD's, i was onto the 8th disk when it just wouldn't detect the end of the burn or...
(More)
I was burning some CD's, i was onto the 8th disk when it just wouldn't detect the end of the burn or eject the CD. I shutdown and re-started and still nothing was being detected. I force ejected the cd and tried another but still nothing seems to be detected. Any help appreciated, laptop is an Acer 3623.
i have aspire 4720z laptop in my drive can't open Cd's i use XP it will not open any cd's like...
(More)
i have aspire 4720z laptop in my drive can't open Cd's i use XP it will not open any cd's like mother board cd's also please give desired solution for this Thanking You Harikrishna
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
