The issues I am having is the unit will run and agiate like normal when moving to the spin cycle the unit spins up but then will shut down before it reachs speed (about 10-20 seconds into the spin cycle). I have noted that the motor is hot to touch at this point and once it cools down the unit will restart and then fail again shortly after it starts to spin again. Any thoughts? Machine is about 14 years old and this is the first issue ever with it.
SOURCE: GE Washing machine won't spin in rinse cycle
Possible your outlet filter is blocked. This requires cleaning depending on your usage. Clean this out and refit. Good luck. Plug off the wall first.
SOURCE: Kenmore Top Load Washer Series 70
NO,your transmission is probably ok!! Inside your top end of agitator are these 4 plastic parts called "dogs" they need to be replaced.To be 100% sure ,do this first,Fill upthe machine on small load and while its washing look to see if the bottom end of agitator is moving back and forth ,if it is replace the dogs.In some machines you have to change the upper part of agitator.If the agitator is not turning at the bottom than,remove the top of agitator cover so you can get a extended half inch socket in to it and pull the agitator up and check the transmission splines.If they are smooth and cannot grab the agitator than your trans, is bad.
SOURCE: neptune tl washing machine spin cycle
Mother26, I have a fair amount of experience with mechanics and have repaired a few washing machines and dryers in my past. For me, both components are easy to replace. Your repairman would have an equally easy time. I'd estimate an hour to repair and verify. Your trouble comes in is the $122 for the replacement clutch and the $82 for the tub displacement sensor. And that's assuming there's no damage to anything else so far.
In my case, change the previous owner didn't remove from pockets destroyed the clutch, transmission, and pump. and somehow spillage caused the tub displacement sensor to short. Overall, far too many parts to make repair equitable.
Keep in mind, this is, in the opinion of many, a failed design on the part of Maytag. Ultimately, it's a toss up on how confident you are that your current condition is the limit of your problems.
SOURCE: Washing machine will not complete spin cycle
OK, what you are experiencing is a timer mechanism fault. the timer motor is malfunctioning. anytime you have to manually advance the timer knob, this will signal a fault within the control mech. this is easily fixed by, replacing the timer control module. i will place a link to the actual part needed to fix this issue. you can also purchase this timer on line at this site if you wish.
CLICK HERE
SOURCE: Bosch WFF1800 - not spinning
HI,
move the kicking plate on the front-bottom of the machine. You will see
o circular lid there, turn it on anti-clockvise to open. All of the
water blocked will come from there, be careful. Look carefully that
there are some objects blocking the water draining. Then turn on the
machine on draining programme, the plastic rotor should turn fastly
when the machine is on. If it is not running, change the pump motor. If
it is running, but machine is not draining again you can understand
that there is an objeck stuck on the hose between drum and pump motor.
Lay down the machine on its rear facade, you will see a large and black
hose between drum and pump motor. When you remove it, you will see that
there is something that blocks water running.
thank you for using fixya,rate my answer,
vijay
