Question about Comdial 8324S-PT Corded Phone
Comdial Impact 24/48/72 phone
Phone set to "do not disturb". will not turn off. Now message on screen says "Wrap Up". Can't find that message anywhere in the manual and can't get it to clear. ??????
    Problem Solver:
  • 19 Answers
You can try the below steps in order to turn off Do Not Disturb. For GE 6.0: There is a button on the base lower right corner  (NOT the phone), you need to press it once again to turn off Do Not Disturb
For GE 5.8 GHz:
1. Pick up the phone handset and dial *98.
2. Press 2 to disable Do Not Disturb.
3. Once you hear the confirmation that Do Not Disturb has been disabled, you may hang up the phone handset.
Posted on Nov 13, 2008
How do I turn do not disturb off
With the Comdial Impact 8012S and a few other models, the DND feature is toggled on and off through the menu system as follows:
1) Select Options (the right-most button below the LCD screen)
2) Press Next (use that right button again) until DND appears as the current option.
3) Select DND (by pressing the left-most button).
4) Select OFF (by pressing the middle button).
5) Select Exit (the right-most button, again)
6) Press Speaker to end the programming mode. The speaker button is on the body of the phone towards the right and bottom of the keypad. The exact position depends on the model.
I hope this works for your model as well. If it doesn't, please add a comment with the model of your phone.
Jun 23, 2015 | Comdial Lands Phones
How do you get the message light to stop blinking and the call S12 to go away?
(ITCM # 3 plus your extension number) to cancel message
(ITCM, HOLD) to retrieve message
May 21, 2014 | Comdial 8324S-PT Corded Phone
Need to know how to change time on Comdial GCA70-281
  1. Programming the time and date for a Comdial Impact digital phone system must be done from the attendant's station, usually the phone located closest to the Comdial controller. Go to this station before attempting to change the time.
  2. Step 2 set-clock_thumb.jpg Now the phone system's clock is ready to be reset. Without picking up the handset, press the "Intercom" button on the phone. Dial * # 0 1. The digital display2.gif should read "Set Clock"
  3. Step 3 Set the year by dialing two digits (00-99)
  4. Step 4 Set the month by dialing two digits (01-12)
  5. Step 5 Set the day by dialing two digits (01-31)
  6. Step 6 Set the hour by dialing two digits (01-23)
  7. Step 7 Set the minutes by dialing two digits (00-59)
  8. Step 8 set-clock2_thumb.jpg Comdial Impact phone with updated day and time. Pick up the handset and set it back down to set the programming changes. The new date and time should display immediately on all phones connected to the Comdial system
Nov 04, 2009 | Comdial Impact 8124S Corded Phone
Called extension and now the light won't stop blinking.
There is a messaging side that is part of the phone system and not the vmail. You can send someone a message and it will appear on that persons phone as text. you should be able to call the person back and that will cancel the message, if not scroll thru the menu screen on that phone for msg cancel.
Dan
Jul 30, 2009 | Comdial Impact 8324S Corded Phone
I don't know the voicemail password; I am trying to reset it to the default
you will need to log in from a main phone or phone with LCD screen and go to the set you need to set to default in the menu...this maybe only be done through your vendor unless you know the system password to get into the configuration mode.
May 29, 2009 | Comdial Impact 8024S Corded Phone
Recording and setting phones for nighttime
When calling your Voicemail and getting AA press * . Ext 70. Input password follow the instructions for box 800
Mar 17, 2009 | Comdial Impact 8024S Corded Phone
Setting up voicemail on comdial 8212S-F8
Your phone model number is no help with this problem. You could have this phone on one of several different Comdial phone systems using one of several different voice mail systems. You will need to determine which voice mail you have and locate instructions for that specific unit.
Dec 13, 2007 | Comdial Impact SCS 8212S Corded Phone
Changing message on Comdial Impact Telephone
Sounds like you are trying to change a voice mail recording. Your Comdial phone can be used on several different Comdial phone systems and with several different voice mail systems that all program and set up differently. Do you have any manuals or instructions for your voice mail system? If not, you will need to find out which voice mail you have and try to locate manuals.
To change main greetings, etc.. you would need administrative rights to the voice mail. There will probably be a password, hopefully you know it or it's still at default.
Nov 28, 2007 | Comdial 8324S-PT Corded Phone
Message light won't turn off...Comdial 8212S
Try dialing (from that phone)
Intercom # 3 then that extension number(exp. 100)
Nov 27, 2007 | Comdial Impact SCS 8212S Corded Phone
Comdial 8324S-PT Corded Phone Logo
830 people viewed this question
Top Comdial Lands Phones Experts
Starnley Johnwells
Starnley Johnwells
k24674
Are you a Comdial Lands Phone Expert? Answer questions, earn points and help others
