SanDisk Sansa m240 MP3 Player Logo
Posted on Jun 17, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Only displays initial power on screen (SANSA m240 1.0GB)
The device shows initialize screen then hangs on the SANSA logo screen. My computer does not see the device at all. Is there some sort of reset for this device?
Anonymous
Level 3:
President:
  • Master 392 Answers
  • Posted on Aug 09, 2009
Anonymous
Master
Level 3:
President:
Answers
392
Questions
6
Helped
168559
Points
1317
Keep the hold switch to right side and connect to pc...then format the player or try updating the firmware..tht must do...
2answers
TOPCON CL100 Display INITIAL ERROR
NO CORRECTION ERROR IN TOPCON CL_100 when switched on
HP Colour Laserjet 5550dn. Once switched on it goes through memory check; display lights and hp logo on display screen. Then displays on screen "Initializing . . ." Doesn't go any farther - just...
i hope that the problem is not in some of your printer boards, but i have to tell you that you have to expect problems with POWER SUPPLY BOARD or FORMATER BOARD. Please call service for help
pifonski
1helpful
My motherboard have four leds in red light, d0 dled2,dled3 and don`t start up
Hi ntamayo,
Here is the description of what the four leds indicate:
d9c5d26.gifSystem Power ON-The D-LED will hang here if the processor is damaged or not installed properly.
1d08ad7.gifEarly Chipset Initialization
14ff182.gifMemory Detection Test
- Testing onboard memory size. The D-LED will hang if the memory module is damaged or not installed properly
1719312.gifDecompressing BIOS image to RAM for fast booting
1cab634.gifInitializing Keyboard Controller
3b994fe.gifTesting VGA BIOS
- This will start writing VGA sign-on message to the screen
2b36bf2.gifProcessor Initialization
- This will show information regarding the processor (like brand name, system bus, etc...)
f53faac.gifTesting RTC (Real Time Clock)
9ec1db5.gifInitializing Video Interface
- This will start detecting CPU clock, checking type of video onboard. Then, detect and initialize the video adapter
4f7c881.gifBIOS Sign On
- This will start showing information about logo, processor brand name, etc
6a25253.gifTesting Base and Extended Memory
- Testing base memory from 240K to 640K and extended memory above 1MB using various patterns
1bef2e1.gifAssign Resources to all ISA
e664b69.gifInitializing Hard Drive Controller
- This will initialize IDE drive and controller
c3b6c58.gifInitializing Floppy Drive Controller
- This will initializing Floppy Drive and controller
3afd28f.gifBoot Attempt
- This will set low stack and boot via INT 19h
24b95b0.gifOperating System Booting
When your motherboard is stuck on any of these signals, that's a clue that something is wrong with that particular device on the board. Replace it and try again.
Good Luck
And don't forget to leave a rating,
Thanks
Mark
Sandisk Sansa View 16GB Won't Start
if it is detected in your system,use sansa updater to upgrade the firmware.You will find it here
If not, first download the firmware from here 1.Turn on the View
2.Put the device in Hold (move Hold button until orange is showing)
3.Press and hold the Left Button
4.Plug the 30 pin connector into the device (be sure the USB is plugged into the computer)
5.Wait for View drive(s) to mount
6.Extract the downloaded zip file and transfer all the contents to the mounted drive.
7.Disconnect the Sansa View and let it restart. 8.Upon completion of the firmware upgrade, the device will restart. If the restart does not initiate or complete, press & hold the Power switch for 8 seconds to reset the device and then release and press again to restart.
M230 problem...
Use Windows Media Player to delete
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
1helpful
3answers
SanDisk Initializing
Sansa m250 is frozen on initializing screen
my e200 does that im sooo pissed it just stays on the screen turns blue than goes back to home screen. i let the batteries run out and the same thing still happens!!
Initializing/ Sansa loop
Please try this steps. Remove the battery from the player. Then enable the hold switch for it to show orange/red color connect the player to the computer. Right-click My Computer and click on Manage. Click on device manager and click on Universal Serial Bus Controllers, see if you have USB Mass Storage Device. Then see if you also have there Storage Volumes, right click on it and see if that is the player. If it is then click on Disk Management and try to format the player from there if it is visible if not you may have to replace the product.
Top SanDisk Audio Players & Recorders Experts
SmartAviator
SmartAviator
Grand Canyon Tech
Grand Canyon Tech
Alexander
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
