Question about Refrigerators
I have a whirlpool regrig model ET21PK. both the refrig and freezer are cooling properly, but I keeep getting water in the bootom of the frige
SOURCE: LG BOTTOM FREEZER FRIGE
I had the same problem. LG came and fixed it in about an hour. Replaced the circuit board with an updated one and swapped out some sensor. Seems to work now and it was all under the 2 year warranty.
Posted on Jul 17, 2008
SOURCE: ge refrigerator model gss22wgph bb
Carben,
I have the same problem and I am able to resolve it by defrosting the element which is behind the inside rear panel of the freezer. I use a hair dryer to melt the ice build up. It happbed a couple of times so I know that there is a cause for this which may be the defrost heater but I am not sure how to confirm this. Let me know if you have any ideas.
Posted on Sep 16, 2008
co7196
  • 3433 Answers
SOURCE: Refrig constantly runs and is only semi cool, same w/the freezer. Left out in a cool room in the winter and stop running when it was cold. Started refrig back up and now runs constantly w/out cooling
Let freezer get down in temp and fridge should start chillg.Good luck
Posted on Jun 03, 2009
Sea Breeze
  • 4655 Answers
SOURCE: refrig & freezer not cooling properly
I believe the start relay and start capacitor with the overload will need replaced. That is easy and should solve your problem, Sea Breeze
Posted on Aug 26, 2009
projdoc
  • 2237 Answers
SOURCE: Whirlpool Side By SIde Refrigerator Freezer stopped cooling
5 reasons for fridge and/or freezer getting warm: 1- the evaporator coils are icing up and won?t let air circulate. 2- the evaporator fan is not working to circulate air. 3- there is no refrigerant in the system. 4- no power to fridge or compressor. 5- the condenser coils have no air circulation check under the fridge behind the vent. if it is too dusty or the fan isn?t working, it is not getting enough airflow to cool down. replace fan and/or vacuum out the dust. if there is no power to the fridge, the light will be off. if the compressor is not running, there is a defrost timer that cuts the power temporarily to the compressor to melt ice on the coils. it?s located under the fridge behind the bottom vent. If the timer is off and the compressor is not going, the compressor or the main board is bad and needs replacing. there is also a temperature sensor on the evaporator coils that tells the defrost coil to turn on and when to turn off. if the defrost timer is on but the coil is not heating up, replace the sensor. if it still won?t heat up, it?s the timer or the coil. the easiest way to tell if there is no refrigerant- the freezer wall is warm and the compressor is loud. if there is no refrigerant, it may be more cost effective to replace the fridge. if you feel no air coming from the freezer vent, the fan needs replacing. If you feel air moving in the freezer but not the fridge, the channel from freezer to fridge is blocked. if the freezer has air and the rear freezer wall has frost on it, the evaporator coils are iced up and need defrosting. causes: 1. low refrigerant 2. no fan 3. too much humid air in fridge/freezer due to door open or bad door seals 4. the condensate drain tube is clogged if the seal around the door is ripped or not completely sealing, or there is condensation at the bottom or the walls of the fridge, replace the seal(s). no air, no fan. Replace if the refrigerant is low, it just needs a top off. but you need to be certified by the epa to move refrigerant, so get a professional. defrost solutions: unplug the fridge. remove the wall of the freezer that is frosted/icing up. use a hair dryer to melt the ice. do not get too close. you will see a drain under the evaporator coil. make sure it is not blocked. the water should run freely to a condensate pan under the fridge that evaporates the condensation with the hot line from the compressor. once the coil is free of ice, frost, and water, replace the panel and repair any of the problems that caused the icing up. plug the fridge in and turn it on. If it frosts up within a week, there is still an issue that not been taken care of.
Posted on Aug 28, 2009
I have a Whirlpool Refrig. model GX5FHDXVY04. The freezer is working properly but the refrigerator is not cooling. I noticed frost on the inside back panel of the freezer. I turned the temp down in the...
Many of frost-free fridges use fans to move a controlled amount of air into the upper or side cooling chamber, check for non-working fan or a stuck or malfunctioning damper control. Keith L.
Mar 02, 2012 | Whirlpool 24.8 Cu. Ft. Side-by-Side...
Model ET22DK or ET22DM water collecting inside refrig
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Mar 15, 2011 | Whirlpool Refrigerators
I have a montegormery wart side by side regrig and freezer. The freezer working wonderful, however refrig barely keeping items cool
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 29, 2011 | Refrigerators
Whirlpool Wrn38rwg6 frige has decided to not cool properly
My first thought is it defrosting? Look into rear of the freezer and see if ice is building up on rear wall of freezer. If yes manually defrost and let me know what you find. If no I would want you to feel compressor for overheating or look and see if a fan has stopped working while compressor is running. Sea Breeze
Feb 20, 2010 | Refrigerators
Whirlpool Refrig. stopped cooling with no warning. Freezer is freezing with ice build up on back wall. Thanks, Mike Strickland
Mike, Please send the complete model number so I can help you better. If your refrigerator has a defrost timer this could be the problem. You also can visit my site below and enter model or part number in the search feature. We also offer free help and assistance. , Thanks, Sea Breeze seabreezehvac@yahoo.com
http://servicepartstec.blogspot.com/
Mar 29, 2009 | Whirlpool Refrigerators
My whirlpool refrig wont cool down the freezer.
Reach into your freezer and feel the back wall. If it is VERY cold then likely your freezer coils are frozen over which prevents the unit from cooling properly. There is also a Defrost thermostat that helps control freezer temp that you'll need to have checked. This is a last resort but if it's a newer frig, the computer control board would be the culprit if the others are OK.
Nov 29, 2008 | Whirlpool Refrigerators
Water leaking from inside of refrig.I think it could be Ice maker
defrost the freezer drain tube with a hair dryer
May 09, 2008 | Refrigerators
Refrigerators Logo
145 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
