Question about Whirlpool GU2400XTP Built-in Dishwasher
Have a whirlpool dish washer it wont work the cancel drain button is blinking how do i reset that thanks
    Problem Solver:
  • 7 Answers
Have you tried refilling salt and rinse aid?
if that do'nt work it probably needs servicing it could be drain pipe blockage.
Posted on Jun 17, 2009
Need a reset sequence for Whirlpool dishwasher Model numberDU1ooXTPQ8 the normal and light load lights are rapidly blinking and it will not start or cancel out
f6 is no water coming in dishwasher check inlet valve an flow valve to cancel open door press start button untill the led go out an close the door the washer should reset an go back working
Dec 20, 2017 | Whirlpool Dishwashers
My washer wont start, I can't get it to cancel or reset. I unplugged for 10 minutes and all lights are still on.
We are sorry to hear of the problem with your Whirlpool washer. We would recommend having a local certified technician in your area properly diagnose and repair the issue you are experiencing. Please email us at Whirlpool_Digital@Whirlpool.com with your name, phone number, address and the model and serial number for your washer.
Apr 14, 2017 | Whirlpool Gold GU2275XTV Builtin...
I have a whirlpool gold quiet partner III Black dishwasher. All of a sudden it stopped working. I push the accusense button and start the cycle for washing, it looks like everything is working normally, I...
Hi
If clean light is blinking then it may be an issue with heater circuit, door switch or wash pump, please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry or High Temp Wash-Heated Dry-High Temp Wash-Heated Dry . Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset. If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back if you need more information.
Daniel
Aug 30, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool Duet Washer has done GREAT for two years..now suddenly,
this means your drain pump is clogged--- there are 3 screws at the bottom of the lower front panel. Remove these screws and there is a drain pump cleanout located in the middle. Twist this off by hand can clean out the debris--- WATCH OUT LOTS OF WATER will come out so have towels ready.
Jan 19, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Cancel drain light continue to flash and dish washer will not make a sound
Hi sandsmi8,
I'm Harvey the Master Plumber.
You're telling me only: cancel drain light continue to flash and dish washer will not make a sound.
Based on this info alone you might be able to reset the d/w with power interuption. Try turning off the breaker for ten minutes. With some models this will reset the d/w computer. If that dosen't work you might consider utilizing our Repair Directory to find a repairman.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 13, 2008 | Dishwashers
Dishwasher won't start
jamcdani Most likely the problem with your dish washer is bad key pad. It is not repairable and has to be replaced. Whirlpool does not sell it separate and you have to by the whole console assembly. The price range is between $95 and $115 (different colors) and it is not very complicated to replace it. I can help you with the complete step by step instructions and, if you provide the complete model number of your dish washer, I get the part number and the best price for you. Gendos post back...
Jun 29, 2007 | Whirlpool 24 in. DU915PWP Built-in...
Kenmore 66516032400 Dishwasher
On another website, we found a reset code that works for our Kenmore, which I think is the same as yours. Hit Heated Dry, Normal Wash, Heated Dry, Normal Wash (one at a time, within six seconds).
Dec 05, 2006 | Kenmore 24 in. 16032 Built-in Dishwasher
Whirlpool GU2400XTP Built-in Dishwasher Logo
301 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
